Question about Stiga ST4100 Indoor Table Tennis Table
Top does not align
There is a gap between the two halves of the top and one is a a little lower than the other
Epson C88 3/16" gap every inch printing black text
Reload the printer drivers, you can get this from the manufacturers web site under support or downloads.
its a common error and an easy fix.
good luck !
Mar 30, 2017 | Epson Stylus C88 InkJet Photo Printer
I need the points gap for a 1940 dodge business coupe
Top dead center:*Set breaker point gap from .018 to .022*Bring #1 piston to "Top Dead Center"*The zero "D-C" mark on the vibration damper must be aligned with the timing indicator/pointer*Rotate distributor until points begin to open slightly, then tighten distributor*Start engine & allow to reach normal operating temperature*Set warm idle at 475 RPM*Use timing light to verify that the zero "D-C" mark on the vibration damper is in alignment with the timing indicator/pointer
Nov 26, 2011 | Cars & Trucks
How do I open my calculator to replace my battery?
refer to page 20 of the manual on the step by step instructions for replacing the battery. Here is the manual:
http://www.actuarialoutpost.com/downloads/ti30xa.pdf
thank you,
Lee
Sep 21, 2011 | Texas Instruments TI-30XA Calculator
Installing multiport valve.
No, the o ring should not squeeze out. When putting the top and bottom components together....
  1. Make sure surfaces are clean...No lube!!!
  2. Make sure o ring is clear
  3. Install o ring usually on lower half but depends on model
  4. Gently place upper half on lower
  5. Place clamp around the halves (this can be tricky)
  6. If there is a tension spring with the clemps, do not use it yet
  7. Without the spring, insert bolt and start tightening the clamp
  8. The halves should slowly come together
  9. Make sure the halves and band are aligned
  10. Once the top is on the bottom fairly secure, loosen the clamp and re-tighten with the spring this time till the spring is compressed with no gap between the colis on the spring. If you have two tightening clamps, do this at equal intervals.
I dont know the exact model you have, but this is a standard procedure... Good luck..
Jul 11, 2010 | Hayward SAND FILTER, PRO SERIES
The agitator tries to rotate, but instead jerks, but doesn't rotate in normal motion. It also makes a ratcheting snapping sound.
Does the lower half of the agitator still operate normally? (Back and forth) Can you spin the top half (spiraled part) of the agitator in both directions with out the lower half moving? If so then you have a worn set of agitator "dogs" they are little plastic ears located in the upper half of the agitator and catch the notched inner section of the agitator to make the top action work like a corkscrew, slipping one way and driving the other as the lower half goes back and forth.
To get at these parts you will need to remove the agitator, Remove fabric softener dispenser or cap on top, and look down inside tho opening.
You will need to remove the plastic cover inside that has two ears sticking up, pull on one side or the other and it should pop out, there will be a rubber seal around it so it will be a little difficult to remove.
Now you will have access to the bolt that holds the entire agitator in the machine. The agitator dogs are located right on the outer edge of the center cup that the bolt goes through. To access them you will want to seperate the two halves of the agitator and flip the top half upside down while holding your hand inside it to catch the cup with the dogs in it. Part number 80040, for the dogs.
Good luck to You!!
Jun 26, 2010 | Roper RAS8445KQ Top Load Washer
No agitation
I have a Whirlpool Utlimate Care II LSQ8520JQ0. For those having a problem separating the upper and lower agitator halves, here's how I solved it after about 2 hrs of aggravation.
Called Sears and Whirlpool with no help (didn't have tech manual...go figure).
I saw the same post with the problem with melted hooks (I called them tabs) ontop of the dog housing being melted. You can differentiate the melted tabs from the dog housing as the dog housing is usually clear plastic (after wiping all the crud off) and the tabs are white as they are part of the agitator. There will be four white tabs on top of the dog housing. They look both smashed and melted. I took a flat head screw driver and and hammer and chipped off the white melted tabs visible on top. I inevitably also chipped some of the dog housing but only marginally. Once chipped off you'll see the tabs are actually rectangular in shape. At this point I EASILY pulled the top and lower halves apart. Those retangular tabs are the molded part of the agitator housing extending down past the dog housing. You're home free at this point.
It's the melted tabs on top of the dog housing that keeps you from separating the halves. What a pain but finally figured it out.
Oct 19, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Roper RAX4232KQ - Top part of agitator won't turn
you need to install new agitator dogs . very in expensive. remove cap on top of agitator reach in and remove opaque cover. you should see a 1/2 " bolt remove that and pull up on agitator. pull apart two halves. disassemble. install four dogs. reassemble in reverse order
Feb 06, 2008 | Roper RAX4232KQ Top Load Washer
Problem with opening monitor cover
to remove the back cover of samtron 56 v monitor is very simple.
locate the 2 bottom screws of the cover, remove them. pull slightly back the cover holding the bottom and about half an inch gap will be seen. insert a flat screw driver straight down through the upper side hole with your left hand and hit the head of the screw driver with your right hand. a slightly big sound is heard and that side is disengaed. repeat he same with the second hole. and you have done it. try.
Oct 10, 2007 | SAMTRON 55V 15" CRT Monitor
Can't open rear compartment
To seperate the two body halves: 1-Set the vacuum on it's wheels & open the front door. 2-Place a wide screwdriver blade just between the reaer cover and the rubber bumper and tap the screwdriver on the side to push the bumper forward towards the door a little bit. 3-Grasp the bumper and pull it straight out. 4-Leave the vacuum halves together...flip the vac over on it's top. 5-Put your palms against each wheel with your fingers in between the body halves..pull each side out just a little and snap the lower body upwards. It will then come apart. 6-You can then mark the wires on the cordwinder for corresct replacement afer the repair. Make sure you put the bumpers back on each I-Beam before you put it back together. (they don't need to be removed). And the FLAT end of the rubber bumper is against the front door. Good Luck !
Aug 30, 2007 | Electrolux Epic 6500 Vacuum
Stiga ST4100 Indoor Table Tennis Table Logo
187 people viewed this question
Top Stiga Sport & Outdoor - Others Experts
Are you a Stiga Sport and Outdoor - Other Expert? Answer questions, earn points and help others
