Question about Toshiba Satellite A135-S4467 Notebook
I have a Toshiba Satellite Laptop Model A15-S129 - The unit shut down and never would restart. I Checked the AC Adapter and it has no DC output voltage. I do have a 15VDC 2A Adapter connected to it now, the little yellow light in the front blinks on and off but when I press the Power On Button nothing happens. The Original Power adapter is rated 15VDC @ 5A - I am trying to avoid buying another Power Adapter if I am having a computer problem that might blow a new adapter. Please help, Jim
  • MrMachineDoc May 17, 2009
    The Laptop does not power up. How can I transfer the HD data to a flash drive or CD?
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 381 Answers
Hello..if you need to run @ safe the unit only up to 16v 2amp DC u need to try input..do not try higher from 16v DC or Lower 15v DC..or you need buy a new..Thanks And Good Luck...^_^
Posted on May 17, 2009
  • Nelson Olaso
    Nelson Olaso May 18, 2009
    hi..remove the HDD from the laptop then buy the mini/mobile enclosure IDE/SATA this way only i know to how to get your important files inside the Hard Drive of Laptop..Thanks..Good Luck..^_^
A15-S129 slow performance with 1GB of memory
maybe the Toshiba is bugged up with viruses and infections.
Apr 17, 2012 | Toshiba Satellite A15-S129 Notebook
It works good on battery but when AC adaptor is plug in the laptop cuts out and restart by itself.
Problem description: The laptop shuts off when AC power adapter is plugged in. The laptop works fine on battery power but as soon as you connect it to AC adapter, the laptop turns off.
Possible cause: 1. Power adapter failure.
2. Motherboard failure.
Possible troubleshooting steps and repair solution: First of all, test the power adapter. Make sure the adapter outputs correct voltage. It's possible that the output voltage is not correct and the laptop shuts down to prevent the damage. Test your laptop with another known good power adapter.
Toshiba Satellite A305 AC Adapter
If the problem still exists, even after replacing the adapter, most likely it's the motherboard failure. Replace the motherboard.
Mar 11, 2011 | Toshiba Satellite A305-S6857, A305-S6858,...
Hello, Can I install a 512MB DDR DIMM, N mem stick taken out of my Dell Desktop into a Toshiba Satellite A15, S129 laptop? Thanks, RD
You can try, without fear of having your laptop "blow-up".
Turn your laptop off.
Remove the battery.
Physically, does the RAM fit into the RAM slot? If not, the answer is 'no' -- most "desktop" RAM is much bigger than most "notebook" RAM.
If it fits, connect the AC power, and turn the computer on.
If it beeps wildly, or does not beep at all, the RAM is incompatible.
Disconnect the AC power.
Remove the RAM.
Re-insert the "old" RAM.
Re-insert the battery.
Reconnect the AC power.
Do a Google-search for "RAM upgrade Satellite A15" to find sellers that sell compatible RAM.
Oct 10, 2009 | Toshiba Satellite A15-S129 Notebook
DC power light is blinking orange on my Toshiba Satellite a15-s1292. Nothing else is working.
In general this indicates a problem with the power supply, this a very difficult error code to decipher unless you are familiar with hexadecimal code. I suggest you contact Toshiba Technical Support.
Sep 23, 2009 | Toshiba Satellite A15-S129 Notebook
Toshiba laptop does not run, just amber light blinking
Did the computer ever work? Have you checked that your memory is properly seated? Remove the bottom plate that reveals the memory modules, pop both loose then back in. Try to restart. Is the battery fully seated?
Sep 18, 2009 | Toshiba Satellite A15-S129 Notebook
Noisy fan
Ebay is a good source to get parts for Toshiba satellite. Look at Toshiba satellite for parts. Ton of them on regular basic.
Jun 04, 2009 | Toshiba Satellite A15-S129 Notebook
Toshiba Satellite A15-S129 PC Notebook
Have you turn the wireless antenna switch on?
Mar 31, 2009 | Toshiba Satellite A15-S129 Notebook
Toshiba satellite a15-s129 boots then lots of error screens show.
If you are referring to drive read errors when you attempt to open ANYTHING ("please restart program").. i installed a newer version of xp, windows7, and everything works fine now. this was not my laptop, so naturally i didnt care about wiping the HD. but the reason i was given this laptop was most likely the same problem you have, and now i have a brand new laptop, heh.
Feb 03, 2009 | Toshiba Satellite A15-S129 Notebook
Toshiba Satellite A135-S4467 Notebook Logo
137 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
