Oki c350dn service call 124 err - Office Equipment & Supplies
Oki c8600 registration error 3
Registration Error 3
When a color registration error is detected with coarse
adjustment, or with the main-scan line adjustment.
PU firmware does not notify this warning to CU firmware
at the time of Shipping Mode. Therefore, this status
does not occur in a user environment.
n
2 = Yellow
3 = Magenta
4 = Cyan
Dens Shutter Error 2
DENS SHUTTER ERR
Check 3: Check to see whether the sensor shutter opens and closes normally, by the
MOTOR & CLUTCH TEST of the self-diagnostic function. If the shutter operates
imperfectly, replace the shutter unit.
May 06, 2014 | Oki Electric Industry C8600n Led Printer
What is err 231 on an oki data b4600
Please list the error message exactly as it appears in your window
Write down the message including the error number "nnn,".
Jul 26, 2011 | OKI B4600 Printer
Err 120
This error is a PU Board Fan motor error.
Check if the fan is properly connected, if necessary replace the fan.
Should fix the problem.
Jun 25, 2011 | OKI B4600 Printer
My OKI B4600 is displaying error 134
It means the printhead [laser] is "missing" - but usually it's just the data cable at the end of the printhead has popped out. Very common - we have hundreds of Okis at our corp and I've fixed this many times. Turn the power off, pull either the left or right plastic clip AWAY from the printhead, and carefully insert the data cable back into the connector on the printhead. Put one end of the printhead nearest the data cable back into its plastic clip, and make sure the spring is seated on its little post on the bar, and then click the rest of the printhead into the clip on the end opposite of the data cable, again making sure the spring is seated on its post. Turn the printer on - your error should now be gone.
Mar 01, 2011 | OKI Electric Industry B4600 Laser Printer
Comm.ERR on fax 5680 OKI
You need to check parameters for LAN and e-mail settings (IP address, Subnet mask, gateway address, SMTP-server address, DNS-server address, etc). It is also important to enter "From address" in a correct form, i.e. name @domain.xxx otherways above error will be displayed.
Aug 28, 2009 | OKIFAX 5780 Plain Paper LED Fax
OKI C8600 service manual.
http://safemanuals.com/user-guide-instructions-owner-manual/OKI/C8600N-_M
I don't know if it is this but i hope it helps
Cheers
Jun 21, 2009 | Oki Electric Industry C8600n Led Printer
FREE DOWNLOAD DRIVER
what is err 120 how can i fix this
Jul 20, 2008 | OKI B4350 Laser Printer
OKI B8300 Call for Service error
http://www.printcopy.info/shop_e/cdrom.php?brand=OKI
Here is a link to service manuals for OKI
Feb 07, 2008 | OKI B8300 Laser Printer
Error code 173
That error means low temperature on the heat roller. The thermistor (something like an electric thermostat) measures the amount of heat needed to work. Error 173 refers a lower temperature than required, while error 172 refers overheat. The complete error list will be of no use to you, since most errors will refer you to an authorized service center.
Sep 20, 2007 | OKI B4300 Led Printer
jasbo
jasbo
