Question about Mitsubishi Diamond Plus 71 (White) 17" CRT Monitor
Mitsubishi Diamond Plus 71 monitor that won't power up
I have a Mitsubishi Diamond Plus 71 monitor that will not power up. I checked the power source but the on/off button will not light or latch when depressed. Any manuals or schematics available for this monitor? Any assistance or recommendations would be appreciated. Thanks, Kirk
4 Suggested Answers
ButtFuzz
  • 463 Answers
SOURCE: mitsubishi diamond pro says "no signal"?
You have tried the monitor on more than one known good computer, yes?
I believe about 4" inside this monitor in the back the vga cable or connector connects to a board with an in-line connector. Can you see if this connector (internal to the monitor) in connected?
Good luck...
Posted on Mar 02, 2009
  • 11800 Answers
SOURCE: Power button won't latch on. Monitor powers up if
Replace the  power switch. If you can't find a replacement part open the case and solder the connections of the switch so they will be permanently on. You can place a new switch on the power cable.
Posted on Nov 26, 2009
  • 56 Answers
SOURCE: Color temperature for the monitor
I have mine on 9300K. The whites seem whiter to me rather than the yellowy tint at lower temps.
Posted on Nov 27, 2009
Power button won't latch on. Monitor powers up if button kept depressed.
Nov 26, 2009 | Mitsubishi Diamond Plus 91 19"
Monitor Does Not turn On...
My Friend you have a problem in the power supply, you try voltage check, check if you have output in the b+. if nothing, there is a regulator in power section, for example ic401, you look at the board you will see all the components section of ic401, all the capacitor have 4 for example c423 or resistor r423 like that one. You check all the section of the power supply. Hope I help you. bye
Mar 20, 2009 | Apple Mitsubishi Diamond Pro 2060u 22" CRT...
Screen goes to single horizontal line across middle, sometimes momentarily at first, then resets after being switched off for a period of time (can take minutes, hours or even days) Model: NEC Mitsubishi...
  • Complete service manual with an error search tree , sometimes there is a vertical ic defect by deformed capacitors hanging around that or a powerline from powersupply failed (sometimes there could be a defect fuse resistor to find ) or only a bad factory cold soldering by manipulate some passive components somewhere in vertical stage .
Mitsubishi Diamond Plus 93SB Service Manual
May 06, 2017 | NEC Mitsubishi Diamond Plus 93SB 19" CRT...
Mitsubishi diamond pro says "no signal"?
Good luck...
Mar 02, 2009 | Mitsubishi Diamond Plus 100E Monitor
Nov 12, 2008 | Mitsubishi Diamond Plus 91 19"
Monitor keeps switching off
The graphics card or onboard graphics driver may not be kicking in at boot up causing the monitor to shut down, check the graphics card connector for bent pins and both connector ends. If you are able, think back to when this started and use system restore to a date before is started. Also you may have inadvertantly updated your graphics driver with one of windows generic drivers, of which may be the cause. You can also try pressing F8 on boot up and selecting 'last known good configuration' and see if that cures it.
Mar 18, 2007 | NEC Mitsubishi Diamond Plus 92 19" CRT...
Mitsubishi Diamond Plus 71 (White) 17" CRT Monitor Logo
Top Mitsubishi Computers & Internet Experts
Coss
Shaukat Bhutto
Level 1 Expert
Matthew Spark
Matthew Spark
Are you a Mitsubishi Computer and Internet Expert? Answer questions, earn points and help others
