Question about Insignia Simulated Rock Outdoor Speakers (Pair)
Sound is broken - Insignia Simulated Rock Outdoor Speakers (Pair)
Hi I have a Buick Enclave 2008 have no radio sound and left gate no sound when opening and left and right signal no sound at all
Sounds like maybe a broken or partially broken ground wire between the lift gate and the vehicle body
Sep 19, 2017 | Buick Cars & Trucks
Is it possible to fix a broken wire
you can repair a broken wire provided you know exactly the pt where the wire is broken..... just turn the wire left and right at suspecious points and listen to the sound..... if you can hear a change in sound at any point, conclude that it is broken there.... cut the wire at that point and solder the wires back in the correct combination to make it work fine...
Sep 24, 2014 | Radio Communications
Start button wont work
did you feel the clicking sound when button is press ? if no clicking sound , then it's the switch broken/wire loosen, if you cann't feel the clicking, then the plastic behind the button broken
Apr 21, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
Car wont start clicking sound
1-starter stuck. find a small hammer and hit to starter slowly few times.
2-neutral park relay is broken or its connection to shifter broken. find relay in relay box check for continuity. remove relay from its place give 12 volts to pin 85 and 86 you will normally hear a click sound. if no sound relay is broken.
Nov 25, 2011 | 2000 Acura TL
No sound, looks like it's broken, the microfone is oke
99 % of sound issues are with drivers. Reinstall the drivers for sound after deinstalling them.
Use the drivers from the acer website only
Use external speaker or a headset. If there is no sound either youknow its not the speakers of the pc or laptop that are broken
good luck
rene
May 27, 2011 | Acer Computers & Internet
Heard a pop sound/TV screen went black but there is sound.
Pop sound would be broken lamp in tv, when did you replaced last time lamp in this tv?
Check lamp of tv that would be broken, replace it to solve your tv problem.
Let me know if you have additional question.
Thanks.
Nov 28, 2010 | Sony KDS-50A2000 50" HDTV
There is a loud sound coming from the engine which sounds like marbles
Maybe it is marbles or tennis balls,just kidding.This sound like your piston rods are cracked or broken. This is a very serious problem that needs to be fixed so your not stranded somewhere.I am not exactly sure because I have not heard the marble sound that you are talking about but that's the sound that a cracked or broken rod makes.
Oct 15, 2010 | 2006 Dodge Grand Caravan
In regards to my Sony KDF-E42A10 I heard a pop and the picture and sound went out. The green light just blinks and there is no picture or sound. What could be the problem?
I disagree with info given by expert.
Pop sound would be broken lamp in tv, take out lamp from tv and check it, replace it if found broken.
Usually lamp got broken at end of its working life span.
Aug 06, 2010 | Sony KDF-E42A10 42 in. LCD Television
Display flashing Hello and clunking sound from DVD RW. Will not change from Hello nor will it open or close
sounds like you have broken piece moving around on the inside or broken dvd inside my youngest son put a music cd in my dvd player and didnt put it in right and it broke causing player to make clunking sound and door refused to open. The broken cd was found when player was opened up and sorry to say the tray was broken because of it
Aug 09, 2009 | RCA DRC8030N
Sound card is not god
Are you sure the sound card is broken !!! Or are the correct drivers Installed
Nov 17, 2007 | Compaq Presario R3000Z Notebook
Insignia Simulated Rock Outdoor Speakers (Pair) Logo
15 people viewed this question
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Curt Larson
Level 1 Expert
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
