Question about Panasonic Lumix DMC-TZ5A Digital Camera
SDHC card How do I format a new card
  • 3 Answers
On my DMC-TZ5 - using the menu button and the surrounding 4 direction buttons.
Put card in camera & switch on.
Press menu button.
Use up/down to select the spanner (wrench) setup menu.
Use right to enter the sub-menu.
Use up/down to find the Format command (the menu will scroll when you move off the bottom).
Use right to select the format command... select yes & the camera does the rest.
Posted on May 31, 2009
Pv-gs35 sdhc formatting win7
SD cards go up to 2GB in size. SDHC cards go from 4GB to 32GB.
The PV-GS35 works with SD cards, not with SDHC cards. Your 1GB and 2GB cards are SD cards. Your new 16GB card is an SDHC card. While SDHC cards fit into the slot, they are electronically incompatible and will not work in devices not designed for them.
Jun 12, 2012 | Panasonic PV-GS35 Camcorder
How to format SDHC card on Canon PowerShot
The PowerShot S1 doesn't take SDHC cards, only CF cards. If you're asking about some other camera, not all of the cameras deigned for SD cards take the higher-capacity SDHC cards.
Jun 10, 2012 | Canon PowerShot S1 IS Digital Camera
SDHC card not working
Go tinto the camera's menu and format the SDHC memory card.
If this does not work then insert the SDHC memory card into an USB card reader and plug it into the USB port on your computer and it the computer detects it as an external storage device then format the SDHC memory card.
If the computer cannot detect this SDHC memory card then this memory card is faulty.
Apr 02, 2012 | Cameras
Card not initilized? what does this mean?
It means the card has not been formatted, or that the camera doesn't recognise the format, but that might not be the full story. You don't say whether this is a new card or one you used before. I'm going to assume this is a new card (otherwise, it means the card has become corrupted or there is a camera fault).
The first thing to try is formatting the card. There is a function in the camera menus to do this. If it won't format or gives an error when you try, then the card may be incompatible. Formatting deletes anything already on the card.
Maybe it is having trouble with the size of the memory. Memory cards have grown enormously in capacity in the last couple of years, and even relatively new cameras may not be able to cope with the memory size of the newest cards.
If it is a new SD card, then maybe it is actually an SDHC card. "SD" cards larger than about 1GB are usually SDHC cards. SD and SDHC cards fit the same slots, but they are slightly different electrically. Many cameras won't work with SDHC (high capacity) cards. SDHC is not backwards compatible
Jan 22, 2011 | Fuji FinePix A330 Digital Camera
I've tried formatting a new san disk 4gb card and still reads "unable to use card" what do i do?
You haven't told us what kind of camera it is, but I can guess at the problem. There are two possibilities.
1. Your camera will only read SD cards, not SDHC cards. You've just bought a new memory card, not noticing that it was SDHC. The new cards don't work in your camera, not because they or the camera are broken, but because they're not compatible.
Cards up to 2Gb are generally SD. Cards over 8Gb have to be SDHC. 4Gb cards can be either SD or SDHC, but are almost always SDHC because they're cheaper. (I would avoid the rare, expensive, and problematic 4Gb SD cards.)
Your solution is to go find a 2Gb card, and be extra sure that it doesn't say "SDHC" on it. (If it does, it probably means that they made a 4Gb card, but there were some error locations and so they disabled half of it and packaged it as a cheap-brand 2Gb.)
2. You formatted the card NTFS, whereas the camera needs FAT32. You can format the card using Windows, but there is a complication: Windows defaults to "NTFS" when formatting, but memory cards normally use FAT32. Before you attempted this, you should have connect the card, and checked the 'properties' on the drive that appears. It probably said "FAT32". In this case, you could have gone ahead and formatted the card, but be sure that you chose "FAT32" from the drop-down list. If you format it NTFS, your camera won't be able to read it!
In this case your solution would be to format the card again, but using the FAT32 format.
You might find it useful to check your camera on dpreview (dot) com, and see if the memory card type is shown as just SD or SD/SDHC.
Jan 20, 2011 | Cameras
CX7525. Inserted new 4gb sd card. Camera says it needs to be formatted. When I click on the "OK" button to format, it says "card needs to be formatted" again and again. Will not format...
There are no 4GB SD cards. "SD" cards larger than about 2GB are actually SDHC cards. SD and SDHC cards fit the same slots, but they are slightly different electrically. Many cameras won't work with SDHC (high capacity) cards. SDHC is not backwards compatible.
Dec 29, 2010 | Kodak EasyShare CX7525 Digital Camera
I just put in a new SD card in Kodak Z760, but it needs to be formatted. How do you format the card?
There is a function to format memory cards somewhere in the camera's setup menus, but this might not be the problem. Most cards come pre-formatted. If this card is more than 1GB it will be SDHC instead of SD. SD and SDHC cards fit the same slots, but many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible.
There is no reason not to try formatting the card, but if it won't format or isn't usable after formatting, then it may be incompatible.
Nov 27, 2010 | Kodak EasyShare Z760 Digital Camera
I have a gateway DC-T50 digital camera. I put in a new 2GB SD memory card, formated the card, but when I go to use the camera I get error msg i inserted a new 2GB SD memory card, I formatted it, but when I...
Is it an SDHC card? SD and SDHC cards fit the same slots, but many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible.
Nov 20, 2010 | Gateway Cameras
The camera says I need to format my memory card and when I do so the screen reads Filesys errore00100, how can I fix this?
The card may be incompatible.
Nov 07, 2010 | Kodak EasyShare C310 Digital Camera
I purchased a new memory card (sandisk sdhc ) it will not format?
Get a new camera :-)
Seriously, the Z740 is designed to work with SD cards, not SDHC cards. While SDHC cards will fit into the camera, they will not work. You need to buy SD cards 2GB and smaller.
Jul 26, 2010 | Kodak EasyShare Z740 Digital Camera
Panasonic Lumix DMC-TZ5A Digital Camera Logo
54 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
