Question about GE GFSF6KKYBB 25.9 Cu. Ft. French Door Refrigerator with Icemaker
Where is drain tube in ge model top freezer refrigerators
freetek
  • 5568 Answers
SOURCE: GE built in Fridge does not defrost and freezer ices up
Defrosters are commonly controlled by a primitive timer and this may have a 'dry' and a 'wet' (humid) climate setting that will cause the defroster to cycle generally every 12 or 24 hours.
If set wrong (by accident or on purpose), it can allow too much frost to accumulate before attempting to defrost.
This can cause a gradual buildup of ice.
Also the heating element for the freezer may have failed open so it never heats at all. The connections that need to be checked are often buried between the in- and outside walls.
The timer is probably still OK since you apparently aren't having a problem on the refrigerator side.
Posted on Jun 10, 2008
  • 4 Answers
SOURCE: Water leaking - GE Profile Refrigerator, Model: TPX21PRX
Check to see if the drain at the bottom of your freezer is plugged. When the refrigerator goes on defrost, the water has to go somewhere. Look below the coils in the freezer section and see if there is ice in the drain.
Posted on Jul 15, 2008
  • 1462 Answers
SOURCE: refrigerator warm on top, cold bottom, blower fan top of freezer not turning
check continuity thro the fan motor and check it is free to turn. also check if power is present at the fan
Posted on Oct 13, 2008
jumptrout51
  • 3361 Answers
SOURCE: how do you unstop the drain line
Remove the freezer back wall and lower panel. Remove the visible ice. Use a hair dryer to defrost the drain hole in the rear trough.
Posted on Mar 13, 2009
  • 212 Answers
SOURCE: How do you unclog the condensation drain on a GE
usually the drain hole underneath the evaporator in the freezer section can restrict with anything from ice to bugs. take a wire hanger and try to run it all the way down into the drain pan. if you have ice then try to poor cool water over it to defrost ice. then use hanger
Posted on Jun 22, 2009
Ice in freezer and warm refrigerator Zisb48dyb
If I remember correctly, GE had a issue with the drain pan as it would clog or restrict and back up in the freezer and in the air return (hence, water under crispers if refer section). GE has a repair kit for this and they have also changed the drain hose to prevent self restricting as it leaves the freezer. This part is an Icing kit part# WR49x10021, this comes with complete instruction as to what your changing and why. This should solve your drain and water problem, if this is what your issue is. I hope this was helpful.
Mar 31, 2014 | GE Monogram ZISS420NRSS 42" Built-In...
My monogram refrigerator leaks water from the upper left side/top of the freezer.It is a model ZIS- 42
you have a blocked/frozen evap drain tube leading to the pan, located directly above the freezer section. in all honesty donot believ this to be a repair homeowner should attemp i would contact an authorized ge servicer.As a maytg/ whirpool servicer myself , i know in our built in refigs we have new heated drain tube/evaporator pans that we installe possible that GE has as well
Mar 14, 2008 | Refrigerators
Our refrigerator is cooling and our freezer is freezing, but there is a leak coming from the freezer area that is dripping down into the refrigerator that just keeps getting worse and worse. Appears that...
Hi maabjcraft,
Have you tried clearing the drain tube?
Your refrigerator has a drain that leads to the exterior drain pan beneath the refrigerator. Occasionally this drain can become clogged resulting in standing water inside your refrigerator. A similar drain exists in the freezer, which when clogged results in ice build up on the floor of the freezer.
The drain is located either on the floor of the refrigerator, beneath the vegetable crisper, or in the wall behind a drain funnel.
Clear the drain by forcing a solution of water and bleach or water and baking soda into it with a basting syringe. If the solution will not flow through, slide a length of 1/4 inch or smaller flexible tubing into the drain tube to push the clog through to the drain pan. Remove the tubing after clearing the clog.
Hope it helps.
Thank you for using FixYa.
May 18, 2011 | GE GTS22WCP Top Freezer Refrigerator
Ge top freezer model tbx211a leaking water on occasion inside fridge
Drain is clogged inside freezer.
Your model number is missing a few characters, but this model should have a black tube coming out of the back side of your refrigerator about 1/2 way from the floor that drains into a pan underneath near compressor. Check this first to see if it is clogged. Carefully pull it off where it enters the back wall (will need to pull out refrigerator to access this) try running a wire into tube to clear and pour water down tubing to make sure it is clear.
Next you may need to pull the back panel inside freezer to excess evaporator coils. Turn off or unplug refrigerator while doing this and pour hot water onto ice build up under coils. Once that is clear and water is draining fine into pan under refrigerator, reassemble and your problem should be solved for a few more years again.
Jan 30, 2011 | Refrigerators
GE TBF17PC top freezer water under vegetable
The drain hole is inside the freezer. you have to take the back panel off to get to it and thaw/clean it out. if this drain stops up it will cause water to run down the back wall of the refrigerator down to the bottom. you can pull the refrigerator out from the wall and see the plastic tube coming from the back of the freezer.
Jul 11, 2010 | GE Refrigerators
The bottom of my refrigerator fills with water beneath the storage bins. It is a top freezer model.
Remove the food and the ice maker from the freezer ( if equiped ) . Remove the rear freezer panel . Using a hair dryer , start in the middle , below the coils , defrosting , until you see the drain hole . Use hot water to help defrost the hole . Once water starts going thru the hole , use a small hose inserted into the hole , and blow thru , to remove any unseen debris in the drain line .
Apr 17, 2010 | GE Profile 21.6 cu. ft. Top Freezer...
We are not sure what the tube coming out the back of the refrigerator does or where it goes for sure. I'm guessing it's a drain or cooling for the fan motor but still not sure. Can you help? Thanks (GE...
If you are refering to the 3/4 " tubing , it's the defrost drain hose from the drain trough to the drain pan under refrig . If it's the 1/4 " tubing , that goes from the water valve to the icemaker .
Aug 27, 2009 | GE GTS22KBP Top Freezer Refrigerator
I have a GE TOP Freezer Model # TBX21JABLRBB
Turn off the fridge. Remove the rear freezer panel inside the freezer. Take a hair dryer and thaw the ice in the drain trough at the rear of the freezer. After it is clear, pour a 1/4 cup of bleach into the drain hole. Adjust the front leveling legs on the fridge to make the fridge tilt slightly to the rear.
Jul 06, 2009 | GE GTS20ICNCC / GTS20ICNWW Top Freezer...
I have a GE TBX25PAXCRWW top mount freezer model. It is leaking water from the light switch. I would assume it is a blocked evap line. Do I access it from the insde of the freezer or outside.
Your problem is a clogged defrost drain . This is accessed from inside the freezer section and by removeing the rear freezer panel . Use a hairdryer to defrost the pan , under the coils . Also , the drain line for your model , is located behind the refrig . So , you only have a short area between the drain hole and drain line , to clear . I would suggest blowing thru the drain hose behind the refrig also , to make sure it is clear .
Jul 02, 2009 | GE J Series 18.2 cu. ft. Top Freezer...
GE GFSF6KKYBB 25.9 Cu. Ft. French Door Refrigerator with Icemaker Logo
54 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
