Question about Summit SPWD1800
Door wont lock
Door will not lock
98 accord door handle broke door will not open
A non electric door, (which?) wont open,lock works ok, handle wont open the door.
What can I do to fix it.
well telling the door to us would help, and options.
so no electric locks,
there are 2 levers. one inside and one outside.
so you pull the door card (inside door covering)
and look at both locks , the inside pull, its it working?
then look at the key lock cylinder. is it connected still
and last are both connected to the latch mechanism.
one can cycle this latch lever inside the door shell.
if that fails the latch is busted.
all this is covered in the FSM ,why not read it.? (under body)
free , too.
http://hondatech.info/downloads/Auto/Manuals/Accord/
Nov 25, 2013 | Honda Accord Cars & Trucks
Hoover nextra washing machine door wont lock / cycle start
sounds like the door lock mechanism. if this cannot signal it has engaged, to the board, no other function will work (you don't want the washer going with the door open, trust me :) )
Nov 08, 2013 | Hoover Nextra 160 HNWF 3137 Front Load...
Door lock was pushed down and now lock wont come up and door wont open
I will have to get back to you on mine is same just have not had time to look under door panel yet sorry
Mar 01, 2013 | 1995 Ford Explorer
Washer wont turn on. code is F dL. any thoughts?
"dl" indicates a door lock error. A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
Check for the following when dl occurs:
  • Door Lock Mechanism broken.
  • Check Door Lock/Switch Assembly for foreign objects
  • Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
Thank you !!
Jul 07, 2010 | Whirlpool GHW9400SU Front Load Stacked...
Power door locks, and power side windows wont owrk
check wiring at drivers door hinge inside protectve loom,should find broken wiring
Oct 04, 2009 | 2004 Pontiac Montana
406 hdi pass door lock wont lock so car wont lock
Remove the door pannel and spray releasing oil over the central locking solinoid.That should sort it for you good luck.
Sep 02, 2009 | 2005 Peugeot 405
Driver side door wont lock
I work at a car dealership and usually turns out to be the door lock actuator itself if everything is working as you say.
Aug 19, 2009 | 1999 Chevrolet Blazer
Rear door wont unlock or sometimes wont lock
The rear door lock actuator needs to be replaced. If you have the dealer do it you will pay $300.00+. If you do it, you can do it in an hour for about $20.00. Just buy a universal actuator kit that looks similar to the one already in there from the factory. Do A Google Search on "Mazda Tribute Rear Door Lock Actuator" to find sources for them.
This is a VERY common problem on Ford Escapes and Mazda Tributes, all years. I am surprised there has not been a recall on this.
Jul 18, 2009 | 2002 Mazda Tribute
My volkswagon door wont lock?
the door lock or actuator that needs to be replaced Please rate my response thank you very much
Jan 30, 2009 | 1998 Volkswagen Passat
Drivers side door lock
is the lock mechanism siezed,or is the linkage disconected?
Jun 08, 2008 | 1999 Chevrolet K1500
Summit SPWD1800 Logo
Top Summit Washing Machines Experts
ray gallant
Dai Boyce
Dai Boyce
 Russ Hill
Russ Hill
Are you a Summit Washing Machine Expert? Answer questions, earn points and help others
