Question about Kenmore 74992 Gas Dryer
Dryer will not heat
Kenmore gas dryer 72902 will not heat is there a pilot ishould lightthanks
  • 7 more comments
  • adegrado May 17, 2009
    how easy it to change
    how easy is it to fix
    how difficult is it to change electronic ignition
    how easy is it to change the igination
  • 10,865 Answers
The answer is no, you do not have a pilot light. What you have is an electronic ignition which is faulty. Call in a repairman and you will be back up and running in no time.
Posted on May 17, 2009
  • Joe Hogan May 17, 2009
    Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too.
    The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one.
    Gas valve coils
    Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
    Thermal fuse
    On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
    If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
KENMORE 90 SERIES GAS DRYER NO HEAT IS THERE A PILOT
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jun 27, 2011 | Kenmore Dryers
How do i light the pilot of my dryer
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 25, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
How do I relight the pilot light?
There is no pilot light on many of the dryers of today. They light with a hot surface ignitor.
Here is a tip that I wrote about dryers and no heat on gas dryers...
heatman101
Apr 01, 2010 | Kenmore 72802 Gas Dryer
Dryer heats up then pilot lght turns off, dryer
heatman101
Oct 20, 2009 | Kenmore 63942 Dryer
Pilot working but will not dry completely.
Check the burner vents--both intake and outlet for lint plugging. With the pilot working, it is supposed to heat a thermocouple which generates electricity that opens the main gas valve.
Aug 21, 2009 | Kenmore 74602 Gas Dryer
Drum rotates but does not give off heat
If the pilot will not light then there is an obstruction between the gas line and the pilot. Most times there is a particle that sticks in the pilot. The pilot needs to be disassembled to clear the blockage.
Usually the the pilot is a simple construction and one of the parts has a tiny hole that easily gets clogged. Obviously this needs cleaned.
If the problem persists, the must be a problem further up. check any elements in between. You could try to blow air through the system with various parts disconnected to identify the obstruction.
May 18, 2009 | Kenmore Dryers
Whirlpool gas dryer heat goes on then off then on again
should have electronic igniter that light gas after turned on.
Jan 03, 2009 | Kenmore 73952 Gas Dryer
Kenmore dryer not heating
hi,
1) When this happens, something has interrupted the heat source. Run the dryer for a couple of minutes to see if it gets hot. Be sure you don't have the dial or controls on a non-heat setting, such as "Fluff" or "Wrinkle Control."
2) On an electric dryer, this may mean that the circuit breaker or fuse that controls the power has blown; reset or replace this. Be aware that a dryer may have two breakers or fuses. The motor will run when one works, but the heating element requires both.
3) On a gas dryer, recheck the control's setting to be sure it's not on a heat-free setting. Check the gas valve behind the dryer to be sure the gas supply is turned on. Also make sure the house's main gas valve is turned on.
4) Most modern dryers have electronic ignition instead of a pilot light. If yours has electronic ignition and isn't heating, call a qualified repairperson.
On an older dryer, make sure the pilot light is burning. If it isn't, relight it. You can find directions in your owner's manual, and pilot light instructions are often mounted next to the pilot light on the burner, too.
Thanks for using FixYa
Jan 03, 2009 | Kenmore 63942 Dryer
Does a Kenmore Elite H3 dryer have a pilot Light???
No. They are electronic ignition. just plug it in and hook it to gas and should heat up.
Nov 21, 2008 | Frigidaire FGQ332ES Gas Dryer
Pilot light
Pilot Light? Are you sure? All the gas dryers I've ever worked on were pilot-less. There should be a glow-type ignitor that heats up when the dryer is turned on. When it reaches a certain current potential a gas valve is opened and the burner ignites. How old is this dryer? Maybe this is something I've never seen before.
Jun 05, 2007 | Kenmore 72802 Gas Dryer
Kenmore 74992 Gas Dryer Logo
149 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
