Will not kick into next cycle
My washer will wash but will not go into the next cycle. No matter where I set the dial it will not kick in.
  • sherrypaints May 17, 2009
    where do I find the model #. I've looked in the washer lid and on the outside. thanks
    Hi vic, I dont have any idea if you have received my correspondence that I did find the model # LSQ8243HQO so now what?
    President:
  • 1,136 Answers
Hi, It sounds like your timer is bad. Can I get the Model # so I ca assist you further?
Thanks
Vic
Posted on May 17, 2009
  • Victor
    Victor May 17, 2009
    If it not on the opening under where the lis closes. Look top back edge of control panel.
  • Victor
    Victor May 17, 2009
    I did get a message that someone wanted to know how to change timer but, I clicked help and it said someone else was helping. Not sure if it was yours or not nut, here's what you can do. If the timer does not advance in any cycle, it needs changed. UNPLUG the washer! There are two screws that hold the control panel to the cabinet. They are located in front lower corners of the panel. The panel will lift up and rest on the hinges. THis is a plastic cover timer. On the back side of the timer you will see a small hole that the knob shaft is in. You will need to pull out the little stem in that hole. Now you have to remove the knob by pulling them off the shaft. Behind the knob, you will find a 1/4" heada screw, remove that.
    Now, looking at the timer from the back side, next to the harness plug ih, you seea little tab that needs to be liftes while pulling the timer out of the control panel. Please let me know how you are doing and if I can assist you further, please let me know.
    If you need to order the timer, please give my web site a chance at www.whirlpoolpartssurplus.com
    Part#3953321
    Thanks again
    Vic
My washer will not switch from one cycle to the next
I understand that your washer is not advancing and stuck on one cycle. If you provide a Model and serial number, it will be helpful.
Jul 22, 2016 | Washing Machines
Washer stops mid cycle
ur drain is stoped up. the drain emptys into the sink plumbing...
Oct 17, 2013 | Admiral Washing Machines
Hello The washing machine is not going through
The lid switch has failed. It will not spin because it is a safety device.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 09, 2010 | Kenmore 22422 Top Load Washer
Washer does not progress through cycle
it might be the pressure switch which in part controls the cycles eg when water enters drum air pressure builds up through a tube connected to pressure switch which has electrical contacts.it is round in shape and if is the fault, it has to be replaced. regards
Jul 29, 2009 | Maytag Washing Machines
The washer stopped in the spin dry cycle. It will not do anything now no matter the dial setting.
Hello.
  • Check the drain control lever
  • Test the drain control coils
  • Check the cam bar
  • Test the timer control
  • Jun 26, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
    Washer fills but won t advance to the next setting for all cycle
    Do you hear the ticking of the dial moving? if so it could be that the points aren't getting connection to cycle it threw the various cycles
    Nov 22, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
    Washing Machines Logo
    100 people viewed this question
    Top Washing Machines Experts
