Question about Mitsubishi WD-62525 62" Rear Projection HDTV
No sound TV was just returned from being serviced for a bad capacitor and now we have no sound, any thoughts on how to fix this?
  • Anonymous May 23, 2009
    the tv all of a sudden has no sound the picture is still great though
  • 64 Answers
Ask service person what the capacitor fixed? Did he/she verify full operation before returning, including sound? Did he/she remove any speaker wiring during the repair process? If so, he/she may not have re-connected all the cables. Assure the tv is not in "mute" mode or has the volume set to zero.
Posted on Aug 01, 2009
I am looking for the complete repair kit for a samsung 51 inch plasma tv model number PN51D490A1DXZA.
Samsung LCD / Plasma TV Capacitor Repair Kit ...
www.amazon.com > ... > Capacitors
Amazon.com, Inc.
Rating: 4.4 - ‎86 reviews
Samsung LCD / Plasma TV Capacitor Repair Kit, Replacement Parts: ... 1-220uf 25v; 4-2200uf 10v; 6-1000uf 25v; 6 Inch Solder and Solder Wick; Cleaning Swabs ... pump + Solder wire + Solder wick + CAPACITORS Replacement)-COMPLETE KIT ... In my case, the OEM capacitors did not look bad, but I replaced them all ...
Samsung PN51D530 Plasma TV Repair Kit, Capacitors ...
Amazon.com, Inc.Samsung PN51D530 Plasma TV Repair Kit, Capacitors Only, Not the Entire ... Save on the full line of Powerblanket heating solutions. ... and 8 inches of 0.1 inch (2.5 mm) copper de-solder wick are included in the kit. .... Made Easy · Look.com
EASY MOST COMMON TV REPAIR EVER!!! - YouTube
? 13:13
https://www.youtube.com/watch?v=SXqSg2A5b7I
Jan 6, 2012 - Uploaded by Tampatec
Must See TV FIX EASY COMMON Samsung TV Repair Repairing LNT LCD PLASMA TV FIX SERVICE VIDEO TUTORIAL ... if you go to get tv repair kit- http://tampatec.blogspot.com/ easy ways .... The YSus/Zsus boardlook to be ok but I'm wondering if I need to replace the YSUS board> Any thoughts?
Jan 05, 2016 | Samsung Televison & Video
Sanyo 52 comes on10 seconds and goes off
i am afraid to say, that the fact it comes on for a few seconds and then off is an idication of a bad capacitor, the heat from the tv is why it shuts down, a capacitor is bad. do you have a warranty? i am possitive this is your problem. if not the only thing is to default your settings to factory settings, but sadly this sounds typical to a shut down on such a tv like this. not saying its a bad tv brand but this is a typical problem and they only thing that causes such a problem is that over heated capacitor. the tv is not bad, the capacitor is bad, the tv is not getting to hot the capacitor is. if you can afford to get that fixed your going to be ok, not to sure how much this will cost, but on the back of your tv is a USB like service port that a service man plugs in a tester to see what the problem is. try this and se if that is what is wrong before throwing a nice tv out. hope i helped you.
Nov 15, 2012 | LG 42LC2D 42 in. LCD HDTV
Proscan 42LA45H has picture and no sound
Good day!!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Jun 05, 2012 | Proscan 42LA45H 42 in. LCD TV
I have a technika flat screen / dvd player bough in April 2009. The TV green light will come on with both the remote and the button on the side of the TV however I have no picture or sound, just a black...
Chris, the problem could be almost any where. As a TV servicer, my course of action would be to test the voltage in the power supply. I would look for a bad capacitor in the power suppy. This capacitor may be bulged or skinned. You will need an ESR meter to locate a bad capacitor. A bad capacitor may look fine, when it is not. I have not worked on this model, I would certainly start with the power supply. Hope this clues you into a fix.
Jul 04, 2011 | Televison & Video
TV Turns on picture comes on for 30 seconds then picture goes off and sound stays on. Even after leaving tv on the sound stays but the picture does not come back on. Its a westinghouse SK-32H540S
This is not the fix for this TV. I guarantee that none of the capacitors exhibit the common bulging characteristics of a faulty capacitor. The common answers to everyone's questions are to replace the capacitors. Most likely the culprit is the inverter board.
Feb 26, 2010 | Westinghouse SK-32H540S 32 in. LCD TV
My Samsung LNS4041DX/XAA is starting to take forever to turn on. Today it took around 2-3 minutes to finally turn on. It has always been a little weird to turn on and now it is near the end of the warranty...
I just fixed this very same problem. It is true that the capacitors are the problem. However, I think that if you have some minimal skills with soldering, you can fix this yourself. You just need to take out the system board, then the power supply parts are on the top right. The bad capacitor(s) will be bulging at the top and possibly have some brown stuff coming out. The ones that go bad are 1000microfarad, 10V, however you can replace them with higher voltage. I got 35V caps from radio shack for 1.59 each. You just need to solder out the bad ones and then put the new ones in and solder. Remember that the negative end goes on the side with the bold black part of the circle on the system board. Then just cut off the extra ends of the capacitors. If you are capable of doing this yourself, you will spend at most 6 dollars instead of however much a technician costs.
Sep 13, 2009 | Samsung LN-S4041D 40 in. LCD HDTV
Screen is black even though the green light is lit
Tv has power supply board inside defective. This board needs replaced.
Aug 18, 2009 | LG 32LB9D TV
Green power light blinking all the time on TV
After changing a defective capacitor, my TV still would not power up. After using a solution I found on this site, I held the power and volume up button down on the TV itself for several seconds, the TV powered up normally. I did notice that you had to do this while the timer light was flashing. Doing so after it went out was not effective. I initially only replaced one capacitor which was noticeably defective, and the flashing green timer light eventually returned. I will be replacing all 7 capacitors and resetting the TV. As mentioned above, the capacitors may look good but in fact may be defective. These are high temp caps which breakdown under a load but function normally when cold. Several people have mentioned replacing the capacitors didn't fix the problem. It appears that you must replace and reset using this method to repair some of these TVs.
Jun 06, 2009 | Mitsubishi WS-65615 65" TV
No sound on TV
Don't know the exact model you have, but generally when the capacitors are replaced, many CABLES ARE UNPLUGGED and RE-PLUGGED in the process, including the speakers. Have someone check the speaker connections. Also be sure the tv is not in "mute" mode or the volume is not set to zero.
May 17, 2009 | Mitsubishi WD-62525 62" Rear Projection...
No pic, no sound
The inverter is bad. Sometimes the logic will go bad due to 3-4 bad capacitors. www.lcdrepair.us will fix the unit for $59 and has a large selection of DELL Parts.
Dec 16, 2007 | Dell W1700 17 in. HD-Ready LCD Television
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
47 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
