Question about Apple iPhone Smartphone
Update gmail to IPhone
When accessing my gmail, the "Updated" messages are days old and newer messages do not show up. How can I get my gmail to actually be updated to the current day and time? Thanks.
  • 443 Answers
Yes you can. You may have the Email Fetch set wrong. So follow this and it should solve that right away.
Go to Settings,
Mail, Contacts, and Calendars
Fetch New Data
Make sure Push is ON
Then set it to Every 15 Minutes.
This will make sure that your email checks for mail every 15min and notifies you right away of new mail.,
Posted on Aug 26, 2011
Trying to update my Iphone 4s and it tells me that i'm already updated with the current ios 7.1.2 how do i get updated to a newer version???
I believe 7.x is the end of the updates for the 4s. Pretty sure you can jailbreak 7.x, search redmondpie.com for an article about it.
Oct 10, 2016 | Apple iPhone 4S
I put in wrong code and now it says disabled connect to iTunes but I set the phone up with wifi so how do I get in my iPhone?
Your iPhone is currently on disabled mode after entering wrong combination of password. There are several ways to gain back the access to your iPhone:
First Method: iTunes
1. Using your computer, open iTunes where you have recently backed up your iPhone.
2. Connect your iPhone. Once your iPhone is detected, a notification will appear to enter your passcode. Note: If the lockscreen doesn't show, proceed to next method.
Second Method: Update
1. While your iPhone connected to iTunes, powered on. Hold down the Power key + Home button simultaneously until the screen off, keep on pressing the Home button then release the Power key until iTunes detected that your iPhone is on Recovery Mode. Note: An iTunes logo will appear on the iPhone when Recovery mode is enabled.
2. On iTunes, click on Update iPhone. It may take a while to download the software, so leave it for a while connected until the installation complete.
3. Once updated, try unlocking your iPhone. Note: If you still can't unlock your iPhone proceed to next method.
Third Method: Restore (last option)
1. If method 1 and 2 fails to unlock your iPhone. Then try to restore your iPhone into its factory default and restore your backup after.
2. Go to recovery mode. See method 2 step 1 process to enable recovery mode.
3. Then choose Restore iPhone. Note: Restoring your iPhone will delete and remove all of your data including apps, music, photos, messages, contacts, notes, etc.
4. It may take a while to download and install the software, so leave your device connected until the process complete.
5. After your iPhone has been restored, choose restore from a backup or iCloud, then wait until your iPhone successfully synced your old data.
6. Try unlocking your iPhone.
-joshd
Mar 28, 2016 | Apple iPhone 5c
Text messages missing after iOS 8.2 update
If you have made backups, you can restore your iPhone from iTunes or iCloud to recover messages. However, this will replace the existed on iPhone, so you can try recover old messages with a professional iPhone data recover PhoneRescue. How to Retrieve Deleted Text Messages from iPhone 6 Plus
Jun 29, 2015 | Apple iPhone Cell Phones
When I sync the outlook calendar to my iphone, one of two things happens. 1. If I put an all day event in outlook, it syncs to the iphone a day earlier (both otlook & iphone are on same date &...
Make sure time-zone is the same for both iPhone and the computer.
On iPhone setting > Mail,Contacts,Calendars setting > Time Zone Support, make sure you are choosing the city where you are in.
Otherwise, make sure you have updated the iTunes to 7.5 or later.
Update to iTunes 7.5 or later to resolve this issue. If you're not able to update, continue reading for other options to resolve the issue.
Each Outlook calendar event has an internal property known as "Message Class." When some Outlook plug-ins are installed (such as Live Search Maps), the setting for the Message Class property can change from its default of "IPM.Appointment" to something else. iPhone and iPod touch are only able sync calendar events with the Message Class set to "IPM.Appointment," therefore any calendar events created after installing certain Outlook plugins may no longer sync.
To verify this, examine the property of the Calendar event items for MS Outlook and see if the Message Class shows something other than "IPM.Appointment" in any of the calendar events. To view the Message Class property for your Outlook Calendar events, add the Message Class field as one of the columns in the Current View using these steps:
  1. Open Outlook Calendar on the computer.
  2. Choose View > Current View > Events.
  3. For Windows Vista, choose View > Current View > Customize Current View.
    For Windows XP, choose View > Arrange By > Current View > Customize Current View.
  4. Click the Fields button and choose All Appointment fields from the pop-up menu in the "Select available fields from" section.
  5. In the "Available Fields" column, select "Message Class" and click the Add button.
  6. Click OK.
  7. Click OK.
Now verify that all your calendar events are showing "IPM.Appointment" for the Message Class column. If you have calendar events showing a different value other than "IPM.Appointment" you will need to perform the following steps to fix the issue.
  1. Uninstall any Outlook plugins such as Live Search Maps or other plugins which change the default Message Class "IPM.Appointment" to some other value. Once the plugins have been removed, verify if those calendar events revert back to the Message Class of "IPM.Appointment" so that you can sync the calendar data to iPhone/iPod touch. If you are able to sync, try adding the plugins back one at a time and verify that you are still able to sync.
  2. If removing the Outlook plugins does not change the Message Class value for the calendar events, manually change the Message Class value of those calendar events to "IPM.Appointment." For more information on Message Class and how to change the Message Class fields/value, refer to Microsoft's KB article 201087 How to update existing items in an Outlook folder to use a new custom form
Apr 06, 2010 | Apple iPhone Smartphone
I have the iphone 3G and i dont know how to view the picture messages that are sent to me, how do i view them?
They should show up just like a text message. If you have not updated the phone to the latest carrier settings then the mms will not work. Simply connect the phone to itunes and it will ask you if you want to update (not just the standard update, but update carrier settings). After the update is complete, you may need to reset the phone for the mms to take effect
Dec 04, 2009 | Apple iPhone 3G
IPhone locked ?
update to 3.0 software nd follow this http://www.youtube.com/watch?v=MZNApm_Nmtk . :)
Jun 30, 2009 | Apple iPhone Smartphone
Update version of imate etrust antivirus
etrust anti virus to down load exact location pl advise
Sep 01, 2008 | i-mate PDAL Pocket PC
USB 2.0 device
All you have to do is Windows update! Sorry, everybody has to update their version of Windows. If you want windows to let you know when there are important updates I can show you how to set this up. Open control panel, open the icon System. Click Automatic Updates tab. You will see you have choices. Pick one. Click Apply & than OK. After your computer is all updated try your iphone again. I'm sure it will be fine. Good day!
Please vote......
Jan 11, 2008 | Intel Motherboard
Gmail on iphone
set GMail to not archive or delete mail after it is downloaded.
Sep 21, 2007 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
54 people viewed this question
Top Apple Cell Phones Experts
David
Marvin
Marvin
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
