Question about Whirlpool Cabrio WTW6800W Washer
Whirlpool Cabrio WTW5500XWO Washer
Washer gets stuck in wash mode and will not spin
jsrock516
  • 5911 Answers
SOURCE: Cabrio washer is giving an F 51 Code
The "F51" error code is common problem with the Cabrio. This is an RPS sensor error. The sensor is mounted along the motor windings under the washer and detects the rotation spin speed. The sensors on these units can go bad, causing the error code, and it has been a frequent problem. I would recommend you contact Whirlpool first (due to the unit only being a year old) and see if there is a recall or upgrade on this part. I believe there is. The repair would then be covered by the manufacturer. If I give you the steps to access and/or replace the sensor at this point, you may be voiding any existing warranty you may still have. Some components carry a longer warranty than your normal one year limited warranty from the manufacturer. Something you may consider.
If you have further questions, please let me know. I hope this helps you in some way.
Posted on Jun 11, 2009
  • 39 Answers
SOURCE: Whirlpool washer grinding noise when draining
there could be something in your pump.....remove the pump and see if there is not something inside...
Posted on Jul 04, 2009
Nicesuit
  • 61 Answers
SOURCE: I have a Whirlpool Cabrio washer (WTW6400SW). It
try cleaning the dispencer first, it has a small syphon assembly in it whcih can get blocked with concentrated fabric softiner and sometimes powder.
Posted on Jul 30, 2009
57 varieties
  • 1653 Answers
SOURCE: washer whirlpool cabrio message code f50,washer
F50 - This is a motor stalled failure. If this persists you will eventually need to call in a service engineer to repair it as the machine will eventually stop working altogether.
Posted on Oct 02, 2009
  • 180 Answers
SOURCE: Whirlpool Cabrio top loading washer F1 Error
F1 means the control board is shot. Call whirlpool and they should take care of the parts and labor even though your machine is out of warranty.
Posted on Nov 27, 2009
Why is my washer stuck in the spin cycle
hi
this might be too obvious but did you try to unplug the washer for at least 5 min to completely reset the computer in the washer ?
Jun 08, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool cabrio washing machine doesn't spin
Try to turn the drum by hand, if it hard to turn, there may be something stuck underneath spin basket. If it does turn freely but makes a loud growling sound, you probably have a bad bearing. You should notice black oil and water mixture at bottom of washer, on the rotor. It will usually throw a f51 error code. This unit has service bulletin on this problem.
Apr 05, 2014 | Whirlpool WTW6400SW Cabrio Washer
CABRIO WTW5500XWO
Make sure that the water is turned on. Carefully under the main control panel if you lift it up when the water should be on you should hear the water inlet solenoids clicking on then off, if not make sure that the wires are connected UNPLUG FIRST BEFORE TOUCHING ANY WIRES
Dec 28, 2013 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool washer cabrio stuck on spin cycle
solution- ID- is in the control program and the door lock. If, there is any warrenty on it, call Whirlpool and a Tech can help you with it.
Sep 10, 2012 | Whirlpool WTW6400SW Cabrio Washer
Whirpool washer cabrio
You can check the drain or the filter. You will have to pull it out of the space it is now to access it. Items will get stuck in the drain clogging it.
Dec 16, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6800W Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
