Question about Great Northern Popcorn Company Great Northern Paducah Popcorn Machine
When I turn on the pop switch it starts the motor but the agitator doesn't spin
Little bambino popcorn maker
Spinner on a Cretors popcorn popper will not work
If when you pick up the kettle to dump it you can spin the agitator in the pan with one hand easy then it is not stuck. check to make sure the motor switch is supplying voltage to the motor. If that is ok now that you have the front panel off look inside to see if the motor is turning but the drive head which comes up thru the pedistal isnt then the motor shaft pin has sheered off. if nothing is moving at all motor needs replacement. the list on those from the factory are over 600 so make sure its bad first.
Jan 19, 2016 | Cretors Kitchen Appliances - Others
My popcorn maker won't spin the kernels. I think it's the stir rod?
There are many possible problems that will cause your agitator to not spin, But you said the gear in the cabinet comes off easily, it should not.
There is a flat part of the motor shaft that extends thru the top of the cabinet that the gear should be tightened onto with an allen wrench via a set screw. This is the first place to check. When the motor is on, you should not be able to stop that cabinet gear from turning. (not easily anyway).
Oct 25, 2014 | Gold Medal 2131 Antique Gay 90s Pinto Pop...
Nostalgia Popcorn Maker CCP399 - when the popcorn is popped, unpopped kernels come out with the popped kernels. How can I stop this from happening? Thanks!
You cannot. All poppers of that style will a some "fall out". The better commercial machines have very little as the kettles are deeper, but you cannot eliminate it. The unpopped kernels are not reusable.
Oct 24, 2013 | Nostalgia Electrics CCP399 Vintage...
When turning agitator on it gets jammed in the spur gear.
This is a hard symptom to troubleshoot, it can have many different causes.
1. Is the stire wire in the kettle straight and spinning freely?
2. Does the agitator shaft spin freely in the crossbar?
3. Is there a small needle bearing on top of the spur gear attached to the kettle? it is a small metal circle that spins independently of the agitator shaft located ontop of the kettle spur gear, it can fall off.
4. The plastic block in the cabinet roof that has the motor spur gear coming out of it, is it cracked?
5. Does the motor turn when the switch is turned on with the kettle in the dump position?
All of these can lead to an answer of why the agitator stops turning while popping.
Sep 06, 2013 | Gold Medal 2656 Ultra Popcorn Maker
How do I get the agitator rotate
The motor in the top of the machine should rotate the gear sticking out of the top of the cabinet when you turn the switch on. This gear should connect with a gear on the top of the shaft that sticks out of the kettle when the kettle is in the correct upright position and turning the stir rod.
Make sure the kettle is installed correctly, and the switch is in the on position. If the motor is not turning with the switch on, it is broken and should be returned to store if possible.
There are no repair parts for this brand popper, and they cannot be repaired.
Sep 03, 2013 | Nostalgia Electrics Helman Group CCP-510...
Hi, I just purchased an older style washer dryer combo. When loaded (with as little as two towels) it doesn't agitate or spin. Belt is fine. Drum starts to turn but can't make it up the hill. Any sugg
Your motor may be having trouble starting due to a bad capacitor or start winding in the motor. Ideally you want to use a multimeter to test resistance of the start winding.
Jul 31, 2013 | Washing Machines
Can I use the Nostalgia Electrics TPM100 Stirring Theater Popcorn Maker without oil?
No, you must use oil to distribute the heat to the kernels. You can use very little oil, 2 tbls to 1/4 cup. but there must be some.
Popping without oil will result in very pour popcorn.
Jan 20, 2013 | Kitchen Appliances - Others
I DO NOT HAVE COOKING INSTRUCTIONS FOR MY KPM-508 POPCORN POPPER
The instructions say make sure kettle motor is plugged in. Turn unit ON with switch on crown of machine. Allow unit to run for 3-5 minutes to heat up kettle. Turn unit off. Add 2 teaspoons of your favorite popcorn cooking oil to the kettle. Then add 1/4 cup of popcorn kernels to the kettle. Turn the unit on and close the door. When popping sound slows down turn the unit OFF. Flip the kettle over with the crank handle to empty the kettle. Repeat process until desired amount of popcorn has been popped.
Jun 09, 2011 | Nostalgia Electrics Helman Group KPM-508...
Can you use this machine with oil and salt
NO. There should be a little cup / scoop on top of the lid. This is used for measuring the popcorn and then melting butter to pour over it when it's done poping. Then you can add salt to the popcorn.
Dec 28, 2010 | Toastmaster 6203 Popcorn Maker
Great Northern Popcorn Company Great Northern Paducah Popcorn Machine Logo
112 people viewed this question
Top Great Northern Popcorn Company Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Great Northern Popcorn Company Kitchen Appliances - Other Expert? Answer questions, earn points and help others
