Question about Peg Perego 12 Volt Rechargeable Battery
When I plug the battery in to be charged the light on the charge stays green. The light never changes to orange/amber. This is not a new battery I have had it for a while.
  • 699 Answers
Your SLA (Seal Lead Acid) battery is must likely past its useful life due to Sulfation and internal mechanical damage (corroded plates): your charger, like for most car lead acid battery charger is indicating that only a very small charging current is flowing just like when a battery if fully charged ... or the terminals are not connected (no current)! You can check if the charger is working by preferrably using a multimeter or connecting a know good battery unit to the charger.
Posted on Nov 27, 2009
Red light flashing on charger
A red light indicates the charger is charging the battery, an amber light means it has switched from fast rate charging to trickle to keep the battery topped off, and green would mean the battery is completely charged. But don't be fooled waiting for green, many times the charger will only be on green for a moment before changing to amber and keeping the battery topped off.
Flashing can be a sign of a problem on some chargers.
A rapid flashing red can on some chargers indicate a bad or shorted battery, or a bad battery contact in the charger itself. If in question, try a different battery on the charger or compare with another charger to determine if the blinking is normal.
Best regards.
Nov 19, 2013 | Motorola htn9042a charger,120v,single unit
Battery light won't change colors, drops to 0% once unplugged
Let the battery completely discharge all they way and let it sit for a day or so. Some times when a battery is new most user do not let it fully charge and then completely drain this causes problems for long use batteries. Then give it a try. It also sounds like your plug your cord that connects to the battery may be faulty. Did you by a different cord with the battery? Or use the one from your old one? If you did. This is a "No No" always buy the cord that come for those battery since they are rated for the particular battery.
Feb 25, 2012 | Fujitsu LifeBook A1110 Notebook
Orange battery light is doing a double blink right now... Does that mean the battery is being charged??
I had the same problem, I removed the bettery while it was still plugged in, tested it, then plugged it back and and now all is fine.
or you may try If an AC adapter is not connected to your computer, the computer's power source
is a battery. If the battery indicator flashes amber or is a steady amber, the
battery needs to be charged. If the battery is flashing green and amber, the
battery may be defective. To troubleshoot this problem, use the following
procedure.
1. Turn off the computer and peripherals, and disconnect them from AC power.
2. Reseat each installed battery by removing it and then replacing it.
3. Turn on the computer. Does the green power indicator light up?
Allow one minute for the computer to initialize its components before checking
for signs of power.
Yes. Continue to step 4.
No. Use the AC adapter to connect your computer to AC power. If the computer
operates normally when using AC power, go to step 7. If the computer does not
boot when using the AC adapter, see the previous subsection, "Total Power
Failure When Using the AC Adapter."
4. Does the battery indicator flash amber or show a a steady amber light?
Yes. The battery needs to be charged. Go step 5.
No. Go to step 7.
5. Connect the computer to AC power, and fully charge the battery.
For instructions, see the topic titled "Charging the Battery" in the online
System User's Guide.
6. As the battery charges, does the green battery indicator light up?
Yes. Go to step 9.
No. Go to step 7.
7. Is the battery indicator flashing green and amber?
Yes. Your computer may be in a hot environment. Charging the battery in this
condition may affect the life span of the battery. Continue to step 8.
No. The problem is resolved.
8. Disconnect the computer from AC power. Is the the battery indicator still
flashing amber?
Yes. You may have a defective battery. Continue to step 9.
9. Remove the battery, and press its test button. Is the uppermost indicator in
the charge gauge of the battery flashing?
Yes. You have a defective battery. Continue to step 9.
10. If a spare battery is available, fully charge it, and then install it in the
computer.
11. Turn on the computer. Is the power indicator off?
Yes. Your original battery is defective - please look for a replacement. Hope it helps.
Jun 25, 2010 | Sony VAIO PCG-K35 Notebook
Battery light blinking red during charging
Dell or Panasonic? Your post has both listed.
If the blinking light on a Dell is yellow or amber or orange (somewhere in that color range) and continues to blink the entire time it is plugged into AC power (wall outlet) and when you unplug it from the wall the laptop immediately dies .... then you battery is dead and needs replaced.
If the blinking light stops after a while (perhaps a minute?) and then turns green while plugged into AC power, then it is successfully charging - or so it thinks.
When you unplug it from the wall, does it stay up and running?
If it runs, it's OK - just ignore the light and plan on getting a new battery one day, start browsing now. :)
If it dies immediately upon unplugging, then your battery is dead and needs replaced.
Jun 13, 2009 | Panasonic Toughbook 28 Notebook
Laptop battery charge indicator flashing amber and green
If the battery is hot from being used in your computer or being in a hot environment, the battery may not charge when you connect the computer to an electrical outlet.The battery is too hot to start charging if the batter15.jpg light flashes alternately orange and green. Disconnect the computer from the electrical outlet and allow the computer and the battery to cool to room temperature. Then connect the computer to an electrical outlet to continue charging the battery.
Regards..
Apr 14, 2009 | Dell XPS M1710 2.33GHz Core 2 DUO T7600...
Orange battery light on, but computer says its running on electrc
Hi, the orange light is meant to show a charging status, so if you have orange light and its running on electric it just means its plugged in and charging.
Mar 09, 2009 | Dell Inspiron 6000 Notebook
Flashing amber light
Attempt to boot the laptop with the battery removed and the AC plugged in. IF this boots ok it may very well be the battery circuitry which has failed.
Nov 26, 2008 | Acer Aspire 5315 Notebook
Battery won't charge/no power to unit
Charger seams defective. get new charger and try.
May 29, 2008 | Samsung SC-D103 Mini DV Digital Camcorder
Samsung battery
Green:Fully charged
Amber:Improper connection
Red:Charging
Sep 04, 2007 | Samsung SCH-i730 Pocket PC
Peg Perego 12 Volt Rechargeable Battery Logo
1,826 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Lawrence Oravetz
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
