Format kingston dti gb data traveler - Computers & Internet
SOURCE: driver for data traveler 4gb pendrive
hi sir place send me kingston4gb pan drive drivers win98
Posted on Mar 23, 2009
  • 3 Answers
SOURCE: USB DRIVER NOT INSTALLED
If you need to install a driver for a thumbdrive, you might be able to get away with defining it as a standard "USB Mass Storage Device" in the drivers. Find the device in Device Manager then follow these steps.
Right click the device, select "Update Driver"
In the new window that pops up, select "Install from a list..." Click Next.
In the next page, select "Don't search, I will choose a driver to install" Click next.
In the Hardware Type Window: Select and double click "Show All Devices"
Click the Have Disk button
In the text box: type "c:\windows\system32\drivers\usbstor.sys". Click Ok. Click ok once more
Click next to proceed through the driver install.
This is one possible solution to get your thumb drive communicating.
Posted on Jun 25, 2009
bob_computer
  • 3153 Answers
SOURCE: i could not open by kingston data traveller 2.0..
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
Posted on Sep 14, 2009
bertus_kriel
  • 121 Answers
SOURCE: my kingston 8 gb data traveller suddenly became
try maybe it is bricked or damaged, try downloading Pheonix products which can help u repair any usb damaged storage media, worked on my 8gig usb and nokia n95, or u can try googling flashing utilities for you flash
Posted on Oct 07, 2009
SOURCE: kingston 4 gb data traveler 101 cannot support 98 se windows
http://www.kingston.com/support/USBFLASHDRIVES/downloads/default.asp?s=DTI_HS
try this
http://cr.am/framed.php?url=http%3A%2F%2Fwww.kingston.com%2Fsupport%2FUSBFLASHDRIVES%2Fdefault.asp&ref=driverguide#
jawaidarshad
Posted on Dec 09, 2009
Kingston dti/2gb usb fd file system is unknown
might be encryoted,, format if you do not need the information
Jan 12, 2014 | Kingston DTI/2GB Data Traveler 2 GB USB...
Flash drives says when it open that needs to format first before it used?
it because there are a a logical eror
just format it but you will lose all data
to format (on windows 2000/XP) right-click on the key icon and click on "Format" then a litle windows apair on t press "Format" bouton
Oct 27, 2012 | Kingston Data Traveler 2 GB USB Drive...
Kingston data treveler not format
Hi qais_baba
1...Plug your Kingston data traveler in to your computer
2...Go to desktop and open "My Computer"
3. You will see your Kingston Data Traveler listed there
4...Right click on the Data Traveler
5...Click on "Format"
This will format your Kingston Data Traveler
Please rate me
Bud
Sep 25, 2012 | Kingston DataTraveler 101 G2...
How to format DTI/2Gb
click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start or you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
I found that you get best results by ticking one box then returning after it has finished then tick the other box
If you need more help with this or if i have missed the problem post a reply
hope this helps you
Oct 27, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Kingston Data Traveler 2.0 64 GB USB - file system corrupted - need to work on windows XP- Upon formatting the pen drive It shows that it has become a raw drive - wat is the file format for the USB to work...
Theoretically, you can't format a more than 32 GB drive with FAT/FAT32 file system. In your case you have to choose the NTFS file system to format your 64 GB USB flash drive. However, if you really need to format it with FAT32, you got to use the command line or a third party tool. Hope this is going to help you.
Apr 06, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Cannot format my data traveler DTI/8GB
hi
may be its infected with virus
try to Do a virus scan on another laptop or pc
or do a disk difragmentaiton & than try to reformat it
Thanks
Jan 03, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Can't read Kingston DTI/4 GB flash drive
you have to see in witch format is the stick mostly is FAT32 but normaly you dont need to format just when is some video on it,from my experience reinstal the drivers and i mean all.
Nov 04, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
32 gb kingston pendrive makes my laptop hang
This is a bug from the operating system, turn off you're laptop, plung the stick and power on the laptop.
Dec 16, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Computers & Internet Logo
81 people viewed this question
David Payne
David Payne
