Question about Emerson Televison & Video
How do i connect ha-w600rf-j/c wireless headphones to a tv with cable without a cable box
Audio output to tv without using the cable box to connect it for sound
  • 3 Answers
SOURCE: Sound problem with Sharp LC-32D4U
I got the sound on my LC32D6U fixed for free. Even though the TV is out of warranty, Sharp considers it under warranty for the sound problem. The number i 800-237-4277.
Posted on Jun 26, 2009
  • 7 Answers
SOURCE: LG 42PX4DV - HDMI Audio / PC Audio IN problem
one quick fix you can try. plug in the HDMI cable, slect a digital audio sound output from the sound settings on your machine, then leave it connected and restart it. It just might work.
Posted on Aug 05, 2009
JollyRoger00
  • 59 Answers
SOURCE: Digital Audio Output Problem
connect the optical line from the DTV box to the audio system directly.
Posted on Sep 24, 2009
Warf135
  • 137 Answers
SOURCE: When I use the headphone output jack (to drive a powered subwoofer), the default internal speaker audio output is disabled, leaving me with only the subwoofer output. How can I use both the internal
Your best option is to use a seperate amp with sub output from the audio outputs on the back of your TV. use this amp to power the sub and a good pair of speakers, and you'll have quality sound.
It is possible to prevent the TV's internal speakers from cutting when you use the headphone socket, but it means going inside your TV, and if your not skilled, you can easily blow your TV (and yourself) up. You just need to re-wire the headphone socket on the TV to stop it cutting the internal spaekers.
Posted on Oct 06, 2009
SOURCE: Does the LG 42LH30 (HDTV) have an auxilary audio output?
I can't find the RCA jacks the last guy referred to on the LG 42LH30. The only out I can find is an optical out, and I need RCA outs for the new wireless headphones I just bought
Posted on Feb 19, 2010
What are connections and connectors for audio output to wireless headset
Hi Richard,
First, you'll need to determine which type of input(s) the wireless headset transmitter has. Most common is the 3.5mm stereo plug designed to slip into the headphone jack of a TV, MP3 player, cell phone, etc. Some transmitters have adapters in the box to allow connecting to the Left and Right channel RCA / phono style jacks found on other components such as CD, DVD, VCR, Stereo receivers / amplifiers, etc.
You'll need to find OUTPUTS of the CD and TV that match the plug on the wireless headset transmitter. If yours doesn't include adapters to go from say the RCA jacks mentioned above - to whatever connector that the transmitter input has - you'll need to go to your local Radio Shack store or similar store to see if they can provide an adapter that will allow you to connect.
Here are a couple plugs / adapters:
Above: A "3.5mm stereo patch cable". Your transmitter may have a cable with an end like this to plug into the TV's headphone jack.
25683604-gy4zxbmnj5ndu14q12lmwneo-2-1.jpg Above: A "3.5mm female stereo jack to RCA stereo male plug" adapter that would allow the top cable to connect to the Left and Right audio output jacks on a typical CD, DVD, etc. device.
These cables / adapters are typically $5 to $10 maximum.
I hope this helps and good luck!
May 07, 2015 | RCA Televison & Video
How can I hook up wireless headsets to direct tv box?
You must have wireless transmitter provision in your TV,to get connected to Headset.
Or you may buy suitable external wireless transmitter and connect it to your TV ,audio output and receive audio,in your head set.
May 03, 2014 | Sony Audio Players & Recorders
Connecting a set of headphones to TV and maintain sound on speakers
since we are talking audio go radio shack and get a splitter cable
Jan 12, 2014 | Panasonic TCP42U2 4 in. TV
Sylvania wireless headphones
Instructions
Set up the transmitter. Wireless headphones rely on a transmitter that sends audio via infrared or radio waves to your headset. Use the digital audio output (coaxial or optical), RCA outputs (red and white) or headphone jack on your TV to connect the transmitter. The connection will depend upon which outputs are available on your TV and/or the transmitter.
Use an RCA-to-headphone adapter. If you don't have a headphone jack on your TV and the transmitter includes only a headphone connection, connect an RCA-to-female headphone connector. This will allow you to plug the wireless transmitter into the female headphone end and then hook the RCA ends into your television's audio outputs. You may also need a 3.5 mm (mini jack)-to-1/4-inch adapter if the headphone plug on the transmitter doesn't match the television jack.
Read more : http://www.ehow.com/how_4883556_use-wireless-headphones-tv.html
Set the transmitter on top of, or next to, the television. For infrared transmitters, you'll need a direct path between the headphones and the transmitter. Placing the transmitter on or near the TV will allow you to take advantage of the clear path you already have.
Plug in the transmitter and turn it on. Charge the headphones if necessary.
5
Turn on the headphones. Adjust the volume and settings and you're ready to watch TV.
good luck
Nov 14, 2013 | Sylvania SYL-WH930GB Wireless Headphones
Sennheiser 126 connect to tv
You should be able to hook the tv to the cable box the cable box should have your A/V jacks. If so unplug the PS3 plug in your receiver to the cable box and run the PS3 through the receiver. Also check the side of the tv for HDMI inputs if you have HMDI you can go to Radio Shack and get a converter to go from HDMI into A/V
Nov 07, 2013 | Sennheiser Audio Players & Recorders
I have a set of T 912 wireless headphones. I am unable to set them up on the TV. I am using the white and red cables from the base station to the TV audio red and white. Do you have any instructions on...
The audio jacks on the TV are most likely inputs, not outputs. They're meant to take the audio signal from something like a DVD player, along with the video input on another jack, so you can play it through the TV. There isn't an audio signal coming out from those jacks, and if you connect your headphone transmitter to them all you'll get is silence. Almost all sets now have at least one set of AV inputs, but most don't give you outputs. The manufacturers figure the TV is just a display device, and not a signal source.
Unfortunately, there isn't any easy way to connect your wireless headphones if the TV doesn't have audio output jacks or a headphone connector. If you're comfortable with soldering and willing to do some modification to your TV, it's possible to add a headphone jack. Most people don't want to start tinkering with their sets, though.
If you're using your TV on a cable system without a converter box and the cable hooks right to the set, you're out of luck unless you're willing to add a headphone jack as I mentioned before. But if you have a cable converter box, or you're using a satellite receiver or other set-top box, you can use your headphones with those. These devices typically have direct audio and video outputs available on the rear panel, and you can use that audio output to feed the headphone transmitter.
What most people do these days is use a home theater receiver along with the TV. All sources (the cable box, DVD player, video game console, audio CD player, etc.) connect to the receiver, and the receiver's audio and video outputs go to the corresponding input jacks on the TV. This way, the TV is just the end of the line. The receiver also would provide an output for the wireless headphone transmitter. This system offers some advantages. You'll be able to connect the proper speakers to enjoy surround sound when not using headphones. And you'll be able to use your wireless headphones with the tuner and audio sources like music CDs when not watching TV.
Aug 14, 2011 | Audio Players & Recorders
I connect my Beyerdynamic DT131 wired headphone to my Sony Bravia TV through the cable box, audio volume is extremely low and the headphone's volume control had no effect on the volume. I tried connecting...
The audiolevel is much to low for a headphone.
You really need to use a headphoneoutput ( if its there) or a headphoneamplifier.
You tried to connect your headphone on line-level outputs.
Regards,
Gerard
Apr 23, 2010 | Beyerdynamic DT 100 Professional...
My Proscan 32LB30QD does not have Audio Out! Is there a way to connect a wireless headphone to this TV?
You can either see if your cable box (if you have one) has RCA outputs on the back or if you are using some sort of a VCR or DVD it should have audio outputs on the back. The only problem with the latter hookup is that you have to turn the vcr on if you want to hear thru the headphones.
Aug 07, 2009 | Proscan 32LB30QD 32 in. LCD TV
Televison & Video Logo
35 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
