New filter has been installed on heater but cannot reset filter. Filter light continues to blink.
This is Robertshaw RS3110 thermostat that I am trying to reset.
Therinnaiguy
  • 1420 Answers
SOURCE: Goodman GMPB-75-4 Rev 13
Is there a diagnostic chart either on the reverse side of the blower door or in your owners manual. It may help you to narrow down what is going wrong.
Operate the furnace with the access door off of the furnace and the blower door switch taped on. Watch the furnace and document what happens. Note if the flame starts but goes out in a few seconds and let me know what you experienced.
Posted on Nov 17, 2007
Therinnaiguy
  • 1420 Answers
SOURCE: how do i stop the filter message blinking?
go to www.honeywell.com, there they have a search engine. Put in your model number of the thermostat and look for the users manual.
Posted on Dec 28, 2007
Therinnaiguy
  • 1420 Answers
SOURCE: Filter light & water mark
The tray is if you want to add humidity. You will constantly be filling it. The filter light could indicate a dirty blower or debris slowing down air flow over the heater.
Posted on Jan 05, 2009
  • 70 Answers
SOURCE: short cycling..continually..minimal heat
Is this furnace standing pilot or electronic? if standing pilot turn power off then take t-stat off wall and connect the wires labeled r and c together and see if that keeps furnace working. If electronic check flame sensor you can check flame sensor buy cleaning with steel wool. if that doesn't work then try t-sat.
Posted on Jan 22, 2009
  • 23 Answers
SOURCE: the heater runs and doesn't want to shut itsself off
check the wire to the thermometor then if the wire is ok replace the thermostat
Posted on Mar 03, 2009
HOW TO TROUBLESHOOT ROBERTSHAW GAS VALVE
check the pressure switch if voltage to both sides its ok then check the gas valve to see if voltage at brown and yellow wires
Oct 14, 2014 | Honeywell Robertshaw Grayson Gas Valve Lp...
My robertshaw 9620 thermostat is stuck on 70 and i can not change setting frim temp or time.
Here's how I fixed my Robertshaw thermostat that was stuck at a 70 degree reading for almost 2 monthes. When I turned on the air conditioner or heater it wouldn't stay on. I removed the cover panel and dusted off the inside which the guy at local hardware store suggested. That didn't work. Then I noticed the words "reset" right on the green circuit board on the left side. There's a very small silver button. I pressed on it and everything reset. Less than a minute later the thermostat is reading the correct room temperature. Now my air conditioner and heater are working properly.
Mar 16, 2014 | Robertshaw 9620 digital...
"change water filter" continues to flash when dispensing water
I believe your new Jen-Air has an old model number placed above your post. If you had a newer model nuber I could see if changes were made to the solution. The ods are no changes. I it possible you may have missed removal of te flilter plug? It also is your first time and to press the 2 buttons at same time for 8 to 10 seconds may be a little confusing. I bet after this time you will have this down to an art! here is what I could find without the vorrect model number if that is what happened or not.Jenn-Air
Press and hold the light and lock buttons until the change filter light flashes.
It is very easy to reset your filter indicator light on your Maytag refrigerator. Simply press and hold the light and lock buttons, on the dispenser, for about three (3) seconds, until the change filter light blinks.
Jenn-Air Refrigerators - Press and Hold The Light and Lock Buttons until the filter light flashes (usually 5-10 seconds).
Mar 05, 2010 | Jenn-Air JCB2059G Bottom Freezer...
Blinking symbol
Look for a reset selection on the thermostat. The Filter warning is probably programmed to come up on 90 day intervals.
Oct 20, 2008 | Honeywell Programmable Thermostat Heater
How do i stop the filter message blinking?
Dec 27, 2007 | Honeywell Programmable Thermostat Heater
Goodman heater
Depending upon your installation the filter could be located in the bottom section of the furnace right or left of the blower, remotely located in its own housing in the return air plenum or it may be missing altogether. If you can find a spot to put one in, do it. You may just have to reset your thermostat. Some models have a pre-timed indicator that comes on after a number of hours reminding you to check your air filter. Post the model number of the thermostat and maybe we can help you reset the timer.
Nov 10, 2007 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
49 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
