Question about Homelite Consumer Products Backpack Blower/Vac, Carb
Hard to start.runs well once started - Homelite Consumer Products Backpack Blower/Vac, Carb
  • 137 Answers
Some engines are just hard to start, go to any auto parts store and buy a can of "Starting Fluid" spray a short burst near the air intake or near the carbuerator and it should start first pull.
Posted on May 17, 2009
Why does it start very hard but once running runs perfect. Shut off very hard starting again.
This can have diggerennt possibles
1) Weak spark. Once running, higher rpm gives better spark. Check plug for condition and HOT blue spark.
2) Poor initial prime. Check for choke function and fuel delivery.
Jul 01, 2015 | Garden
Why is my truck hard to start? Once it starts it runs great.
Check the fuel pressure before you start it. There is a check valve that maintains pressure when the engine is not running. Do a compression test to find out what the condition of the valves and piston rings are too.
Jun 20, 2015 | Pacesetter ArmorCoat Headers 72C1356 for...
88 suzuki quadrunner 300 idle problems
You could try using petrol rather than gas to start it.
Also run it off petrol rather than gas.
May 07, 2017 | Cars & Trucks
XLT1200 hard to start in water after it has been running awhile. Once starts, runs good. Why so hard to start once the engine is warm?
fuel pump diaphrams could be hard ! compressions all over 100psi minimum pressure? carbs clean ?
Aug 29, 2011 | Yamaha Boating
Well I just bought a kawasaki kx 250f it is very hard to start runs fine after it is running but once it shuts off hard to start also it is tough to find neutral
i had a similar problem with mine starting and re starting hard. my problem was the vavle clerance on the exhaust side. the vavle was so tight it took me 20 minutes or more to start it. once it fires ran fine, a littel hotter than usal. i check the vavles for the proper clearance i adjusted them to manufacture settings put a new plug in and vroom started in less than 5 kicks. also check the acc pump diphram they tend to dissolve with age and use one they got bad or get thin the bike will not run right. once you have checked all of this also change the pluge, always helps to have a fresh plug.
hope that gets you started any more qustions let me know
mr. green
Mar 15, 2011 | 2004 kawasaki KX 250 F
My Macbook computer will not start up once it gets to the light blue screen it has a file/ folder with a question mark
It sounds like your system has corrupted. Put your instal disk in. Start your mac up and hold down the c key. Once it has started check that the hard drive exists by go to the menu bar and selecting the disk utility. If the hard drive shows it means that it is okay. Then run the disk utility check drive and then run the repair permissions. You can then try restarting, if it works then you are back up and running again. If it does not you will need to reinstal your system. You do this by starting up with the instal disk holding down the c key and run the instal script. To keep your hard drive contents you MUST use the preserve users instal which will come up as an option. Do not reformat the hard drive as this will wipe all your information.
If you have been running time machine as your backup operation you could instal a totally clean system and then select the time machine backup once the new system has been laid down using the migration utility in the utilities folder within the applications folder.
If your hard drive does not show up the hard drive is probably a goner and you will have to purchase a new hard drive and instal a fresh system.
Hope this helps
Dec 04, 2010 | Computers & Internet
Very hard to start but once it idles for a minute it runs great any suggestions?
cold start is not working right,, thats why its hard to start, when it warms up a little it runs ok,,,,fix the chock!
Nov 14, 2009 | 2003 Buell Blast
Hard start and occasional stalling
souds like the choke is staying on too long , did you check the chokevacuum pull off they often go bad
Nov 14, 2009 | 1986 Chevrolet Camaro
Hard to start cold but once running is ok
I believe you have a throtle body correct? IF so you have poor fuel pressure, plugged filter of injector.If by some miracle you have a carberated engine the the fuel is leaking from the bowl. Get a carb rebuild kit.
Aug 23, 2009 | 1987 Chevrolet Blazer
My 1991 GMC with a 350 V8 is hard to start. Runs ok once started.
check fuel pump for proper pressure....Also very common is a bad o2 sensor not allowing enough fuel.
Jul 28, 2009 | 1991 GMC C1500
Homelite Consumer Products Backpack Blower/Vac, Carb Logo
310 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
