Question about GE Wr13x10737 Ice Route Case Assembly For Refrigerator
WR13X10737 repair how to remove part from the left door of the refrigerator
When i close the left door the right door pops open 1.5 inches this problem has just started i have had the unit for 4.5 years
I had the exact same problem with my Kitchen Aid French door refrigerator...... I had my appliance repair man come twice and we finally found the problem........... the LOWER DOOR HINGE was broken on the inside. you can only tell when you go to remove the hinge from the inside of the door. he replaced it and it works beautifully. I read how many people have had this problem and have replaced the gasket on the door but it didn't solve the problem. that's because it's not the gasket it's the lower hinge in the actual door. good luck
Jan 21, 2011 | KitchenAid Architect KBFA25ERSS Stainless...
Electrolux side by side door refrigerator. White
This can be pulled out of the door and replaced with new tubing.You may need to remove the front dispenser panel in order to get the tubing out of the dispenser.
Once you do that then you can pull the remove the tubing and replace it with new line.
Jan 01, 2011 | Electrolux 25.9 Cu. Ft. Side-by-Side...
Our bottom freezer, frenchdoor whirpoolgold 2008 refrigerator stopped cooling the refrigerator last night. The freezer works fine. What do I need to do. I emptied the refrigerator, vacumnned off the...
It has a motor mounted above the evaporator that pushes air up into the fresh food compartment. That fan motor might not be working. To get to it you need to remove the bottom door and get the food out. Remove the ice maker and shelves and then the rear access panel can be removed. Before going through all that though you can check the continuity of that fan at the control board located behind the ice box. I have a repair manual HERE
Jan 19, 2010 | Refrigerators
Water dispenser line leaking at bottom of freezer door hinge, line broken, do i need to remove the inside door panel of freezer door to replace it?
if you have enough room left you can just cut out the hole and go to any hardware store and pick up a water line coupler and repair it....if it is too short or broke up inside the door then you need to remove the water/ice dispenser and pull the line through and run the new one down the track.
Oct 03, 2009 | GE GSS25JFM Side by Side Refrigerator
GE refrig Model # GSS25WGMD WW freezer is cool, compressor is running, but food is thawing out, ice has melted...not sure if I left door open ovenight, should I call repair..show long does it take to...
I pulled the refrig out from the wall, turned it off, took off the back panel (that covers the compressor fan and motor) and used the attachment on my vacuum to remove the dust from the area. Then I closed the flapper that allows the ice to release from the ice maker compartment to the dispenser, so no warm air would get into the freezer area. I plugged the refrigerator back in and within an hour it was freezing again! So far this week, I have had to repair the garbage disposal and the refrigerator.....I saved some nice $$$ by figuring this out by myself!
Jun 25, 2009 | GE Refrigerators
Amana AFI2538AEW bottom freezer door handle is loose?
My dad's freezer handle is loose, model ABB2224DEW. Went to partselect.com and located drawing of freezer door parts. Found a link to a "do-it-yourselfer" that describes removal and replacement of the handle. Hopefully this helps.
Replacement of freezer door handle.
1. Removed freezer door handle. First I read the freezer door handle removal instructions in the Amana refrigerator user guide. Removing the handle requires inserting a plastic card at least 1.5 inches under the left end of the right side of the handle so it releases the butterfly clip latch on the freezer door. Next I pulled the right side of the handle to lift it away from the freezer door. Then still holding the handle away from the door, at the spot that is 1.5 inches from the inside of the right side of the handle, I held the plastic card vertically and slid one corner of it between the handle and the freezer door and worked the card down until it released the butterfly clip latch. Keeping the card at the same space under the handle so the latch was released, I then turned the card to the left until it was horizontal and was lifting the left end of the right door handle away from the freezer door. I then slid the handle across the card to the left until it cleared both door butterfly clip latches and it lifted off the door.
2. Installed freezer door handle. First I read the freezer door handle installation instructions in the Amana refrigerator user guide. The handle is curved on one edge and must be installed the curved side down. Correctly installed, the outside ends of the handle curve upward and the handle curve is down so it looks like a frowning mouth. Next holding the handle curved edge down, I turned it up so I could see the brackets and held it against the door. I lined up the handle brackets slightly to the left of the butterfly clips on the freezer door. Next I turned the handle with the brackets against the freezer door and slid it slightly to the right until the left side of the handle held onto the door butterfly clip by itself but was not latched. Then I lined up the right handle bracket with the right freezer door butterfly clip and carefully slid the whole handle to the right until I heard the left butterfly clip latch click. Next I slid the handle back slightly left once more and then slid it back to the right until I heard the right butterfly clip latch click.
Parts Used: HANDLE, DOOR (WHT) Level of difficulty: Difficult Time to do repair: 30 - 60 mins
Apr 02, 2009 | Amana AFI2538A Bottom Freezer French Door...
How to repair the ice dispenser door on a whirlpool refrigerator
If you will look on the bottom of the dispenser cover you will see 2 notches on the left and right side. carefully pry the cover off using a flat tip screw driver. then you will see a white switch plate that is either held on with latches or 2 srews depending on model. once this is removed you will gain access to the dispenser door.
once you gain access I think you will find the hinges for the dispenser door are broken off. if so you will need a dispenser door repair kit form whirlpool part # 8201756 this kit includes new door and hinge repair kit. this is something you can do yourself if you are pateint and pay lose attention to detail. otherwise I would recomend a god servie company. thanks for using FixYa Peyton
Feb 18, 2009 | Whirlpool 21.8 cu. ft. Side-By-Side...
Wont fit through the front door
take plastic covers off top hinge remove 3 screws pick door up off bottom hinge do not remove bottom hinge,both doors remove the same left side u have to disconnect the water line.
Jan 10, 2008 | Samsung RS2630SH Side by Side Refrigerator
GE Wr13x10737 Ice Route Case Assembly For Refrigerator Logo
51 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
