Question about Razer Sabertooth Elite Gaming Controller For Xbox 360
My xbox 360 razer sabertooth controller won't turn on
Xbox 360 controller won't stay on
just buy a plug in and play it cost about 10pound or 10 euro
Jun 21, 2012 | Microsoft Xbox 360 Controller
My xbox 360 wireless controller won't turn on
If it has a rechargeable pack on it try swapping it out with a "AA" battery pack. sometimes the rechargeable batteries can go bad. If the controller still won't turn on then you have an internal problem and you will need a new controller. :)
Or you can try getting your controller fixed, although there in not very many people that are willing to work on controllers
Nov 14, 2011 | Microsoft Xbox 360 Console
E73 won't turn on
E73 error is a hardware error linked to the Ethernet controller or other communication controllers.
I'd recommend calling Xbox support. The number is 1-800-4MY-XBOX
Hope this helped,
Dan
Oct 08, 2011 | Microsoft Xbox 360 Console
My xbox 360 controller won't turn on? I was just
your controller is broken because something (a chip) inside the controller has been misplaced. did you ever have the controller be hit or thrown? if so, this is the case. i recommen just getting another1, unless you can mod the controller. otherwise, i am sorry to say, it is broken.. hope this helped
Jun 07, 2011 | Microsoft Video Game Consoles & Games
None of my wireless XBox 360 controlers will connect to to my XBox 360. I have tried replacing batteries, syncing it with the system, turning my system off then on again, removing any obstructions near the...
If the wireless controllers won't connect under any circumstances even with the Charge-and-Play Cable then you most likely have a problem with a board inside your 360, i think it's like the RF board or something, mind you, the C-P cord only forces through an electrical charge and does not force the controller and console to connect, it just works when your batteries are low, in the event that your console is faulty, you can purchase RF boards and replace them yourself (voids the warranty but takes 20 minutes) or send it into XBox HQ (gives you more warranty but takes like 6 months)
Apr 16, 2011 | Microsoft Xbox 360 Controller
How do you turn on an xbox 360?
Simply press the big button that has green lights around in front of your console
Apr 21, 2010 | Microsoft Xbox 360 Console
My controller and xbox wont connect
To connect the controller to your Xbox 360 console, follow these steps:
  1. Press and hold the Xbox Guide button until the controller turns on. The Xbox Guide button is the round button with the green "X" near the center of the controller.
  2. Make sure that your Xbox 360 console is turned on. If your Xbox 360 console is not turned on, press the power button. The power button is the large round button on your Xbox 360 console.
  3. On the Xbox 360 console, press and release the Connect button. The Connect button is the small round button on the Xbox 360 console.
  4. On the controller, press and release the Connect button. The Connect button is the small button on the front edge of the controller, between the left bumper button and the charging port.
  5. After the Ring of Light spins and flashes one time on the controller and on the console, the controller is connected. The quadrant on the Ring of Light that remains lit indicates the position in which the controller is connected.
Aug 28, 2009 | Microsoft Xbox 360 Wireless Controller
XBOX 360 Wireless Controller PC Connection Problem
WARNING: try at your own risk!
I kind of fixed it. The problem appears to be with the USB controller - specifically, my mouse (a Razer Copperhead) and the XBOX 360 wireless receiver. A lot of work went into the solution, but I essentially ended up uninstalling and unplugging all of my USB devices (you can uninstall them using device manager in System Properties>>Hardware within Control Panel. Look for Universal Serial Bus and uninstall everything in that category). Reboot. Then, I first plugged in the device in question (my 360 receiver). Afterwards, I one by one plugged in each item until I found the one conflicting with the receiver (my mouse). After that, I uninstalled all devices again and next uninstalled the drivers for the conflicting device (my mouse in this case) and rebooted again. After this, I tried several times to uninstall and reinstall the mouse and various USB devices until finally it worked (sort of).
I call this a partial solution because now I appear to have the opposite problem. My mouse seems to be conflicting with another device (probably the 360 receiver). My mouse refresh rate is very choppy. The good news (for me) is that I can uninstall the USB controller for the mouse, reboot, and both the 360 controller and the mouse will work fine... that is until shut down. Then I have to uninstall the mouse controller and reboot again. Needless to say, I keep my computer on more than usual now.
Nov 25, 2008 | Microsoft MS Xbox 360 Common Controller...
Razer Sabertooth Elite Gaming Controller For Xbox 360 Logo
318 people viewed this question
Top Razer Video Game Consoles & Games Experts
James Wishart
Are you a Razer Video Game Console and Game Expert? Answer questions, earn points and help others
