Question about Mitsubishi WS-55859 55" Rear Projection Television
Out of focus
Greetings, I have an 8 year olf Mitsu 55 inch rear projection TV. Recently it began intermittently, now consistently, having red and gren double images particularly out towards the sides. The image is better in the middle, but distorts as it move to the sides. I suppose that one or more of the projectors is out of line. Can this be fixed. Thanks----------------Mark W.
    Champion:
  • 205 Answers
You have a convergence problem, probably the convergence electronics are going out or the TV has been violently moved and needs a mechanical alighnment. Small adjustments can be made from the menu.
Posted on Jul 07, 2009
I have an 8 years old rear projection TV. Try to
May be a short. Contact tvrepairkits.com and see if they help diagnose it further.
Feb 19, 2010 | Televison & Video
Blue color bleeding
the color issue is most likely the crt coolant needs to be replaced you can get the phillips CRT coolant replacement kit at the following link which contains the coolant and the instructions on how to do the replacement.
http://servicemanuals.vstore.ca/
The crack you hear could just be the speakers or a intermitant ground problem in the audio circuit more likely the spealers if its only on strong Bass
Apr 03, 2009 | Philips 55PW9363 55" Rear Projection...
My 55 inch Toshiba Projection TV is getting fuzzy.
try to adjust the focus from the back inside the tv it may be out of whack because of the focus
Nov 26, 2008 | Philips 55P8241 55" Rear Projection...
Fuzzy Rear Screen Projection TV
Probably the EHT unit is failing or the Focus Control is out of adjustment or if it gets worse as the brightness increases, may need a new TV.
Apr 02, 2017 | Televison & Video
55 inch Philips
I have 50" philips magnavox big screen. I recently started to have a problem with the edges of my tv. They became blurry. the center of the tv is clear and the edges are blurry. what should I do to fix this problem.
Sep 06, 2008 | Philips 9P5034C 50" Rear Projection...
4 pin or 6 pin
It has neither. It is not firewire capable.
Jul 17, 2008 | Mitsubishi WS-55411 55" Rear Projection...
No red in picture
It could be a dry solder joint on the base socket pcb. Try resoldering the base socket, and try for dry joints on the main board also. Check if the rgb voltages are steady on the crt driver transistor bases.
Jan 10, 2008 | Televison & Video
Toshiba 42 inch rear projection
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 23, 2007 | Toshiba 55H70 55" Rear Projection...
Blurry Image problem with Mitsubishi WS-55805
Hello, if you want I can supply you with the service manual, please leave your email. Best regards, Arpi
Aug 14, 2007 | Mitsubishi WS-55805 55" Rear Projection...
Philips 55PP9401 ProjectionTelevision
it seems as you need your tubes re-alinged dont get riped off by tv experts saying it will cost you loads if you have a screw driver and a gentl touch just re focus your red green and blue-simple cost you nothing
Aug 08, 2007 | Philips 55PP9401 55" Rear Projection...
Mitsubishi WS-55859 55" Rear Projection Television Logo
91 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
