Question about Proform CrossWalk TreadSoft Treadmill
Sudden surges when running on the treadmill - Proform CrossWalk TreadSoft Treadmill
Power surging
sounds like the treadmill is drawing too many amps. try using a larger surge protector.
Feb 19, 2014 | Nordic Track NordicTrack C2300 Treadmill
When i get on the treadmill the belt stops all of a sudden
Try to tension the tredmill's belt. For that you need an allen wench. Watch the following video to adjust the running belt. All the treadmills uses the same way to adjust the belt.
Oct 10, 2011 | Reebok Vista Treadmill - RBTL13305
Tread mill wont turn on. it was on then while in use the screen flashed on and off then treadmill shut down and has not turned back on. tried reset button then unpluging for a while but still does not turn...
Dear Sir:
Thank you by your problem, I will help you inmediately.
Make sure that the power cord is plugged into a surge suppressor, and that the surge suppressor
is plugged into a properly grounded outlet . Use only a single-outlet surge suppressor
that is UL 1449 listed as a transient voltage surge suppressor (TVSS). The surge suppressor
must have a UL suppressed voltage rating of 400 volts or less and a minimum surge dissipation
of 450 joules. The surge suppressor must be electrically rated for 120 volts AC and 15 amps.
Important: The treadmill is not compatible with GFCI-equipped outlets.
2)After the power cord has been plugged in, make sure that the key is fully inserted into the console.
3)Check the circuit breaker located on the treadmill
near the power cord. If the switch protrudes as
shown, the circuit breaker has tripped. To reset the
circuit breaker, wait for five minutes and then press
the switch back in.
4)Check the on/off switch located on the treadmill
near the power cord. The switch must be in the on
position.
I hope you resolve this. Otherwise, try to reach me. Inmediately.
sincerely.
E.Cuadra
Sep 13, 2011 | Nordic Track NordicTrack Elite zi...
What type of AC adapter does the T790 ellictical machine needs also the voltage and polarity
Dear Sir:
Please read carefully:
Your treadmill, like any other type of sophisticated
electronic equipment, can be seriously damaged by
sudden voltage changes in your homeõs power.
Voltage surges, spikes, and noise interference can
result from weather conditions or from other appliances
being turned on or off. To decrease the possibility of
your treadmill being damaged, always use a surge
suppressor with your treadmill (see drawing 1 at
the right).
To purchase a surge suppressor, see your local
PROFORM dealer or call toll-free 1-800-366-7278
and order part number 14657. Use only a single-outlet
surge suppressor that is UL 1449 listed as a transient
suppressor must have a UL suppressed voltage rating
of 400 volts or less and a minimum surge dissipation of
This product must be grounded. If it should malfunction
or break down, grounding provides a path of least
resistance for electric current to reduce the risk of electric
shock. This product is equipped with a cord having
an equipment-grounding conductor and a grounding
plug. Plug the power cord into a surge suppressor,
and plug the surge suppressor into an appropriate
outlet that is properly installed and grounded in
accordance with all local codes and ordinances.
If you need Extra help please reach me inmediately.
sincerely. blessing.
E.CUADRA
MANAGUA, NICARAGUA .C.A
Sep 13, 2011 | Reebok Exercise & Fitness
Pro form 580 SI, power incline runs up as soon as it is plugged in and wont go down using console buttons.
possible it could be in incline senser but most likely the console needs replacing. you should always use a power surge protecter on a treadmill. power surges can blow out 1 resister on those circuit boards and there no good.
Sep 12, 2011 | Proform Exercise & Fitness
Reebok 5500C - when turn on treadmill and increase the speed, the motor has a sudden surge, for approx 1-2 seconds, then stops.
hi,
Replase the IGBT on the aluminium heat sink. this problem will be solved. Adde the photo of IGBT .
ajin_g_5.jpg ok
Mar 08, 2011 | Nordic Track Mc2100wa Treadmill Motor...
Will the treadmill work without the surge suppressor
Yes, it should. The surge protector is just to protect the electronics in case of a power surge.
Feb 21, 2011 | Icon Treadmill
I have an everlast folding treadmill and the machine starts fine but then it speeds up and and stops and the display say E1. I tried adjusting the belt but to no avail. Please help. Thank you.
if your everlast speeds up all of a sudden it is your speed controller and this is useally caused by you not lubricating under the walking belt, a dry belt will cause friction which causes the motor to labor harder and then over time your motor will over heat and cause speed problems,
or buy pluging your power cord directly into your out let the surges with cause your controlle board to fail over time u must plug the power cord into a 15amp surge protector with min 500 jouls and 1 plug at all times,
you should always have a anti static mat under the whole treadmill if your treadmill is on carpet static can de magnatize your motor, and static will be pulled into the treadmill
so when u step on your treadmill u become charged with static so every time you touch your computer console you are causing little charges to your console which over time cause the computer to male fuction,
also watch out for useing cheap exstention cords they will cause major damage to your treadmills electronics and motor they can not carry the proper voltage from the outlet into your treadmill so this will daMAGE YOUR TREADMILL ALWAYS USE A HEAVEY OUT DOOR THICK EXSTENTION CORD make sure it is 15 amps and a heavy gage and no longer the 10-15ft
the longer the exstention cord the more power you loose
Tim Ramsay
Lubeatread Inc
lubeatread@sympatico.ca
16 feb 2011
this goes with all treadmills
Jan 27, 2011 | Sport & Outdoor - Others
My Healthrider 400se Treadmill slows down after 10seconds
Use only a single-outlet surge suppressor that is
(TVSS). The surge suppressor must have a
and a minimum surge dissipation of 450 joules.
for 120 volts AC and 15 amps. There must be a
monitoring light on the surge suppressor to indicate
whether it is functioning properly. Failure to
use a properly functioning surge suppressor could
result in damage to the control system of the
treadmill. If the control system is damaged, the
walking belt may change speed or stop unexpectedly,
which may result in a fall and serious injury.
Jan 23, 2010 | HEALTHRIDER Pro H500i Exercise Workout...
Proform CrossWalk TreadSoft Treadmill Logo
11 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
