Question about Garden
Micronta manuals I have a micronta 22-027B and no manual. I need to know where to plug the leads. Unlike the 22-293A there is no 'common' socket.
2 Suggested Answers
hunter19_46m
  • 7482 Answers
SOURCE: I need a manual for
Hi racqbell...
Go to the following webpage and download your user manual for the Micronta 22-185 multimeter.
Please take time to rate me
http://www.pdfph.com/pdf/free-micronta-22-185a-manual/
Posted on Aug 18, 2011
Need manual for Radio Shack MICRONTA 63-3003 VLF Metal Detector
Go to http://www.scribd.com/doc/38611721/63-3003-Micronta-VLF-Metal-Detector-Manual
Sep 23, 2012 | Vehicle Parts & Accessories
Which cords and/or plugs should I use inorder to connect a projector to a computer
if your desktop doesn't have a standard vga socket then you can get a dvi adapter that fits onto the end of a vga lead. you will still need a seperate cable for audio as a dvi connection only does video.
Aug 02, 2012 | Computers & Internet
I need a manual for a Micronta 22-185A multimeter online.
Hi racqbell...
Aug 18, 2011 | Garden
02 VW Jetta TDI with ALH engine glow plug
this is a common problem for these cars glow plugs go bad like spark plugs however the smoke would lead to bad mass airflow meter. it is not telling ecu corrcet miss. disconnect mass airflow meter. when cold see if this makes it start better. it should would means you need new m.a.f. glow plug issue take a test light place clamp on positive of battery then pull off glow plug connectors place tip of test light on glow plug the bad one will have a dull light unlike the good one which will be brighter. will need new plugs and wire harness four **** connectors and wire striper and crimper will fix concern good luck
Sep 01, 2009 | 2002 Volkswagen Jetta TDI
Cans in my engine
The MAF (mass air flow sensor) is a common problem on this car. I had a mechanic change mine for $300 you can do it yourself for $100. It is the big "box" right after the air filter.
Can't be sure it is the problem, but my car had pinging, rough idle, and it would heat up.
Another common problem are coils - this usually has the check engine light one (unlike above). Some dealers want to charge you $600 for parts, and $240 to install them, but if you shop around/bargain you can get them for $350 and install yourself in less than 30 minutes. They sit right on the spark plugs (see your owner manual for under spark plug change). You pull them off and then disconnect from wire by pushing the connector with a screwdriver where there is a little arrow. Very simple and quick. The dealer also wanted to charge another $120 labor for changing the plugs (even though it slightly harder than the coil - need a spark plug socket which most DIY have). I did both in 45 minutes and saved $360 in labor and over $300 in parts! You don't get greasy and grimey like fluid changes!
Good luck.
Jun 24, 2008 | 2000 Nissan Maxima
Can't re patch tv with set top box to watch tv
Hi.
Ok here goes.
1) Take airial lead from the wall socket in to antenna in on freeview box.
2) connect short usually black airial type lead in to antenna out socket on freeview. plug the other end of this lead in to aerial in on vcr.
3) connect the other end of this aerial type lead to airial plug on the back of tv.
4) now if you have 2 or more scart sockets on the back of tv set plug in the scarts in this order.
Freeview box scart with tv on it connect to scart 1 on tv set.
Freeview box vcr scart connect to vcr in scart socket on vcr.
Vcr scart marked tv plug scart from here to scart 2 on tv
If you have 3 scart sockets on tv you can connect dvd using scart to scart socket 3 on tv.
If Tv has only 1 scart the aerial leads will stay the same as I have stated,
Freeview must go to scart socket on tv set.
leave second scart from freeview to vcr plugged in so you can record freeview by putting vcr to line 1 or AV 1.
you will need to put tv on channel (0) & tune this channel to the video play a tape that you recognise then go to tv tuning & tune tv untill you see video playing then store this on channel (0).
DO NOT USE AUTO TUNING IT WILL PUT CHANNELS IN THE WRONG ORDER JUST USE MANUAL TUNING.
Now to view Dvd you will either need to purchase A scart switch box. Or have keep unpluging freeview scart from tv so you can plug in dvd .
If your tv has red yellow white phono sockets you can plug dvd in to these, you may need to purchase phono leads.
Hope this helps.
http://dysonmanuals.llc.nu/
Chris..
Jan 08, 2008 | Televison & Video
Garden Logo
235 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
