Question about Whirlpool Washing Machines
Washing machine takes forever to fill? - Whirlpool Washing Machines
  • 1,543 Answers
Turn off supply valves and remove hoses from machine. Look into washer where the hoses were removed from the machine to find the inlet screens. Clean or replace these screens. (usually the cold is the worst) Check to make sure there are no additional screened washers in the hoses which require the same attention. Make sure hoses were not kinked or buldging. Reconnect and turn water back on.
Posted on May 17, 2009
How long does it take to complete a wash cycle
In a perfectly normal washer with decent incoming water pressure it should take 3-5 minutes to fill depending on water level size selected.
If what your experiencing is that your washer does fill yet it takes forever the problem is going to be with the water inlet valve.
GENE
Oct 04, 2011 | GE Profile WPRE6100G Top Load Washer
GWL 11 takes forever to fill with water
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Aug 13, 2011 | Fisher and Paykel GWL11 Top Load Washer
Takes forever to fill water bearly comes out
The water line valves will need to be replaced. The are electrically operated valves so remove all power before replacing them. They are located under the hood, top rear of the machine.
Sep 23, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Kenmore 90 Plus Series washer washer takes forever
is the cold water all the way on?
if so, the first thing to do would be to check the screens in the cold water fill hose and the screen in the cold side of the water valve on the back of the machine. if that is not the problem then replace the water valve.
(turn the water off before taking the hose loose)
Jun 16, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Slow to fill the washer
Here are a couple of tips that I wrote to help people that are having problems with the washing machine not filling...
Washing Machine2_bing.gif Problems No Water
http://www.fixya.com/support/r3880845-washing_machine_problems_no_water
http://www.fixya.com/support/r3880533-washing_machine_fix_washing_machine_no
heatman101
May 10, 2010 | Crosley CAWC529JQ Top Load Washer
Washing machine takes forever to fill on hot wash used similar machine in Australia and had no problems
take hose off at washer make sure your pressure is good if it is then inside the valve you just took the hose off is a screen pop it out and clean
Jan 14, 2010 | Washing Machines
Takes forever to do the laundry
If it is taking forever to fill, take the water hoses off the supply and check for clogged filters. Also, if you have low water pressure in your house, or old clogged pipes, your water is running slow.
Mar 18, 2009 | Bosch Washing Machines
LG WF-T652A Slow water fill
Probably dirty filters in the inlet part of the washing machine. I had the same problem with this model.
Jul 29, 2008 | Washing Machines
Washer takes forever to fill
sediment gets clogged in the valve that cant be cleaned if you replaced the water valve it will solve the problem
Nov 25, 2007 | Roper RAB2121KW Top Load Washer
Washing Machines Logo
Dan Webster
Dan Webster
Sal DeAngelo
