Question about Brother MFC 6490CW InkJet Printer
Unable to clean 5a - Brother MFC 6490CW InkJet Printer
My brother dcp-165c how to clean unable 5A
I FOLLOW AS YOUR STEP ,BUT DEVICE STILL SHOWN "CLEAN UNABLE 5A"
Sep 03, 2014 | Brother DCP-165C Multifunction Printer
Unable to clean 5A for brother printer MFC J220
check for ink levels and also check for rollers and usb connections drivers etc
Apr 05, 2014 | Brother Office Equipment & Supplies
Unable to clean 5a
Sir/Madam
If one of the following messages is displayed on Your Printer,I suggest You Go To Below Official Brother Website For Troubleshooting,
  • Unable to Clean (Clean Unable)
  • Unable to Init. (Init Unable)
  • Unable to Print (Print Unable)
  • Unable to Scan (Scan Unable)
http://welcome.solutions.brother.com/BSC/public/as/sg/en/faq/faq/000000/000500/000065/faq000565_012.html?reg=as&c=sg&lang=en&prod=mfc290c_all
Or If You FaceProble Then Follows Us On For Online
Brother Printer Support
Jan 08, 2014 | Brother MFC-465CN InkJet Printer
Unable to clean, error 5A. Already reset purge counter. Print head clear of any obstructions and moves properly. Unable to determine what error 5A is.
Hi Jason, 5A is usually caused by a bad maintenance unit. The purge cam gear may be broken or too much load on the maintenance unit. Either way replacing maintenance unit should solve the problem.
Aug 19, 2013 | Brother MFC-3240C All-In-One InkJet...
Unable print 5a printer message unable print
how to solution 5a print unable pring Dcp 125 prin
Aug 18, 2013 | Brother MFC 6490CW InkJet Printer
What can i do to fix this prob?clean unable 5a?how do o clean it manualy?
THIS PROB? CLEAN UNABLE 5A MANTANCE UNIT 1.MANTANCE UNIT CLEAN WATAR WTOUT MOTAR 2. CHEAK MANTANCE UNIT SWITCH
Jan 11, 2013 | Office Equipment & Supplies
Brother MFC-465CN says 'Unable to Print 5A'
Hi there
Solution:
· Machine off
· Switch on the machine while holding down the “menu”button until all the leds are flashing on/off. Now you are in “maintenance” mode.
· Press 80
· Press the “mono start” button several times until you see “purge: xxxx”
· Press “2783” in order to reset the purge counter. You will see: “purge:0000”
· Press the "stop" button.
· Press “99” to exit the maintenance mode.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Dec 18, 2009 | Brother MFC-465CN InkJet Printer
Printer message: Unable to Print
5A means that the purge cam stopps abnormally when it is in use. This could be of a broken cam shaft. You have to replace the whole purge unit. This is a service job to do!
Aug 27, 2007 | Brother MFC 420CN All-In-One InkJet...
Brother MFC 6490CW InkJet Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
