Question about Westinghouse Dishwashers
My dishwasher just stop working i turn the dial nothing happends ive checked if its getting power and it is any ideas
    Problem Solver:
  • 18 Answers
There may be an internal fuse which has blown there may be one on the pcb
Posted on May 17, 2009
Dishwasher stopped working
Open it up and use a tester.
Jul 24, 2015 | Washing Machines
My 1993 nissan pathfinder wont start i get power to everything but when i turn the key nothing happends i replaced the starter and still wont start nothing happends not a sound could you please help
wire may be loose or your ignition switch could be bad hard telling if it was me id just install push button start cheap and easy to bypass all that
Dec 05, 2012 | 1993 Nissan Pathfinder
Dishwasher won't start
its the timer in the dial replace it and it will work fine yes its worth fixing
Dec 03, 2012 | Kenmore Dishwashers
Ive had my book for a while now and my life is on it... it was working fine and now i plug it in and nothing happends... it wont spend and the blue light wont even come on.... i check the cables and the...
#1 MAKE SURE THAT YOU HAVE ENOUGH LIGHTING .....I KNOW BECAUSE I'VE DONE THIS. I PLUGGED THE DRIVE SIDE USB INTO THE LOCK SLOT IN BACK OF DRIVE INSTEAD OF THE CORRECT SLOT......HOPE THIS HELPS..........JEFFXC
Feb 07, 2011 | Western Digital My Book Essential 1TB...
Our Nautilus dishwasher won't turn on. I can hear a buzzing noise, but nothing is happening. Does anyone now what I should do?
The same thing happens with my dishwasher. I have made it work by doing the following. When you start up the cycle, turn the dial to just a tick before "start." If you hear the buzzing, but no water is running, unlock and then lock the dishwasher door again. This usually gets it running. If it's still not running water, unlock, advance the dial a little bit, and lock again. This should work. You need to be around for the early parts of the dishwashing cycle because this machine tends to stop up and buzz without running water until it gets past "short wash." Every time this happens, do the same thing, unlock and lock, and advance the dial a little when necessary. Once you get past "short wash," it should complete the wash without intervention.
Feb 22, 2009 | GE Nautilus 24" Built-in Dishwasher
GE Dishwasher not working...
Sounds like you have a one of four possible issues. More info to diagnose would be helpful. (age, which mid cycle) If the motor runs when you turn the timer dial than it is a belt/motor pump issue. If the motor does not run than a bad motor start switch or the water level switch. More than likely the motor/pump assembly as this is usually the problem on these models. If newer check with whirlpool the manufacturer to see if it is covered by warranty.
Nov 06, 2008 | KitchenAid 24 in. KUDI01TJ - Multiple...
Dryer shut off towels were not yet dry, turned dial to restart dryer acts as if it isn't getting power I closed door and pushed start button. Nothing! Checked breakers and power cord at outlet all checked...
Hello mdonettaYou said,
Dryer shut off towels were not yet dry, turned dial to restart dryer acts as if it isn't getting power I closed door and pushed start button. Nothing! Checked breakers and power cord at outlet all checked okay. Any ideas.
yes, try unplugging the power cord or turning off the breaker for 5 minutes. Either will due. Some times the system needs to be reset!
If this does not work there are internal fuses that can be replaced!
Let me know how it goes!
Huuum
Sep 19, 2008 | Dryers
GE Nautilus wont start
Looks like you need to replace the timer/cycle panel on your appliance.
Try first unplugging machine for 20 minutes, to see if this reset can fix the problem.
Aug 28, 2008 | GE Nautilus 24" Built-in Dishwasher
Stopped working altogether
Check the door switch, it may have gone bad or maybe isnt connecting with the catch, making it look dead. They wont do anything when the door is open, as you know. Also remove the lower panels to get to the inside of the dishwasher. Check for power where the cord is plugged into the machine. If you have power, unplug it and look at the terminals to the heaater element. They are on the right side, facing down out of the dishwasher tub. Just look inside the dishwasher to see where the heater goes through, then look in the same place underneath, Check the condition of these connections. The timer gets power through the heater element (strange but true) so if the heater is bad or these connections have heated and melted, it will cause a dead dishwasher. if tis just the connectio, pu t a new terminal on it and you should be good to go. Hope this helps
Jun 19, 2007 | Asko D1716 Built-in Dishwasher
Dishwashers Logo
65 people viewed this question
Top Westinghouse Dishwashers Experts
Denis FixYa...
Denis FixYa...
Are you a Westinghouse Dishwasher Expert? Answer questions, earn points and help others
