Question about Siemens Dishwashers
Bosch manual for SHE44C05UC - Siemens Dishwashers
4 Suggested Answers
  • 457 Answers
SOURCE: Bosch dishwasher will not drain
drAIN AND CANCEL BUTTON WILL RESET UNIT;)
Posted on Feb 25, 2010
  • 457 Answers
SOURCE: Disconnected sink and related garbage disposal.
reset unit by hitting the drain and cancel button.
BElectric
  • 1140 Answers
SOURCE: My Bosch Dishwasher is not
Unfortunately, it seems that the heating element has failed. The dishwasher uses steam to heat the tub to dry the dishes. I suspect your dishes are also being washed in cold water.
To check this, please run a regular full wash cycle. Allow the washer to fill with water and run for about 10 minutes, then open the door and feel the water temperature in the bottom of the washer. If the water is cold, it's more than likely the heating element has failed.
There are other possible faults which would cause the element not to heat, but these often prevent the dishwasher from completing the cycle. If the water is cold but the dishwasher still drains the water at the end - and completes the cycle - the heating element has probably failed.
Please try this simple test for water temperature and let me know if you need further assistance.
Regards,
BElectric
Posted on Feb 18, 2011
Model SHE44c05uc runs for long period of time and dishes not dry at end, also not hot
Sounds like your heating circuit is not working. In Bosch dishwashers, this is frequently caused by a bad controller (instead of the heating element as you might first suspect).
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Mar 17, 2015 | Bosch Dishwashers
Noise Drain Motor? No Cloged
The Bosch units do have a little noisier drain pump than most other units, so if you don't hear a grinding sound it probably isn't something you would worry about, BUT if it is grinding, then it is a sign that either something got sucked into the pump or that the pump is starting to fail.
Jun 09, 2011 | Bosch 24 in. SHE44C05UC Stainless Steel...
My Bosch Dishwasher is not drying my dishes now. The model number is SHE44C05UC.
Regards,
BElectric
Feb 18, 2011 | Bosch 24 in. SHE44C05UC Stainless Steel...
Feb 25, 2010 | Bosch 24 in. SHE44C05UC Stainless Steel...
Bosch Dishwasher (SHE44C05UC) won't turn on
Just had the same problem, same model. Found the wiring below the front cover fried. So now I'm checking to see if anyone else had this happen.
Jan 13, 2010 | Bosch 24 in. SHE44C05UC Stainless Steel...
Bosch 24 in. SHE44C05UC pops breaker
We just had a potentially dangerous problem with the same model. Only we found the wiring beneath the front door were fried. How do yours look?
Dec 31, 2009 | Bosch 24 in. SHE44C05UC Stainless Steel...
Power fine, but no water filling the tub
difficult not seeing the valve firsthand but if you could connect a tester to the solonoid and confirm that there is power on the terminals, then you know there is an issue with the valve. typically, if you have a leak, it to will raise the float and shut off the valve.
Oct 05, 2007 | Bosch 24 in. SHE44C05UC Stainless Steel...
Dishwashers Logo
73 people viewed this question
Top Siemens Dishwashers Experts
aliasger yq
Mike
Are you a Siemens Dishwasher Expert? Answer questions, earn points and help others
