Question about Kitchen Appliances - Others
Replace the sealing strip on a foodsaver v3825
How to replace the sealing strip on a food saver model v3825
SOURCE: Food Saver quit working.
i have a game saver plus. when i start the seal light comes on then it sucks the door closed then the seal light comes on again and the door opens and it stops
Posted on Apr 30, 2010
SOURCE: Foodsaver 1050 - the metal strip under the tape is
Try elementsandteflon.com. or Hualian Packaging Machineries, Inc. You may find it there.
Posted on Jul 13, 2010
  • 88 Answers
SOURCE: Foodsaver Food Sealer Vacuum V2240 T: Foodsaver Professional II Turbo. Vacuum pump work...
This is likely happening because the unit cannot detect that a vacuum has formed, and as a result, the unit never "turns on" the heating element to seal the bag, with the gaskets around the vacuum channel being the probable culprit. The Foodsaver gaskets will deform and/or dry out with time, just like in any device, but you don't necessarily have to replace them. I've tried this inexpensive solution on my own Foodsaver V2490, and it works perfectly.
Buy some food-grade silicone grease and apply it to both the upper and lower gaskets. I remove the gaskets and coat both sides with a thin layer of grease before replacing them in their respective channels. And since this grease will be absorbed and/or dry out with time, you will have to do this occasionally, so I also flip the gaskets (i.e. turn them over) whenever I apply the grease.
You can buy a 2 oz container of silicone grease at any dive store, or you can buy it over the Internet by searching for "Trident silicone grease".
This is a link where you can buy it for around $7.00:
Dolphin Dive Center
I do not work at this dive center, but I am a scuba diver and already had some grease that I use for the numerous rubber gaskets in my gear. The 2 oz. jar will last you several years, and you will find many other uses for it around the house since the grease will last longer than a spray.
Posted on Aug 02, 2010
  • 88 Answers
SOURCE: Can you purchase a replacement seal/gasket for the
I posted this solution for other problems - it might help you, too:
Dolphin Dive Center
heatman101
  • 43501 Answers
SOURCE: foodsaver vac800 not sealing bags any way to fix
No, the heating strip is actually a wire that get s warm the do the sealing...when the wire breaks there is no more heating and there is no way to repair that wire...
heatman101
Posted on Sep 16, 2010
Testimonial: "20 mins. got my answer fast thanks"
Door to my foodsaver is stuck on one side. It's shut. How can I release it? Is there a release button anywhere?
Trouble with Food Saver Brand - Survival Podcast
thesurvivalpodcast.com > ... > Food Preps > Processing Food For Storage
Aug 15, 2010 - 17 posts - ‎13 authors
We have been using our Food Saver Vacuum sealer we bought ... connects somehow got stuck open and therefore the bags would not ..... I've had the FoodSaver V3840 for about 10 months now and thus far it has been great.Missing: door
FoodSaver Repair - YouTube
? 8:22
https://www.youtube.com/watch?v=jguFiF0Rouw
May 21, 2014 - Uploaded by Kelly Kimble
Repair a FoodSaver that isn't drawing out air anymore. In this case, its ... Vacuum Sealer Troubleshooting - Duration: 10:25. katzcradul 52,345 views. 10:25 ... How to Food Saver Lemon Juice or Other Liquids - Duration: 4:56.
[PDF]Use and Care Manual - Home Depot
Jan 25, 2016 | FoodSaver Vacuum Food Sealer - V3840
The progress light on the food saver is flashing red
The heater bar is too hot. Allow it to cool for a while before resuming sealing.
Oct 15, 2014 | FoodSaver Tilia 801 Food Saver Vacuum...
Why my foos saver is not sealing
I've found with mine I have to hold down firmly on the top while unit is heating the bag to seal it. I continue to hold the lid down for about 10 seconds after heating stops until the seal cools. Hope this helps.
Sep 09, 2014 | FoodSaver Smart Seal Vacuum Sealer V3825
V3840 heat strip doesn't get hot
Could be the heating element (wire that gets hot enough to melt plastic) is going bad, how long have you been sealing bags with the unit? If you have used it for some time there is the possibility of build up plastic/residue on the the wire or the surface that actually comes in contact with the bag as I would suspect there is a coated surface the element heats up as opposed to the element / wire coming in contact with the plastic itself!
Nov 19, 2017 | FoodSaver Vacuum Food Sealer - V3840
Why there say tray full red light
The tape trick didn't work for me. Had to cut the wires. Works for now.
Sep 27, 2012 | FoodSaver Smart Seal Vacuum Sealer V3825
Jan 08, 2010 | Tilia FoodSaver V2240
Foodsaver compact vac 550 sealing strip doesn't seal
My machine stopped working because the sealing ribbon was broken and the tape was worn. FoodSaver no longer does repairs. I knew the wire was called nichcome ribbon so I searched that. I checked the resistance of the ribbon on my machine, it was about 3.8 ohms. I found a site called mpakonline.com and from their site I bought 1/16 x .005 nichrome ribbon and 3/8 x 5 MIL. x 18 YD Acrylic Teflon Tape. The total cost of these items was about $36.00, the ohm value of their ribbon was 1.66 somewhat less.I used ends from radio shack made the repair and it has been working fine for the last two months and I have enough material leftover for about ten more repairs.
Nov 14, 2008 | Heating & Cooling
Kitchen Appliances - Others Logo
106 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
