Dreamer alarm clock manual - Audio Players & Recorders
How to raise and lower the volume on the alarm on a model 4248 alarm clock
BRIAN, DID YOU GET A MANUEL WITH YOUR CLOCK-RADIO LOOK IN IT OR CALL MANUFACTURE CUSTOMER SUPPORT
Jan 21, 2016 | Audio Players & Recorders
Brookstone Model cks 2022 Alarm clock radio Instructions
I searched on your product name and found an instruction manual for a Brrostone self-setting alarm clock radio:
http://www.brookstone.com/webassets/pdf/607960p_manual.pdf
Apr 23, 2014 | Brookstone SmartSet Alarm Clock
I just got a Memorex Digital CD Alarm Clock with no manul the modle number is MC 7101. I'm not able to set the clock or alarm. I just need the instructions.
To set the clock:
1. With the power off, press the TIME button; the time will blink.
2. Press the MINUTE button to set the present minute and the HOUR button to set the present hour.
Make sure to set the correct AM/PM setting.
3 Press the TIME button (or wait approx. 15 seconds) and the time will be set.
To set or reset alarm time:
1. With the power off, press the desired ALARM, Press and hold the desired ALARM 1 or ALARM 2 button; the alarm time will blink. The Alarm 1 or Alarm 2 time and settings will appear.
Press the MINUTE button to set the alarm.
2. Press and hold the desired ALARM 1 or ALARM 2button; the alarm time will blink.
Press the MINUTE button to set the alarm minute and the HOUR button to set the alarm hour. Make sure
to set AM/PM setting. Press the ALARM 1 or ALARM 2button again (or wait approx. 15 seconds).
3. Repeatedly press the ALARM 1 or ALARM 2 button to select alarm off, alarm on, for buzzer, radio or CD.
If you needed the manual it could be downloaded:
http://www.retrevo.com/support/Memorex-MC7101-Clock-Radios-manual/id/1081dj880/t/2/
Thanks.
gylacz
Aug 01, 2011 | Memorex MC7101 Clock Radio
I cant find an online manual for an audiovox CD alarm clock radio model 1167, and cant figure out how to set the alarm. a link to the actual manual would be great
With the power off, push the alarm 1 button, then push the clock set button. Use the skip & preset buttons to set the hour. Push the clock set button again to change to the minute. Again use the skip & preset buttons to set the minute. Push the clock set button again to set. You will see an alarm clock in the upper left of the screen to show the alarm in now set. To cancel push the alarm button and then the stop/alarm off button.
Mar 09, 2011 | Hardware & Accessories
Alarm clock GE model no. 7-4894A but no manual
You can down load the manual on link below for free.
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000045591.pdf
Good Luck and please rate 4 thumbs up for the free answer.
Apr 29, 2010 | GE 7-4894 Clock Radio
Cant turn off alarm on RCA alarm clock model 3715A
Closest available RCA CD-CLOCK RADIO USER MANUAL online is for Model #RP5610 at this location: http://www.voxxsupport.com/images/manuals/RP5610/media/RP5610_DOC_OM.PDF
It is almost exactly the same model as the #3700 series.
If unable to link to that webpage, go to RCA Tech Support page at: http://support.rcaaudiovideo.com/manual.aspx?product=143 and click on download manual.
Nov 05, 2009 | RCA Radio Alarm Clock
Instruction manual for a Tevion clock radio
how to set the alarm on Tevion fm/am digital alarm clock
Oct 23, 2009 | Audio Players & Recorders
Set Clock
This clock has 2 alarms to set Alarm 1, switch alarm 1 to the "set" position and make sure alarm 2 is pushed to the "off" "radio" or "cathedral" position, press and hold the "alarm" button on top while pressing the "f.fwd" or "rev" button to set the alarm....to set Alarm 2, do the opposite of the set buttons and repeat...to set the time just hold the time button down while pressing "f.fwd" or "rev"...hope that wasn't too confusing.
Jan 01, 2008 | Timex Nature Sounds LED Clock Radio
Alarm Clock
The manual can be downloaded from the RCA site:
http://support.rcaaudiovideo.com/manual.aspx?product=217
Oct 13, 2007 | RCA Mini CD/Radio Alarm Clock System -...
167 people viewed this question
 Grubhead
Grubhead
