Old bose awrc1g wave radio cd am fm
Time is not being displayed
4 Suggested Answers
SOURCE: BOSE WAVE RADIO/CD
I've repaired about 10 type Bose AWRC3x (the radio/cd model with lift up lid and top controls). If the cd won't play or skips, try cleaning the lens VERY carefully with a cotton bud with some isopropyl alcohol. Let it dry then try again. This will help in about 1/3 of cases.
After that, a new laser unit is needed. They cost around 15 pounds,30 dollars, (Type SFP100s with 13 pin connector made by Sanyo). You need to have some electronics experience to take the case to bits to get the laser deck out, change the cd laser and reassemble. Basically, DISCONNECT THE POWER! Remove the 3 screws on top, turn over and carefully prise the front of the base away from the top cover with a table knife or similar. Lift off the top cover - be careful with the lid ribbon! The deck can be disconnected from its ribbon cable and wired connector very carefully. Take the deck to bits and fit the new laser head (take photos if you think it will help). Remember to unsolder the shorting 'blob' of solder which protects the new laser from static till its fitted.
On the bright side, there is no tracking etc to set up, that's all automatic so usually they work like new with a new laser fitted. I have to say this is the weakest feature on the Bose CD radio, the actual electronics rarely gives trouble.
Hope this helps Steve O'Donnell
Posted on Mar 20, 2008
BillB-SA
  • 2761 Answers
SOURCE: no power
Unfortunately Bose will not release their schematics or parts lists, effectively giving them a monopoly on repairs. Their web site, www.bose.com, offers to repair most Wave radios for $100 or to give owners of broken sets a $200 allowance towards the purchase of a new Wave. Before spending the big bucks though, you might want to check out the new HD radios. Better sound and a MUCH lower price.
Posted on May 21, 2009
  • 137 Answers
SOURCE: I have a Bose Wave radio AWRC-1g. The CD player
Yes you have a defective laser assembly. The 139 is a great price as buying the laser lens alone will cost you around 70 .Bose will also upgrade with any new software and will also provide you with a 1 yr warrenty.
Posted on Apr 16, 2010
How do i repair the cd player on my bose awrc1g radio cd player
Hi Susan
As there are no user serviceable parts inside your unit, your best bet would be to contact Bose directly. This is likely best left to the pros, especially if the unit is still under warranty.
Here's the link to your owners manual, service centres are on page 29.
-Steve
https://www.bose.co.uk/GB/en/images/owners-guide_Wave-Radio-CD_AM250723_05_tcm6-57006.pdf
Jan 19, 2015 | Bose Awrc1g Wave Radio Cd Player Only -...
Cd carriage does not always load cd properly
Yes,as rightly suggested,dirts can cause the optical lens to reject some CDs.Use a a CD cleaner to clean the optical lens.If the problem persist,then you will need a qualified service personel to replace the lens.
Apr 07, 2014 | Bose Awrc1g Wave Radio Cd Player Only -...
Bose wave radio cd does not power on--nothing!
This obviously is a power problem which can be handled only by a qualified service personnel.
Feb 17, 2014 | Bose Awrc1g Wave Radio Cd Player Only -...
Bose wave radio cd won't play cd's
If your CD is not scratched,the optical lens need replacement.
Apr 02, 2013 | Bose Awrc1g Wave Radio Cd Player Only -...
AWRC1G Bose radio/CD I have....when I turn on there is nothing but a tremendous screeching sound and thats all I hear.
I know this is an old post, but more likely than not you have a liquid damaged unit. This is very common and symptoms such as that which you describe are the result. We service hundreds of these units with great success. CET Services, 117 Windsor Ave., Hurley, WI 54534 // don.miller60@outlook.comS2XL9M
Aug 23, 2012 | Bose Awrc1g Wave Radio Cd Player Only -...
Bose radio awrc1g only static like there is no antana. Works some times. CD works fine.
Mine did the same thing. I took the cover off and took the radio apart. I discovered the FM/AM tuning crystal was separated from the mother board (soldering failed). Anyway, when figured out where the crystal went I reinserted it and it worked great. I considered gluing it back in but opted to test my soldering skills and it worked out just fine. The crystal is a small silver electrical component with 2 prongs that plug into the motherboard.
Good Luck.
Oct 20, 2009 | Bose Wave Radio
My bose wave system will not turn on.
There's a line fuse inside the radio, mounted on a PC board. CAUTION: disconnect the set from power before opening the case or poking around inside. The fuse could be bad, but these sets are notorious for losing the power transformer. If the fuse is ok then you are looking at a $100 repair fee from Bose. You might want to check out the new HD radios -- better sound, MUCH lower price.
Bill B.
Nov 15, 2008 | Bose & Wave& Music System
No power
Nov 11, 2008 | Bose & Wave& Music System
 Grubhead
Grubhead
