Question about Frigidaire Kitchen Ranges
Frigidaire PLCF489ccg takes 4 hours to reach 400 degrees
5 Suggested Answers
  • 409 Answers
SOURCE: TAKES TO LONG TO PREHEAT
sounds like the thermostat may be open and nees to be replaced. have a technician take a look at it.
Posted on Sep 13, 2008
SOURCE: I have a Frigidaire Gallery gas range and oven #plgf389aca
i need to shut off the self cleaning on my stove.
Posted on Dec 24, 2008
  • 97 Answers
SOURCE: Takes 20 minutes to preheat.
The unit seems to be working ok....usually the temp probe will reach temp in 5 minutes and it will beep....i sugg for cust to let sit for 15-20 mins for precise cooking.
Posted on Jun 11, 2009
  • 9 Answers
SOURCE: range takes 2 1/2 hours to reach 350 degrees
Check for proper voltage at connection. breaker may be half off. Check for burnt wires
Posted on Jul 21, 2010
How long will it take to cook a 15lb. turkey? From the Utube, I saw 30 minutes at 450
Just cooked a 15 pounder with stuffing wrapped tightly in foil on a rack in a roasting pan at 450 degrees 1/2 hour then dropped to 350 for 4 1/2 hours in a convection oven, the foil keeps the moisture in. Uncover last 1/2 hour for crispy skin
Nov 23, 2017 | Grilling
Why does it take 25 minutes to preheat to around 400 degrees ?
If it's a gas range, I'd guess you have a pressure problem at the source. There should be some sort of pressure regulator at the gas tank. It might need adjusting or replacing. In other words, your oven might not be getting enough gas pressure to create a large enough flame. It should take only five or ten minutes to reach 400 degrees.
Mar 25, 2015 | Whirlpool Accubake SF362LXTS Kitchen Range
How long does it take for water to get warm
if you wire a hot tub on 230v it will take 4-5 hours to reach 104 degrees
Rod @ USPartsCenter.com
May 02, 2013 | Qca Spas Dream Series Dream Master Hot Tub...
How to change the temp in a frigidaire galaxy refrigerator
Units will vary give or take a few degrees from the control panel display. Keep in mind once you change the temperature it will take up to 10-12 hours to stabilize and reach that temperature. If the unit is not cool, even at the bottom of the refrigeration portion (where the coolest air will be found) then contact a professional to diagnose the control pane and board.
Dec 29, 2012 | Frigidaire FGHB2844L (27.8 cu. ft.) French...
Frigidaire gas stove/range heating problem
it might just need a good cleaning sometime dust and soot builds up and needs cleaned out of the burners but you can check the thermomitter with a multimeter ohms test if current flows through it
Oct 26, 2009 | Kitchen Ranges
Dec 11, 2008 | Kitchen Ranges
Gas oven temp problem
HI thanks for your question. there is a oven sensor , located in the oven, top left corner. replace this part. thanks the appliance doc. please rate my answer. thanks
Oct 11, 2008 | Frigidaire Ovens
Freezer alarm
Upright freezer door was ajar, alarm went off. Where is the reset button? Product is Frigidare.
Jun 02, 2008 | Frigidaire 20.6 cu. ft. / 583 liter...
Self cleaning oven instructions
I tried pressing clean then the up arrow. Nothing. THEN I HELD DOWN THE UP ARROW FOR A FEW SECONDS AND 3 HOURS CAME UP AND it worked and my oven is now cleaning itself. Remember...HOLD DOWN the up arrow for a few seconds and it will work
May 26, 2007 | Frigidaire FEF352 Electric Kitchen Range
Kitchen Ranges Logo
26 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
