Question about Tappan TGF320 Gas Kitchen Range
Kenmore elite 790.4637 is overheating during the bake cycle and shutting down with an f1 error code
The range overhears and shuts down
2 Suggested Answers
SOURCE: tappan gas range tgf355 error code f1; what does it mean?
Where can I find the manual of the parts of the rear box of a Galloper 4X4 year 2001
Posted on Jan 20, 2009
I have a Kenmore Elite double oven, model 790.48123801.(4 years old). My wife attempted to operate the self-cleaning feature and 29 seconds later an F90 error message appeared, the oven began to beep
Oven door latch error code. The oven door latched but the control board did not receive a signal that the door was latched.
The only time that the latch is used is during the cleaning cycle.
KENMORE ELITE Walloven Parts Model 79048123801
How to unlock Kenmore oven
Oct 18, 2014 | Kenmore Kitchen Ranges
F1 Error Code : Kenmore Self-Clean Electric Range. Oven wont shut off. I can silence the F1 alert but it keeps coming right back on every 30 to 60 seconds or so. Range top burners work fine, but oven
An F1 error code usually means that the temperature probe isn't sending the correct signal back to the control board. Try disconnecting power to the range for at least a minute. If F1 displays after you cycle power you may need to replace the EOC (Electronic Oven Control).
Dec 05, 2012 | Ovens
My Kenmore Elite Gas Range is reading F1 on the display....the gas burners work on stove but the oven wont work....any ideas??
The F1 error code is a failure of the electronic oven control. This could be caused by a stuck keypad or an internal malfunction of the control. You will need to disconnect power and wait at least 30 seconds, reapply power and if condition still exist you will need to replace the electronic oven control.
You will also need to check if the oven is overheating. If the control has sensed a runaway oven temperature it will display an F1 error code. This could indicate a failure of the oven temperature sensor.
Hope helps.
Jul 18, 2011 | Kenmore 79383 Dual Fuel (Electric and Gas)...
My Kenmore stove when I try to bake the oven shuts off and i get a code of E1-F1-
Hello there
Your kenmore product is a whirlpool product actually. The error E1-F1 indicates that the Electronic Range Control/Clock has been blown. Replacing this piece can easily cost you $150+. but is not too hard to replace ok?
Hope this helps
Best regards Mike
May 11, 2011 | Kenmore Kitchen Ranges
Help! Mt Kenmore Elite Quietpak2 HE3 keeps
F/06 Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
  • Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the Drive Motor
  • Check the MCU
  • Check the Wire Harness
Mar 10, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Whirlpool Electric Oven RBS305 overheats while baking, locks door
The technical manual for your range doesn't show an error code of E2 F2 but all of the F2 codes pertain to the touchpad of the range.
Can you clear the E2 F3 by pressing the cancel button? If not, shut off the power to the range for a few minutes and see if the error code goes away. If the error code remains You should unplug the range from the wall and remove the back panel for the control area. Disconnect the ribbon between the touchpad and the electronic control, clean the end of it and reconnect it.
If this doesn't repair the problem you will need to replace the touchpad on the range. The parts diagram lists two touchpads, they are part numbers 8273575- bisque, and 8272702- white.
Good luck
Dec 18, 2008 | Kitchen Ranges
Kenmore Elite he3t model 11045972404
POSSIBLE COMMUNICATION PROBLEM BETWEEN MAIN AND MOTOR CONTROLLER
Nov 22, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore Elite Oasis HE F1 Error
Im sorry to tell you but you have a bad control board. This was a faulty board from the factory. There is a class action lawsuit agianst whirlpool (whirlpool made the oasis). Try calling to get whirlpool to fix it. Maybe try joining the lawsuit. They have remanufactured the part so the new one wont do that again. Its a great machine when it works right.
Nov 18, 2008 | Kenmore Oasis HE 27087
Kenmore Elite Oasis HE/ Error Code F1
repl/ main control board reason for error code F 1 ,,,nothing else
Nov 08, 2008 | Kenmore Elite HE4 Electric Dryer
Jenn Air Range SCE30600
i would pull unit out adn look for a bad thermostat on back wall wired inline from bake and broil elemnts, probably tripped during a clean cycle or something got to hot, common for oven to shut down because of bad safety thermo, yet stovetop function without interuption
Nov 26, 2007 | Jenn-Air SCE30600 Slide-In Electric...
Tappan TGF320 Gas Kitchen Range Logo
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Sal DeAngelo
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
