What type of bulb does wonderwall projector take
2 Suggested Answers
SOURCE: Wonderwall projector has black spot in middle of screen
Tranlucent dark spot on Optoma image. Looks like something is on the lens.Off center--top to bottom. Cleaned lens, blew out case, changed bulb, still with dark spot.
Posted on Nov 15, 2009
How to fix wonderwall projector after being unplugged while red light and fan were running
PDF]Download - MS Customer Care
mscustomercare.com/forms/ProjectorIM.pdf
getting started with the projector. 14 n. (1 se') ... I The projector can project up to 90" (228 cm) diagonal image. ... I Once powered on, the fan and the lamp will run instantly.... WHILE THE RED LIGHT IS BLINKING ... light bulb. I Turn off the projector, unplugthe power and allow it to cool for 30 minutes as it runs at an.
[PDF]Checking Projector Status - Epson
https://files.support.epson.com/Epson.../450W_460lampStatus.pdf
EpsonIf your projector isn't working correctly, first turn it off and unplug it. Then plug the ...doesn't solve the problem, check the lights on top of the projector. What To Do Whenthe Lights Flash. The lights on ... If you continue to use the lamp after the ... P Red. Off. Flashing red. There is a problem with the fan or temperature sensor.Missing: wonderwall
Canon Knowledge Center - Turning On and Off the Projector
Jan 18, 2016 | Sharper Image Wonderwall Entertainment...
When i plug it in makes noise like it will power up but when i press the power button nothing happens
Review: Discovery Wonderwall Multimedia Projector ...
? 15:01
https://www.youtube.com/watch?v=GYrFFrbWm5U
Dec 3, 2010 - Uploaded by georgef551
This is a review of the Discovery Wonderwall MultimediaProjector, ... twist the lens to focus the image, up to at least 120" (can go farther), but you'll ... RGB elements, which stands outlike a sore thumb when video gets .... The bulb will just make the display more true, and possibly, ... sound compared to 3m?Missing: power ‎power
Discovery Expedition Wonderwall Entertainment Projector
www.amazon.com/...Wonderwall-Entertainment-Proje...
Amazon.com, Inc.
Rating: 2.7 - ‎60 reviews
Amazon.com: Discovery Expedition Wonderwall Entertainment Projector: ... color contrast, volume control, distinct power on/off button, LED indicator light .... A lot of reviews complained about the fan noise and speaker level, but I thought .... I got it for Christmas to play video games on and you can't even make out the words.
Amazon.com: Discovery Expedition Entertainment Projector ...
www.amazon.com/...Entertainment-Projector/.../B002...
Amazon.com, Inc.
Rating: 2.5 - ‎267 reviews
Jan 05, 2016 | Discovery Channel Discovery Expedition...
How do I clean the inside of the lens on my wonderwall 1625073 projector
It is recommended only cleaning the outside of most projector lenses. However if obstructions have worked their way into the case and will not leave the lens, you may be able to remove the bulb (carefully, following the manuals instructions for bulb replacement)
And gently spray inside towards the lens where the bulb was. However, keep in mind the display itself sits between the bulb and the lenses,
Some projectors have air fins along the sides of the lens, some air in these fins can also loosen debris away from the lens.
Ensure the front of the lens is not dirty and that the focus has been properly adjusted before cleaning the back of the lens.
Nov 28, 2014 | Office Equipment & Supplies
No picture comes out when i plug in my wonderwall projector?
Could be no power where you plugged in or a bad light, switch or fuse if it has one. Check the wiring for burned connections.
Oct 08, 2014 | Discovery Channel Discovery Expedition...
Discovery wonderwall projector
i have one of these, i found that even if you think it is not blown it could be, i have replaced mine and it worked, so try to do the same
Jul 27, 2013 | Home
Is there any way that I can connect my new WONDERWALL projector to my laptop computer
The wonderwall does NOT have the proper inputs for use with a computer for good reason.
A wonderwall projector is NOT a projector that is good enough to be used for movies or games and it would be embarrassing to make a presentation on one. It has WAY less resolution than even old fashioned standard definition TV. Standard def Tv is 720x 480 pixels at 30 cycles. A wonderwall is 480x 240 pixels which is appx. the resolution of a screen on your phone. That's 345,600 for STANDARD def versus only 115,200 pixels for a wonderwall. When you blow that up to 3 feet wide, it'll look pretty mediocre. We have one just like it and we use it to project VHS onto our garage during Halloween and Christmas.
It IS perfect for fun and might be ok to watch old VHS tapes but watching a dvd on one is horrible.
Your 1440 has VGA outputs. A wonderwall has AV (red, white yellow) inputs. You can buy a vga to AV adapter for less than 10 dollars almost anywhere. You don't even need to go to a specialty electronics store.
Dec 17, 2012 | Discovery Channel Discovery Expedition...
How to connect wonderwall projector to computer?
Connecting an External Monitor or Data Projector
You can switch to an external monitor or data projector by two methods. 1. Connect the external monitor to the laptop's video port, power up the external monitor first and the laptop. The video information will automatically switch to the external monitor. 2. If you power up the laptop first then you can switch the video output to the external monitor by pressing the Fn key and one of the Function keys, depending upon your make and model laptop. You can also toggle between the external monitor or both LCD screen plus the external monitor or back to LCD screen only by pressing the Fn key plus one of the function key a few times. Here is a list of key combinations for some of the laptops :- IBM ThinkPad = Fn + F7 HP and Compaq = Fn + F4 Toshiba = Fn + F5 Dell = Fn + F8
Sep 23, 2012 | Discovery Channel Discovery Expedition...
Discovery projector no sound
go into the menu and select the internal speakers.
Dec 27, 2009 | InFocus LP 435Z Multimedia Projector
Sound from Wonderwall Project
make sure the ground (earth) is good. make sure there are no obstructions in the fan (paper, labels, packing peanuts, styrofoam, etc.). you may need to replace the fan itself.
Dec 26, 2009 | InFocus LP70+ Multimedia Projector
18 people viewed this question
k24674
jasbo
jasbo
