Question about Weller Welding Tools
My problem is continuing early failure of your product. I have been in business for 45 years and always selected Weller soldering irons. For the past 5-6 years the quality of your products has fallen off completely I have purchased at least 6 irons which have failed within the first 3 weeks of work. I expect better quality and have begin buying other brands....Terry S. Gilbreth , owner Five Raven Art enterprises
    Top Expert:
  • 46,310 Answers
Terry you have sent this message to the wrong website . FIND WELLER and try again.
Posted on Jun 19, 2015
Dissolu
  • 221 Answers
SOURCE: repair wiring on weller soldering iron model ec1002
If the coil wire is snaped then you will need to replace all the coil. usually the power from the outlet goes stright to the coil and connects to both ends of it's windings
Posted on Jul 24, 2009
Vanguardian
  • 106 Answers
SOURCE: Weller WMRP soldering iron faling prematurely.
I suggest that you set the "Auto Time Off" much longer or turn it off by setting it to 0, and use a standby of 400 degrees after 10 minutes instead.
The reason is that every time this soldering iron has to turn on, it's trying to heat up in about 5-10 seconds. When it does that, it applies full wattage to the heating element, and putting full wattage on them a lot of times is what's burning them out. If the soldering iron maintains the same temperature while not soldering, it only uses 20-30% of the full wattage to keep it at the set temp. This isn't nearly as hard on the heating element.
Posted on Sep 11, 2009
  • 33 Answers
SOURCE: I have a Weller 1002B soldering station. Haven't
Hi, I'm not sure the tip is defective. Check that the tip is screwed in tight. If it is not good and tight the tip will not get a good heat transfer from the solder wand. Hope this helps. If the wand will heat then the tip should.
Posted on Aug 30, 2010
  • 185 Answers
SOURCE: The tip of my weller
This happens quite frequently. On the tip there are two nuts that hold the tip to the gun. Tighten them a bit. The tip is made of copper and as this heats, it causes the connection where the nuts are to become a higher resistance and thus lower heat. When you tighten them, it "cuts" through the copper oxidation (caused by the heat) and lowers the resistance, hence more heat.
Posted on Jan 12, 2011
  • 5 Answers
SOURCE: Hi i have an old
A soldering iron is composed of a heated metal tip and an insulated handle. Heating is often achieved electrically, by passing an electric current (supplied through an electrical cord or battery cables) through the resistive material of a heating element. Another heating method includes combustion of a suitable gas, which can either be delivered through a tank mounted on the iron (flameless), or through an external flame.
Posted on Sep 20, 2011
Cold iron
if under warranty - return it
Apr 19, 2014 | Weller HEW100P - Heater Assembly for W100P...
The solder station (power unit) is turning itself off randomly
I have heard that some of these had a failure on the regulator circuit that was packaged on a ceramic substrate with the control pot. Not sure if yours is this type.
Jan 17, 2011 | Weller Wesd51 Digital Soldering Station...
In the year 2020 day 202 we will not need soldering iron, they will be archived with the world's people. Cockroach's will be running the world and eating Twinkies. By the year 2025 the cockroaches will be dieing off do heart failure from eating Twinkies. The next 2020 years Twinkies will be live and well with the all chemical preservatives they--that is Twinkies....
Twinkies, walk Gentry upon this earth, and do no MAS' and this earth will be good to you, Twinky.
GB...stewbison
Jul 04, 2010 | Weller D550PK Professional Soldering Gun...
NEED MANUAL FOR Weller soldering station WESD51 POWER UNIT
You can download the manual from here: http://www.weller-toolsus.com/MagentoShare/media/mannuals/WES51_OI_PL.pdf
Jan 19, 2010 | Weller WES51 SOLDERING STATION
Welding Tools Logo
696 people viewed this question
Top Weller Welding Tools Experts
Lawrence Oravetz
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Weller Welding Tool Expert? Answer questions, earn points and help others
