Question about RCA L37WD12 37 in. LCD HDTV
When I turn on my tv, I get a black screen that says unusable signal. I change the channel, same thing. I try to use the DVD player or another add on and it is still black. My TV is an RCA 37in flat s
When I turn on my tv, I get a black screen that says unusable signal. I change the channel, same thing. I try to use the DVD player or another add on and it is still black. My TV is an RCA 37in flat sceen tv.
Thank you ryolkowski!!!! We just tried your solution and MAN it worked like a damn. We were all ready to make a trip to the city to get a new tv, an expense we just didn't need right now. You made our day. I can't thank you enough. jabo
Posted on Aug 02, 2009
Take the back panel off and look for a smd fuse with an F on it. Middle panel in the upper left corner, it is about the size of a tip of a pen. We used a copper wire to make a jumper. Works great now!!! We also noticed that there we some loose pieces and we pushed them back in and now the buttons on the side of the TV work.
Posted on May 18, 2009
Rca entertainment series unusable signal
i think your rca cord is not functional. replace it with another one or fix the connections of your cord.
Jan 04, 2014 | Televison & Video
Rca model j27435 trying to use dvd player says unusable signal
Most DVD players and maybe the Wi are connected via rear audio and video input jacks so that may be your issue.
Jun 11, 2012 | RCA F27442 27" TV
Dvd black screen tv
i guess there is some problem with line selection, please try to get the correct line input on tv, also dvd must provide correct line output signal, press input button on remote few times for example, please refer to user manual for detailed information.
Oct 19, 2011 | Sony Televison & Video
The screen is black and a little box that says no signal is moving around on the screen
Check your inputs. The no signal box means exactly that - there's no incoming signal for the TV to decode. So you've either disconnected a cable somewhere or turned off your input device.
Try changing the inputs on the TV (this will be a button saying input or A/V)
Try changing the channels
Check that your cables are correctly connected and that whatever you are trying to use (dvd player, PS3, etc) is turned on.
Check that your TV is tuned to the corresponding input it is plugged in to (if you plugged your DVD player into HDMI input 8, tune your TV to input 8)
Hope this helps.
May 11, 2011 | Sanyo Televison & Video
Entivoe DVD player worked fine. The next day, the tray opens, closes and the power turns on and off but the screen says only "Unusable signal", either with or without a video disc in the player. If there...
check the connection cable to the tv, unplug this an replug it to see if this helps.
if you used a cheaper HDMI cable for example the connectors are very wobbly and often make poor contact....
Aug 31, 2010 | Televison & Video
I have an older RCA television and when I hook the dvd player up to it the tv says unusable signal.
I don't know if this will help. Try changing the tv channel to channel 3. If that doesn't work, depending on which port you plugged into, start at channel 3 and go down in channels. it should change to the different ports you have with every push of the button. to get to channel 3 you may have to use your remote and type in '03'. Make sure your dvd player is on while you do this.
hope this helps
Aug 08, 2009 | RCA L32HD41 LCD TV
Emerson VCR/DVD player - can't get tv (cable tv) to play anymore
I have the same problem with my Emerson VCR. When the ADD button is flashing, just press the menu button to exit the menu. It will add. That's the only thing I know to do. Sometimes it works, sometimes it doesn't.
Feb 01, 2009 | Emerson EWD2203 DVD Player/VCR
Suddenly cannot record DVD after years
Apologies for the delay in response. Your concern was just brought to my attention.
To your recording, based on your second posting (and would appreciate corrective information where applicable), your system is:
  • Cable provider > Cable Decoder Box > Panasonic DMR-E75V > TV (equipment setup)
  • single coaxial cable > yellow, red & white > yellow, red & white (wiring setup).
With your indulgence, a couple clarifying questions:
  • to watch the Panasonic when you play DVDs, to what channel or source or setting must the TV be set to?
  • to record a TV program/channel, to what channel or source or setting must the Panasonic be set to?
  • what is the brand and model of your Cable Decoder Box?
Initially, pls try:
  • play any known good DVD disc/movie. power on the TV and set to watch said movie;
  • without changing anything on the TV, STOP the playing of the DVD;
  • try changing channel on your Cable Decoder Box's remote;
  • pls post back result(s); or
  • do the above steps again but before changing the channels on the decoder box's remote;
  • try changing/cycling through the different input/source of the Panasonic DVD;
  • again post back result(s).
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 10, 2008 | Panasonic DMR-E75V DVD Player/VCR
RCS Scenium
What is your TV input connection? Are you using Antenna? Cable? Dish?
The Unusable Signal sounds like the TV is not getting a signal. Does your TV have a built in HD Tuner?
If you are using Antenna you might want to try setting up the connections and it should search for quality channels that you get good signal strength. If you are on channel 2 and there is no over the air channel 2 it may say "unusable signal".
Sep 24, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Frozen on a menu screen
Just fixed ours with the same problem. You need to hit the volume buttons on the remote during the time the screen goes black but BEFORE it gives you the "Connect cables" message.It should trick the TV into giving you a blank channel.
Sanyo TVs are made notoriously cheap, and have little glitches like this. Best of luck, space cowboy.
Oct 13, 2007 | Sanyo HT27546 TV
RCA L37WD12 37 in. LCD HDTV Logo
870 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
