Question about Kitchen Ranges
Whirlpool cooktop/oven infinite switch need replacement
9755174 Extendable element Dual range infinite switch not working. Extendable element partly works. How to access the switch for renewal
SOURCE: Help in Removing Frigidaire Smooth Cooktop Burner
What holds the spring assembly onto the bar assembly is just two small prongs. Use a pliers on the end that protrudes through the bar, squeezing the prongs together, and it should come out fairly easily.
Posted on Mar 02, 2008
aborcass
  • 2651 Answers
SOURCE: wiring hookup for a replacement part
hopefull yyou havent disconnect old switch yet. whirpool and kit aid are same Co. same parts used. assuming the correct part was sent for the corrrect burner. diffrerent element will require different rated swties(ie. small , large, dual and so forth.), the indivudal switches are labeled, on the swithc itself ( L1,L2,H1 H2, P1 andso forth, so although the switches looke differnet they should stil have the same lettered terminal to plug into .
Posted on Mar 16, 2008
  • 32 Answers
SOURCE: LG range cooktop
Open the door and just under the front lip of the top there are a few screws that secure it to the body. Then you have to pull the maintop towards you. Its secured by two clips at the back.
Posted on Dec 23, 2008
SOURCE: Oven element started to spark
See this for description of same issue:
http://forum.doityourself.com/appliances-large-electric/255234-ge-electric-range-oven-element.html
Posted on Jan 24, 2009
TheMobilian
  • 8220 Answers
SOURCE: Can someone describe how the
That switch controls the big burner and the middle or bridge burner. It works just like a single burner but it just does 2 functions: I have a video: HERE
Posted on Jan 29, 2010
Cooktop light stays on
Replace the element
Feb 06, 2013 | Kitchen Ranges
Could this be a User Interface,Board 316239500 part problem? or a Electronic Control Board part problem?
Normally, the E.O.C. (electronic oven control) only controls power the ehe bake/broil side for the oven. Doesn't control power to the element. If you have already replaced the infinite switch to that eye, the element itself could be faulty. There is a sensor inside the element that is supposed to communicate with the infinite switch to determine the proper cycling temp for what you selected.
Jan 31, 2013 | Frigidaire GLEF396 Electric Kitchen Range
Hello. We have a Whirlpool Accubake range and we heard a pop and saw a spark under one of our 8" burners. What ever happened tripped the circut. After resetting the circut, the rest of the oven and...
I had a problem with my Whirlpool range. It would not regulate temperature properly on the two large 8" burners. I found the problem was the "infinite switch". The infinite switch regulates temperature of the electric stove elements.
I found this video (see youtube link below) informative and it solved my problem. I found the correct infinite switch on Amazon (my infinite switch was this $21.00 one: https://www.amazon.com/gp/product/B004XLEJ7M/ref=oh_aui_search_detailpage?ie=UTF8&psc=1). The fix to replace 2 infinite switches (both 8" burner switches) took me 1 hour, including cleaning the floor under the stove (nasty!). All was well afterward.
https://www.youtube.com/watch?v=F4gCWNdu2io
Apr 14, 2017 | Whirlpool Accubake RF362LXTB (Dual Fuel)...
My oven does not start
Hello there:
It doesn't work at all dot_lineone.gif 1. No power
Make sure there's power getting to your range, oven or cooktop. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter. Sometimes the power cord disconnects or burns at the appliance, if this is the case, the wiring and the terminal block must be repaired or replaced. ^ top clear.gif Top element doesn't work dot_lineone.gif 1. Top element
If the element only works partially or not getting red hot at the "Hi" setting, the problem might be with a burned out receptacle that the element plugs into. If this is the case, replace both the element and the receptacle.
You can usually tell when the element itself burns out. It might have small holes or bubbles on the coil. Replace the element, if found defective.
2. Infinite switch
Another reason, why the element would not start, might be a defective infinite switch (located behind the control panel, with the burner knob on its shaft). Replace the switch if found defective.
Read more: http://www.appliancepartspros.com/repairtips/repairtips_range_oven.aspx#2-1#ixzz1CZ54wKfT
Jan 30, 2011 | Whirlpool Ovens
Just replaced infinite switch part # 12002125 on Jenn-aire JED8430 cooktop. Now burner will only come on HIGH and does not cycle.
Hello- First of all, congratulations on getting it out, apart, and back together again! There are two types of switches for this cooktop. One for the dual, other three are single. Wires can be a trick sometimes. Replacement switches look different sometimes, but work the same. If part is correct, check wire connections at contact points. Lightly crimp any loose ones. Partselect.com has the wiring diagram for JED8430.  Let me know if this info helps- have more if needed. - Thanks- ED
Mar 05, 2010 | Kitchen Ranges
Control for dual element has to be wiggled just so -so to shut element off, what do I need to fix it? Heats perfectly, shutting it off is my only problem.
The control you're wiggling (infinite switch)needs replacement. Model# and the position of the dual element (right or left, rear or front) is needed to get the part number.
Mar 03, 2010 | Cooktops
Whirlpool rangge radiant element stopped working
It may be a bad element, a bad control switch or a bad infinite switch.
There should be a technical sheet on the back or inside of the oven. Or you can find it here.
You can find links to helpful exploded view diagrams and part ordering help here.
I'd recommend that your bookmark this link to your favorites.
Dec 07, 2009 | Whirlpool Microwave Ovens
Hello, My one of my dual element burner didn't work, would you give me advice which part should I replace, the element or switch infinite? thx.
I have a link to some visual aids you can use to give some ideas how to go about checking as well as a way to get back to me cause I am all over the net tonight:
Nov 07, 2009 | Whirlpool GR460 Electric Kitchen Range
How do I change the element on a Whirlpool Gold range?
If you have replaced the dual element with a new one, and have verified that you have the wiring installed correctly, it may be the infinite switch that controls the element that is bad. That would be the switch behind the control knob for the element in question.
Sep 19, 2008 | Whirlpool GR399LXHS Electric Kitchen Range
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
