Question about Brother HL 1440 Laser Printer
Black spots on my documents Brother HL-1440
We have a Brother HL-1440 that leaves tiny black spots on the paper. It doesn't do it all the time only when we have something that is Really Important. Thanks for any suggestions.
  • chrisstan May 23, 2008
    i have black and maginta spots. The maginta spots showed up after i replaced the toner cartridge. HELP!
Stray dots (on a vertical imaginary line on the page) may not require an expensive drum replacement. In my situation, I simply followed these steps:
(1) Open up the printer, remove the toner-cartridge/drum assembly, and remove the toner cartridge from the drum.
(2) For purposes of reference, place (and center) a sample page of the "offending" output in the bottom of the drum housing, lining up the dots so that the page is turned the way it would have fed through the printer, placing the page generally in front of the shiny green roller surface. Loo, for where any matching black dot or other thing might be sitting on that surface.
(3) Gently roll the green surface's roller with its outside end pegs (without touching the green surface) if and until such a matching dot (or dots) can be found. (Multiple dots might appear along other imaginary verticals on the page, which is to say, additional vertical striping is occurring because there are more instances of "items/dots/garbage" arrayed across the roller on the horizontal, to produce repeat images down the page as the page feeds through the printer.)
(4) Take a Q-tip and very, very, very gently "polish" away the dot(s) you found on the green roller. (I ended up just dabbing the dot I found--which had consistently left a trail of three dots down my pages, in different locations because of the distance the roller traveled relative to the page size--using the absolute least amount moisture to remove it.)
(5) Clean the drum's corona wire by moving the blue plastic slider back and forth, and leave the slider at the far left point.
(6) Reassemble the toner cartridge and the drum and place the assembly back in the printer.
(7) Test.
Worked great for me. Done in around five minutes. No cost, except for the negligible cost of a Q-tip. No time waiting for a new drum to show up, etc.
Posted on Sep 01, 2011
  • Brother Master
  • 1,113 Answers
It can only be the drum unit or the toner unit, both are normal consumables, sound's like the drum is the problem to me I'd change that to fix.
Posted on Oct 17, 2007
How do I clear the memory from my Brother HL-1440 printer?
Printer memory will clear if you simply unplug it from the wall. More likely, the old document was in your computer's disk, and you can control what prints from there.
Sep 11, 2014 | Brother HL-1440 Laser Printer
Brother hl 1440 printing light
Toner empty or due to moisture toner is not distributed or OPC is gone bad
Aug 23, 2012 | Brother HL 1440 Laser Printer
Brother hl 1440 prints fine, except from Microsoft Word. Each time I send a job to the printer, the Alarm and Ready lights flash, and I have to press the button on the front of the printer. There is no...
I suggest you set up your printer to a different website if your in power point or excel or anything else or maybe you don't have a full connection from word to your printer if this is on your phone email to your work computer if you have one or a friend and print it off your email.
Nov 08, 2011 | Brother HL 1440 Laser Printer
I am Bruce of BLACK SPOT, I have a Pavilian dv7-4170us Entertainment Notebook bought 5 weeks ago. Pluged into my Brother HL-1440 printer and it worked fine for a few weeks. Now I cant print anygthing; I...
Either the paper sensor is broken (if it was stuck it'd always think it had paper) or the pickup roller needs maintenance.
Start by taking a lint free cloth moistened with distilled or bottled water and wiping then drying the paper pick roller really good.
If you can get your hands on some Rubber Renu, that's the best stuff in the universe...dunno why they discontinued making it...maybe because it turned plastic to oatmeal...did wonders on rubber though!
Another trick is to pour a tiny amount of rubbing alcohol onto a piece of paper where the pickup roller goes and quickly putting it in the tray and trying to print.
Keep telling the printer to resume or keep resetting the printer and sending another job til it feeds the paper. The alcohol cleans and moistens the roller until it's evaporated restoring the grip of the pick roller.
Clean any other rollers you can reach either with the lint free cloth or q-tips and bottled water or rubbing alcohol.
This should FixYa right up.
If it doesn't, the clutch may be gone in the printer, and you have a real problem. (that' or it's that darn sensor).
Mar 02, 2011 | Brother HL 1440 Laser Printer
My HL 1440 Laser printer does not print The
If your printer have no paper jam inside and paper tray has paper in it, then you need to replace toner cartridge.
Oct 06, 2009 | Brother HL 1440 Laser Printer
Brother HL 1440 Laser printer-horizontal black streaks
check your drum may the corona ware is broken . change the drum.
Feb 27, 2009 | Brother HL 1440 Laser Printer
Brother HL-1440
I'm not sure if this will help, but are you printing from adobe? If the page is a little small on the pdf and you have Adobe set to "adjust paper size to fit document" the printer will keep trying to print to A4, which is smaller than letter.
If the printer itself is doing this when printing from any program than I'm not sure what is wrong.
Did you try uninstalling and reinstalling driver? Do you have the newest version of the driver, i have the same printer and I think online a May 2008 driver is available
Oct 03, 2008 | Brother HL 1440 Laser Printer
Brother HL 1440 Laser Printer Logo
2,753 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
