Question about Samsung SGH-A707 Cellular Phone
Paul skurulis phone was soaked in coke for about 1 minute,i removed battery& rinsed under tap.now it is dry it has red screen & front screen says download ?
  • anestis Sep 29, 2008
    MY PHONE WAS DROPPED IN THE SINK WITH VERY LITTLE AMOUNT OF WATER FOR ABOUT 3 TO 5 SECONDS.20 HOURS LATER IT SEEMS DRY BUT I HAVE THE SAME PROBLEM.RED SCREEN THAT SAYS DOWNLOAD.
  • Anonymous Nov 11, 2008
    was soaked in the water for about 1 minute,i removed battery& rinsed under tap.now it is dry it has red screen & front screen says download ?
When i thought my phone broke because i got pushed into a pool, i was told to put it in a bowl of rice. Take out the sim card and battery and put all components of the phone into the rice. If this doesn't work, you can take out the sim card and battery, and just put the body of the phone in the oven... heat it up to 100 and then put your phone in there, only leave it in for about 15 minute intervals. DO NOT PUT THE SIM CARD OR BATTERY IN THE OVEN THEY WILL BLOW UP!
Posted on Jun 26, 2008
When a phone gets wet, there is usually no fix for the problem, especially with coke. the sugar and other ingredients in a coke can corode anything faster than water. unfortunately you will probably need a new phone. stop by radioshack they have great deals on cell phones.
Posted on Nov 20, 2007
I hear if you remove the battery for 8 hours, it will drein the phone components respondible for the red sreen, except this is only a temp fix..everytime you turn off the phone it will do the same. my phone is doing the same thing..i'm on hour 4.but my phone never got wet, or any othe reason for this, i don't why its doing it.
Posted on Oct 18, 2007
  • 425 Answers
You needed to open your phone and to dry it throughly or have it check to technicians maybe thier is still moisture left inside and causes your phone to malfunction.
Posted on Oct 17, 2007
My dog has a metal dog bowl and the food sticks to it and gets dry
You can use dish washing detergent and hot water to remove the dried on food - I usually use boiling water from the kettle and leave it to soak for a while. Make sure you rinse off all the suds after by running it under the tap for a while.
May 13, 2012 | Pets - Others
How do i wash an air filter
1. APPLY CLEANER
Liberally spray K&N Air Filter Cleaner onto both sides of filter and allow to soak for 10 minutes to loosen the dirt. Do not allow cleaner to dry on air filter.
2. RINSE FILTERRinse off air filter with cool low-pressure water applied to the clean side out in order to flush the dirt out of the filter. Continue to rinse the filter until all traces of cleaner are gone. It may be necessary to repeat steps 1 and 2.
3. DRY FILTERAfter rinsing, gently shake off excess water and only allow filter to dry naturally. Do not oil until the filter is completely dry.
4. OIL FILTER
A.) Squeeze Oil (99-5050)
Apply K&N Air Filter Oil evenly along the crown of each pleat. Allow oil to wick for approximately 20 minutes. Touch up any light areas on either side of filter until there is a uniform red color at all areas.
B.) Aerosol Oil (99-5000)
Spray K&N Air Filter Oil evenly along the crown of each pleat holding nozzle about 3" away. Allow oil to wick for approximately 20 minutes. Touch up any light areas on either side of the filter until there is a uniform red color at all areas.
Thanks
Apr 01, 2012 | Garden
Hi, I am from Singapore. I have a fx-9860G Casio Calculator which I bought in 2008. I believed that I have left the battery in the calculator and left it untouched for about 1 year. I recently changed the...
When you took the batteries out, was there a white or greenish deposit around battery terminals, or battery leaks or swelling?
Most likely battery electrolyte has leaked into the electronics, eating through wires / parts, or the battery connector terminals / springs may just be corroded and need a toothbrush.
Best to open the back cover and inspect for corrosion / damage, cleaning where needed.
For cleaning dried electrolyte, it's best to remove the entire board, unplug display, soak in medium-hot water with dishwasher, or Coca-Cola, for 1 hour.
No, I don't work for Coke - just saw the tip once on You Tube. ;)
Gently scrub then rinse well with clean running water, allow to dry.
Dec 24, 2017 | Casio FX-9860G Graphic Calculator
How do I clean my EcoQuest Breeze?
The purifier should be cleaned about once a month and you should do the following:
  1. Unplug the Breeze before cleaning.
  2. Wipe the Breeze with a soft cloth dampened with water, vacuum the front grill to remove any lint buildup.
  3. Cleaning the rear lint screen - You can either vacuum the filter or you can wash in hot water. Allow to dry before reinstalling the lint screen. Do not use soap, it will damage the carbon material in the lint screen.
  4. Remove the purifier plate from the purifier and soak in 1 part amonia and 1 part water solution for 10-20 minutes. Gently scrub the metal grid on the plate with a toothbrush and rinse with water. Clean the metal contacts with the same solution. Allow the plate to dry overnight or use a hair dryer to dry throughly.
Dec 07, 2009 | Ecoquest Breeze AT Living Air Purifier
Coke spilled on nokia e90 and front display is not working
Remove the battery immediately, and use a hair dryer to dry up all the traces of coke. Do it for a few minutes at a time, many times till you are sure that the phone is totally dried up. Then insert the battery and poweron the phone. By using it wet I only hope that you have not short circuited some portion. DO NOT USE THE HEAT while doing it.
Aug 27, 2009 | Nokia Cell Phones
Routine cleaning Mabis XP.
If your unit is the one pictured, he cup with the medication can be taken apart to be cleaned... the top unscrews and the nebulizer comes out....and should be done so after every use. Do not use house hold chemicals to clean the unit. Use a water/distilled vinegar mixture to clean, then rinse with clean water.
Apr 07, 2009 | Mabis Neb Xp Portable Handheld Cmpressor...
Hunter Humidifier #33222
From The Hunter Manual
1. Turn the humidifier ‘OFF’ and unplug the unit.
2. Lift the main housing and remove the water dispersion tray and the PermaWick™ Filters. The motor is attached to the main housing. Do not place the motor near water. Do not use a wet towel on the motor or motor housing as electrical shock may occur.
3. The PermaWick™ Filter should be cleaned in a vinegar and water solution to remove any mineral buildup. Place in a solution of one (1) gallon of water and eight (8) ounces of undiluted white vinegar. Allow the filter to soak for 20 minutes.
4. After soaking, rinse it several times with clean water. Place the PermaWick™ Filter in a location where it can drip dry while you clean the other parts of your humidifier.
5. Remove the water tank from the base and empty any water that is left in the tank. Soak the base in a mixture of one (1) gallon of water and eight (8) ounces of vinegar for 20 minutes.
6. After soaking, wipe the base with a soft cloth or sponge to remove any mineral build up. Rinse with clean water several times. If you are planning on storing the humidifier, be sure the base is completely dry.
7. Fill the water tank with one (1) gallon of water and eight ounces of undiluted white vinegar. Replace the tank cap and shake the tank vigorously until all interior surfaces of the tank have been exposed to the water/vinegar mixture.
8. Empty the tank of the water/vinegar mixture. Rinse it several times with clean water and then replace the tank cap. If you are planning on storing the humidifier, dry it inside and out, leaving the cap off to allow the tank to completely dry. Continue to clean the other parts of your humidifier.
9. Remove the water diffuser cap by squeezing the two tabs as shown in Figure 3. Rinse the cap in clean water to remove any debris. If the cap contains hard water residue, soak it in a mixture of one (1) quart of water and two (2) ounces of vinegar for 20 minutes.
Rinse well and reinstall the water diffuser cap. Do not expose motor or other electrical components to water.
10. Wipe the surfaces of the main housing with a soft cloth.
11. Once all the parts are clean, reassemble the humidifier, and follow the USING YOUR HUMIDIFIER to continue use. If you are storing the humidifier, make sure the parts are completely dry, reassemble, and store in a dry location
Jan 16, 2009 | Hunter CareFree Plus 33222 Humidifier
How do I clean Hunter Humidifier #33222 ?
From The Hunter 3322 manual.
9. Remove the water diffuser cap by squeezing the two tabs as shown in Figure 3. Rinse the cap in clean water to remove any debris. If the cap contains hard water residue, soak it in a mixture of one (1) quart of water and two (2) ounces of vinegar for 20 minutes. 41553-01 01/03/2008 6 © 2008 Hunter Fan Company
11. Once all the parts are clean, reassemble the humidifier, and follow the USING YOURHUMIDIFIERto continue use. If you are storing the humidifier, make sure the parts are completely dry, reassemble, and store in a dry location
Not adding moisture to the air
Have you cleaned the unit lately? The following is from the owners manual.
Jan 04, 2009 | Hunter CareFree Plus 33222 Humidifier
I need to know how to clean my filters on Hunter Humidifier Model # 33222. I have misplaced my instructions.
The instruction manual suggests using the water vinegar solution.
The following is from the manual.
11. Once all the parts are clean, reassemble the humidifier, and follow the USING YOURHUMIDIFIERto continue use. If you are storing the humidifier, make sure the parts are completely dry, reassemble, and store in a dry location.
Dec 18, 2008 | Hunter CareFree Plus 33222 Humidifier
Samsung SGH-A707 Cellular Phone Logo
85 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
