Question about Philips Audio Players & Recorders
Philips HTB7150/98 Stuck in starting mode
The monitor shows 'Starting' but the theater system doesn't seem to be working, cables are connected correctly.
SOURCE: No Sound In Home Theater with Dish HDTV DVR Dual Mode Remote Connection
I have a high definition Polaroid tv which I bought in 2007. I have it connected to Dish tv. It worked fine at first. Now when I use the Dish tv remote, the television won't power up. The red light, which appears when the television is off turns blue when I attempt to turn the tv on, but the screen stays black. Why won't the television come on anymore?
Posted on Nov 02, 2008
  • 3 Answers
SOURCE: no sound though home theater when watching tv
There is an orange button on the remote, half way down in the middle. I belive it has orange lettering and says something like "TV-?" press that, and the sound should start to come through your speaker system. You can then use the original remote that came with your TV and turn the sound off on the TV to use just the theatre system. I noticed that if you use the TV speakers in conjunction with the theatre system, that it echo's.
Posted on Nov 26, 2008
SOURCE: home theater system jvc th-d60
This is from the TH-D50 User Manual:
The connected TV is not HDCP-compatible. (“HDCP ERR” appears on the display.)
Disconnect the HDMI cable and connect it again, or use a shorter cable.
Posted on Dec 31, 2008
  • 15 Answers
SOURCE: How to extend speaker cables of Philips MX6050D DVD Home Theater
Go down to your local RadioShack or any place that sells wire of any sorts (heck, even Walmart might carry it now) and ask them for speaker wire. I'm not sure what the impedance of this particular model is, but you should be able to find it printed on the back of the speakers, or in your user's manual. This guide will help you to identify what size speaker wires you need, that way when you go in looking for speaker wire, you'll at least sound like you know what you're doing.
Posted on Jun 02, 2009
Plasma tv/home theater
Is your Panasonic set to monitor the HDMI input? Just like selecting a mode input on the Tv you must also select the mode input on the surround system.
Bill
Dec 07, 2007 | Televison & Video
Philips 5.1 home theater htb5510d hang in starting mode how to recover from this problem pls help
Sounds like firmware corrupted. It will be best to contact the authorized service center for Philips. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jun 03, 2015 | Philips Audio Players & Recorders
Home Theater System is stuck in "starting" mode
I don't see the starting mode described in the user's manual, so I don't know if the buttons on the remote work or not, but you if they do you can try to reset to restore the default settings. Press the Home button, Select Set up and then press oK. Select Advance - Restore Default Settings and then press OK. Select OK and the press OK to confirm.
Also you might want to check if you can if the software is up to date. Compare the version of your current software with the latest version on the Phillips website.
Dec 27, 2013 | Philips HTS3541/F7 - 5.1-Channel Blu-ray...
Philips HTS6100 -seems to be stuck in Standby Mode....won't actually do anything! Any ideas?
Your unit maybe on protect condition that why on standby mode,,,it means theirs a truoble in circuit inside that why happened...try to consult in the nearest service cnter or a wll trained technician,,wish you luck
Feb 19, 2012 | Sony Audio Players & Recorders
How can i make the tv play through the speakers
Source the TV-related sound (probably from the cable box, huh?) as if it is an external audio device, which it IS. The TV need not be a part of the audio path. Some of us have monitors without speakers. It doesn't seem to be a show-stopper.
Apr 17, 2011 | JVC TH-C3 System
Reset my soundbar
Amp is probable going into protection mode. Disconnected all speaker and av wires (only power) and check if it switches on. Try to plugged it in also at another wallsocket. Presume PSU damaged by surge
Aug 12, 2009 | Philips SoundBar DVD Home Theater with...
Cracking popping type sound coming from front and center speaker
if u are trying to connect the audio of ur tv as input to flow out from the home theater; this is a common thing; u need to replace the audio cable that connects the tv to 3565 with a good quality cable
Apr 01, 2009 | Philips HTS-3565 Theater System
My Philips LX3600D returns always to stand-by mode
The speaker cables for the LX3600D are: (+) is blank, whereas (-) has slightly shaded bands along it. Once you see these bands its easy to open up the connector and check they are the correct way around.
Mar 15, 2009 | Philips LX3600D System
178 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
