Question about Maytag Washing Machines
My maytag lav3600 aww leaks when it fills. It is leaking from underneath the tank. As soon as it starts filing it leaks. Any advise?
    Champion:
  • 219 Answers
Your main seals are probably bad advise to buy new
Posted on May 22, 2009
As soon as I put coolant in the reservoir tank it drains out but cant see where its going and the ground is wet WHAT COULD BE THE PROBLEM?
Sounds like the tank has a leak, remove the tank and inspect, you should be able to see if its wet underneath.
Mar 08, 2015 | Saturn 2001 SL1 Base
Krups water leak
It could be the seal where the tank engages. I would remove the bottom and prop it up so I could see underneath it and then engage the tank and see where the water is coming from. Sometimes putting it over a mirror and having a torch on hand can help you see deeper inside while it is leaking.
Jan 13, 2014 | Krups Gusto 880-42 Espresso Machine
Husqvarna model 357XP chainsaw leaks oil all over as soon as I fill the tank. Any solution? Never leaked until now.
You need to find out where its coming from, drain the oil tank and re fill with some fuel, as this is much thinner it will leak out much faster and give you a better idea where its coming from, it may be just the pipe up pipe behind the pump has got hard and started to leak, the other possibility is the crankcase gasket, if this is leaking it is a full strip down to fit a new gasket.
Oct 23, 2011 | Garden
My Maytage icemaker just started leaking. It is not overflowing as many of the answers here suggest. As soon as the ice dumps, and the tray starts to fill, the water pours out of the bottom front of the...
Check to see if it is level - left to right and front to back. Make sure the mounting screws are tight. If it still leaks, I would replace the icemaker.
Oct 28, 2010 | Maytag Refrigerators
When I fill my truck with fuel, gas leaks from underneath chassis
under so circumstance should it leak out. Either the filler neck is leaking or the seal for the fuel pump. You will need to lower the tank to check it out.
Jul 30, 2010 | 2001 Ford Ranger Regular Cab
We think the seal underneath the machine is leaking, is this hard to fix?
If this is a top load washer it is probably no the seal more likely one of the hoses either the fill hose or the drain hose ineither case this are not that hard to fix. If it is a maytag newer style there is a common leaking problem upon filling and it is usually the fill line that is leaking.
Jan 13, 2010 | Washing Machines
Maytag MDBH950AWB Leaking
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
zgwerty
Feb 23, 2009 | Maytag 24 in. MDBH950AW Built-in...
MAY8700AWW LEAKING WATER UNDER DOOR AND S/B/F DISPENSER
Service came out to check out my washer. He sent it thru the wash cycle and it started leaking. He removed the top and checked the hose that leads from dispenser to tub. What he found was the round piece of paper from the clorox top which had dropped into the dispenser apparently when I poured clorox into the dispenser. Which was causing the dispenser to backwash underneath and flow down like it was coming from underneath the door. Thank God I have an extended warranty. I advise everyone who has the newer digital models to purchase an extended warranty. It is worth it....the repair can be costly from what I understand.
Jan 16, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washer leaks from bottom as soon as it starts filling with water
There are 2 green clips between the top of the unit and the front panel. (you can use a flash light to find them easier). Push on the with a putty knife or small flat head screw driver while lifting on the top. Once the top is open, you will find 2 5/16 screws that hold the front panel on at the top on the right and left hand sides. Once these are removed, you can tilt the front panel forward and see where the water is leaking from.
May 31, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machines Logo
1,052 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
