Question about HP W1907 19-inch Widescreen Flat Panel LCD Monitor
After some time LCD going to black screen till again power on
  • Dayton Computer
    Dayton Computer Dec 25, 2013
    Hi mudaser , I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
  • mudaser
    mudaser Dec 25, 2013
    which type detail .?what do u want to ask from me ?
  • HP Master
  • 1,511 Answers
Do you have a Video Picture for a short time and soon after the picture drops out and the screen goes black?
If so, when the LCD gets warm/hot a Diode shorts out and the screen can shut down. If that is the case, you may need to replace the screen. A technician needs to test the circuit board to see if a short is occurring in that hardware as this could be another fault.
Posted on Dec 25, 2013
Mac book pro. Black screen cannot start but with boot sound
Have you tried connecting an external monitor.
A boot chime means the Mac has passed POST, that the screen remains black initially suggests there is a problem getting image to screen which could mean a bad cable to the LCD or the LCD display its self is having problems.
By connecting to an external display you verify the graphics on the logic board is functional, and it could get you up and running till the display problem is fixed.
Also try powering up and when you hear the chime, hold down the COMMAND+OPTION+P+R keys, and keep holding them till the machine has chimed 3 times, this will reset the 'BIOS' in case there is a glitch there stopping the display from showing up.
Apr 14, 2014 | Apple Computers & Internet
Screen goes squiggly, then black. have been able
best thing to try is a external monitor if one is available - if not then run the test....turn system off..as soon as u power back on hold down the FUNCTION key..wait till u see the test running on the screen before u let go of function !!! it will only take a couple of min to know .....when u see this test run just wait until it asks u if u see color bars..whether u can or cannot does not matter..we want to press N for no on the kb....next u will get the color bars if u can see them the mb is fine and u need to replace the lcd..if no bars were seen then u replace the LCD
May 08, 2010 | Computers & Internet
My Dell E176FP 17" LCD monitor keeps cycling colors -red green blue black then colors again... (More) My Dell E176FP 17" LCD monitor keeps cycling colors -red green blue black then colors again during...
well that could be because the screen is going bad. you might want to get another one or take it in to get it fixed, no more than 100 to fix your screen.
Feb 13, 2010 | Dell E176FP 17" LCD Monitor
The display on my acer extensa 5420-5687 will go black from time to time. All i have to do is close the cover and open it up and the display will be back on again. I may have to do this several times...
Most likely the Power Inveter... though both the power inverter and a failing LCD bulb will produce the same symptoms... Usually when the LCD Bulb starts to go, it will give off Pastel Colors.. Pinks/Oranges.. And Dim or Brighten in a flickering manner... Power inverters when starting to fail will do what you are explaining.. And go on and off until eventually complete failure....
If you have a Sleep Switch/Pin in the upper base of the laptop, check to see if that is sticking ..
Nov 15, 2009 | Acer Extensa 5420-5687 Notebook
Monitor goes black
I also have a hp w1907 monitor which also powered on for a second and then go blank with the power light still on.. it was out of warranty so I had no loss so I took it apart..I found one of the wires broken at one of the backlight bulbs { becarefull they are fragile and there is four of them, two on the top and two on the bottom... and the lcd screen is very fragile } I soldered the wire back on and it all work fine... just remember where all the screen parts go.
Oct 24, 2009 | HP w1907 LCD Monitor
Canon sd600is.Screen is black,takes pics but cannot see images
did you try pressing the DISP button @ bottom right just next to screen near the menu button?
Jul 06, 2009 | Canon PowerShot SD600 Digital Camera
TV was playing, then the screen turned black.
If the screen is black and you have sound then lightly press and shine a strong flashlight against the screen. If you see an image around the edge of the flashlight, an image is being 'displayed'. The problem is probably in the Inverter/CCFT or the power going to the Inverter.
Feb 01, 2009 | Insignia 37" LCD Flat-Panel HDTV
ECS Elitegroup lcd screen turns black after the unit is switched on after a time
It would be either the backlight behind the LCD or the inverter board capacitors going out, my suggestion buy a new LCD screen.
Mar 08, 2008 | EliteGroup ECS A535 Notebook
Blue screen for a second after power on and then black screen again
Check where your plug go's in to your powersupply if it is well fitted. ////sometimes it dosnt make well connection then you will struggle to get it on.
Oct 13, 2007 | Westinghouse LTV-27w6 27 in. LCD HDTV
Screen not appearing straight away
It could be your LCD backlight giving you problems till it warms up. Turn you computer on and while the monitor is displaying black and the power LED is green shine a flashlight in the lower left hand corner of your screen. Look for the ?Start? button, if your backlight is not working you?ll see a faint ?start? button if you look closely. A 15" LCD monitor is probably not an economically repairable problem unless you have access to really cheap parts and have the skills and tools to do the repair yourself.
Jul 29, 2007 | AOpen F55PS (Black, Silver) 15 in. Flat...
HP W1907 19-inch Widescreen Flat Panel LCD Monitor Logo
59 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
