Question about Cuisinart Cusinart 5.5-Quart Stand Mixer
Mixer does not turn on
Mixer will not reset itself
My Kitchen aid Ksm90 mixer got a little noisy, then it just wouldn't even turn on. What could be wrong with it?
You have possibly blown the fuse gear. Need a bit more info on the noise. If you turn it on slow and help the planetary does it try go get itself going?
Jan 16, 2015 | KitchenAid Kitchen Aid Ultra Power Tilt...
Drive Shaft stopped kneading dough
To give the mixer strength it has planetary gears. Something may be wrong in the gear section
Nov 26, 2013 | Bosch 800-watt Universal Plus Mixer with...
Mixer went into over load useing a stactic converter wont come back on no noisewhen turn on
This sounds the thermal reset is tripped have you looked for a red reset button on the mixer? that is usually what fixes that
Feb 28, 2011 | Hobart HL600 Legacy Stand Mixer
Mixer will not turn on. Is there a reset button?
There is no reset button. More than likely the speed control plate is bad. This is a common problem. I recommend storing the mixer unplugged and on the first speed. Also don't store it with the beater, whisk, or hook attached to the mixer. This may help save the control plate contacts from becoming sprung. Fixmymixer@aol.com
Feb 19, 2011 | KitchenAid K45SS Classic Stand Mixer
Have power to mixer but no lights and doesn't turn on......
If you raise the mixer arm you will expose a reset button that may have been tripped.
Cheers, immorion
Oct 03, 2009 | Kenmore KSM100 Stand Mixer
It's completely dead - won't turn on. worked fine
You need to remove the motor and find the heat protection fuse on the side of the windings. The fuse is rated at 140 and has a red tip. You might be able to get one from Radio Shack but Viking sells them for $3. Solder into place and take care not to overheat while doing so.
Jun 30, 2009 | Viking VSM700 Stand Mixer
Mixer stuck
It sounds like you burnt the motor out or shorted the speed control.
Dec 24, 2007 | KitchenAid KSM150PS Artisan Series Stand...
Cuisinart Cusinart 5.5-Quart Stand Mixer Logo
42 people viewed this question
Top Cuisinart Food Mixers Experts
Ross Keen
john h
Are you a Cuisinart Food Mixer Expert? Answer questions, earn points and help others
