Used toner bottle full ricoh 2045e - Office Equipment & Supplies
spinal
  • 287 Answers
SOURCE: Used Toner Bottle Full - how do I empty it?
Hello Pete,
I have your bulletproof fix. Open the front door,and look at the far right bottom corner.You will see a piece of sheet metal about 3" by 6" that is locked down by a black plastic button that looks like an oversized thumb tack(if its still there). The black retainer holds the sheet metal slider in place. The sheet metal slider holds the used toner bottle in place.Remove the black plastic retainer and slide the sheet metal towards you.The sheet metal will actually have a hold on the waste toner bottle and so they both will come out together,as you will see when you pull it out. Empty the bottle into a trash bag (be careful, its not dangerous but can make one hell of mess). This machine uses an auger and tube assembly to deliver the used toner to the bottle. As the bottle reaches maximum capacity, the backpressure of trying to push more toner into a confined space causes a bind in the delivery system which trips a sensor(photo interruptor) and you get the message to empty the waste toner. So once the bottle is emptied you should be ok. Note: on rare occasions the tube and auger assembly(which became somewhat packed and therefore gave the message) will remain slightly bound even after the toner in the bottle is emptied.You might have to slide the waste toner bottle back in a couple of times to dislodge the clogged toner. In fact I have had to use a slight amount of "force" to jog the clog loose.Again this is rare. The copier should immediately recover once you put the bottle back and close the door. Another rarity can occur which will cause you to turn the copier off and back on in order for the copier to return to a ready condition. Have a fine day. ............SPINAL............
Posted on Jul 19, 2008
chad7houston
  • 62 Answers
SOURCE: Used Toner Bottle Full Ricoh Aficio 1035P
The used toner bottle is not actually a bottle at all. Not sure what you emptied, but it sounds like the actual toner bottle itself. The waste toner is contained with in the transfer belt unit. When you open the right side cover, this is the unit that is attached to the door. It is a brown belt that provides transfer of the image to the drum and separates the paper from the drum. Remove this unit by locating the release levers on either side of the transfer unit (push both of them towards the machine). After removing, you will need to actually take the belt unit off of the transfer unit. To do this, remove the two tension springs on either side, and then take a small flat bladed scredriver and release the clips that hold it down (you will see when you get started). Once you get it off, you will see the long blade that actually scrapes the toner off the belt. Dump the waste toner out this end. You will need to shake it pretty hard. A better (and cleaner) option is to vaccum it out using the crevace tool on you vac. Just make sure you completely empty it. Now....do everything in reverse.
Hope this helps,
Chad
Posted on Oct 09, 2008
  • 990 Answers
SOURCE: I need to empty or repalce the used toner bottle
Hello sir; You may open side door, you will find out a retangle plastic box that is the waste toner bottle, on the top of waste toner bottle have a green knob, just slide it to right, you can remved it and dump it out.
Posted on May 18, 2009
  • 15 Answers
SOURCE: waste toner bottle - Ricoh MP W2400
Just an FYI, this can be very messy. If you figure out how to get the thing out (should be near your consumable supplies like toner and image units) place the whole unit into a plastic bag, tie the bag, then shake it out gently. You may have to learn how it opens in order to "open the door". Best to use a vaccum with a heppa type filter as normal vaccum filter is too course for the fine toner partcles. Be ready for toner volcano.
Posted on Jun 09, 2009
SOURCE: used toner bottle full on a ricoh aficio 400
The sensor is dirty or damaged cleans or replaces. This is not reset.
Posted on Sep 14, 2009
Message the toner bottle is full please call the server machine printing rico 4500
The bottle full message indicates that the waste toner collection bottle is full. The full bottle needs to be removed and the toner disposed of properly. Then a replacement collection bottle needs to be installed and the waste toner counter reset. This site has the toner bottle: http://www.precisionroller.com/waste-toner-containers-for-ricoh-aficio-mp-c4500/details_47769.html . It is possible to reuse the bottles but most people will spill the toner when they try to empty a collection bottle. You do not want loose toner in your environment.
Turn off the printer (at the power switch) and wait for the lights to stop blinking before attempting the replacement. See page 62 of the network guide for the replacement procedure. See https://www.ricoh-usa.com/downloads/downloads.aspx to search for your printer and get the manuals.
I hope this helps
Jul 06, 2015 | Office Equipment & Supplies
My machine aficio 2045e give error toner signal even though toner in bottle is more than50% i make every thing but still appear add toner
Inside the toner feed mechanism there is little plastic fins that tend to break off. You will probably have to replace the hopper unit (The unit that the toner tube sits in) or in that unit where the tube opening sites you can either replace the feed chuck or if your handy maybe repair the feed fins. The chuck part pops out with plastic tabs.
Sep 14, 2011 | RICOH RICOH AFICIO SP C820DNT2 40 PPM...
We have a Ricoh Aficio CL3500N and are getting an error stating: "Used toner is almost full." No manual to refer to. Thank you!!
Hi there, You can just empty the waste toner bottle. here is what you need to do. Here is also a manual for your machine http://support.ricoh.com/bb_v1oi/html/oi/re/model/cl3500/cl3500en.htm Detailed instructions on cleaning the Waste toner bottle on Page 32 of the Maintenance Guide. Instead of replacing just empty it. Just be careful as the toner is toxic so you can also vacuum the toner out of the Waste Toner Bottle.
Regards,
Jul 27, 2011 | Ricoh Aficio CL3500N Laser Printer
Ricoh aficio Aficio 3224C used toner bottle -1 is full
On a 3224, the used toner bottle is easily replaceable. To get to it, open the front cover of the copier. In the lower left corner, you will see a white or light gray plastic container which slides straight out -- that is the used toner bottle. You can replace it (if you have a new one) by taking the old one out, putting the black plug in the hole to prevent toner from spilling, throwing it away, and inserting the new bottle. If you don't have a new used toner bottle, you can empty this one out into a large bag or trash can and then reinstall it.
Mar 18, 2011 | Ricoh Aficio CL3500N Laser Printer
Ricoh copier imagio error used toner bottle is full
Change the used toner botle,desasembly the LCT tray,open the front cover and change the waste toner bottle.
Feb 09, 2010 | Ricoh Aficio 450 Copier
Used toner bottle full on a ricoh aficio 400
Apr 08, 2009 | Ricoh Office Equipment & Supplies
The used toner is stored in the Transfer Belt assembly on the right door that you open to remove a jam. Remove one spring on each side and release the catch while gently lifting up on the belt and roller assembly. It swings 90 degrees up from the rest of the assembly. There are 6 screws that hold a cover on the lower assembly. remove it and dump the waste toner. *** VERY MESSY*** have a vac on hand. Not a shop vac unless you want toner clouds floating around the office. If the six screws aren't present, dump the toner out of the **** between the mylar-rubber blade and the lower assembly. once this is done, the message will clear.
I have a Ricoh 2045E I changed the toner and now get a SC680 error?
There are no SC 680 codes listed in the service manual for a 2045e
Please re check the code
Feb 26, 2009 | Ricoh Aficio AP3800C Laser Printer
Ricoh SP C410DN
Unfortunately the newer ricoh equipment may include a chip like the HP toner. This allows the printer to track the usage so the printer can "intelligently" determine how much toner remains in the bottle. The chip overides all other factors on the remaining toner. Hence, if the chip "thinks" that the toner bottle has little or no toner left, it will give you a false toner low message. Presently, you can only replace the toner with a new bottle.
Oct 08, 2008 | Ricoh Aficio SP C410DN Laser Printer
Waste Toner Light won't go off?
just clean out the transfer belt
Sep 20, 2008 | Office Equipment & Supplies
26 people viewed this question
k24674
jasbo
jasbo
