Question about Cell Phones
How can I disable forward when unreachable in samsung s duos
2 Suggested Answers
alchiecez27
  • 641 Answers
SOURCE: Samsung galaxy ace duos S6802 incoming call always
When a Samsung cell phone becomes unresponsive or when the device slows to a crawl, a reset may be in order. There are two primary methods used to reset the phone. Users should always start with the soft reset when the phone locks up or programs slow down due to memory or software response issues. A soft reset is akin to a reboot of the machine and usually solves most problems without any loss of user data. A hard, or master, reset is required when the phone completely locks up and becomes unresponsive to any cellular signals. This second and more drastic reset deletes all personal data, preferences and settings so that the device is restored to the original factory configuration.
Perform a Soft Reset
Step 1 Press and hold the power button for 10 to 20 seconds.
Step 2 Release the power button and tap the "Power Off" option under the "Device Options" menu that appears. Tap "OK" to initiate the shutdown.
Step 3 Press the power button again to restart the device.
Perform a Hard (Master) Reset
Step 1 Tap the "Menu" key from the home screen and then tap "Settings."
Step 2 Go to "Privacy" and tap "Factory Data Reset" to review the Factory Data Reset information.
Step 3 Review the Factory Reset options. Place a check next to "Format USB Storage" to clear your device of user data, such as music, pictures and other account settings.
Step 4 Review the disclaimer and verify your changes before tapping "Reset phone."
Step 5 Tap the "Erase Everything" or "Yes" buttons to confirm the reset the phone to factory settings. The device initiates the restoration process to the original factory configuration.
Perform an Alternative Soft Reset
Step 1 Power off the phone. If the phone does not turn off, remove the back cover of the phone and take out the battery. Wait between 10 and 30 seconds and then replace both the battery and the cover to restart the device.
Step 2 Simultaneously hold down the power/lock keys.
Step 3 Release the keys when the Android screen appears.
Tips
  • The ATT Samsung SII models have an alternative hard reset that requires you to simultaneously hold down the "Volume Down" and power keys after an alternative soft reset, and then release the power button, bringing up the menu titled "Fastbook, Recovery, Clear Storage, and Simlock." Use the "Volume Down" key to navigate to "Clear Storage" and then press the power button. Press" Volume Up" for "Yes" and "Volume Down" for "No." This will reset your device to its original factory setting.
  • A soft reset on a Galaxy S phone involves pressing the "Volume Up" key simultaneously with the power button.
  • Some older Samsung models have a reset button located behind the battery cover. Press the reset button using a small, blunt object.
Warnings
  • A factory data reset removes all user data and settings associated with the current account. Make a backup of all data on your device before starting a hard reset.
Posted on May 12, 2014
I forwarded my cell phone calls to my house phone. I cannot deactivate call forwarding. I have a Samsung S7
  • 1.From the home screen, tap Phone
  • 2.Tap More
  • 3.Tap Settings
  • 4.Tap More Settings
  • 5.Tap Call Forwarding
  • 6.Tap Always Forward
  • 7.Enter the number you would like your calls forwarded to and then tap Enable
  • 8.To disable call forwarding, swipe down from the top of the screen
  • 9.Tap the Call Forwarding notification
  • 10.Tap Always Forward
  • 11.Tap Disable
Samsung Galaxy S5 How to Setup Call Forwarding
Feb 11, 2017 | Samsung Cell Phones
How do i block a number on my alcatel one touch pixi 3
Block Calls & Messages:
  1. Open the apps drawer and launch "Contacts"
  2. Tap the name of the contact you want to block calls and messages from
  3. Tap "Edit" > "Menu" and enable "All calls to voicemail"
Unblock Calls & Messages:
  1. Launch "Contacts"
  2. Tap the contact you want to unblock
  4. Disable "All calls to voicemail"
Forward Calls (Unconditional):
  1. Tap "Phone" on the home screen
  2. Tap "Menu" > "Settings"
  3. Tap "Call settings" > "Call forwarding"
  4. Choose to "Always forward" and if necessary, enter the phone number to forward calls to
  5. Tap "Enable"
Forward Calls (Conditional Forwarding):
  1. Open the "Phone" app
  3. Go to "Call settings" and tap "Call forwarding"
  4. Select to forward calls "When busy", "When unanswered" or "When unreachable"
  5. Enter the phone number you want to forward calls to and tap "Update" or "Enable"
Turn Off Call Forwarding:
  1. Open "Phone" and tap "Menu"
  2. Tap "Settings" > "Call settings" > "Call forwarding"
  3. Select "Always forward", "When busy", "When unanswered" or "When unreachable"
  4. Tap "Disable"
Read more: http://cellphoneforums.net/general-cell-phone-forum/t381553-alcatel-onetouch-pixi-3-block-calls-messages%3B-forward-calls.html#ixzz4TXeusLlT
Dec 22, 2016 | Alcatel Cell Phones
Hod do i turn call forwarding off
Select Setting on your phone
Then go to call settings
Scroll down to Call Forwarding and click
Select Voice call
Then select where you want to disable
And click Disable
Mar 04, 2015 | Samsung Convoy 3 Mobile Phone - Gray...
HOW DO I TRANSFER MY CALLS TO ANOTHER PHONE?
1. Find "Voice call"
2. Select divert type
3. Divert calls to alternative number
  • Key in the required number and tap Enable.
Aug 28, 2014 | Samsung Galaxy S Iii Gt-i9300 - 16gb -...
What do you mean by forwarding on conditional on?
Forwarding on conditional, means that calls can be forwarded to a different number (or voicemail) on certain conditions.
These could be, unanswered, unobtainable or busy.
Normally you would have this set to forward to voicemail if you are unreachable, or unanswered.
But you can forward ALL calls to a different number if you wish.
Please note that different phone providers can charge for this feature.
i.e. forwarding a call to your home number, they may charge you for forwarding.
May 12, 2014 | Cell Phones
Hi, how doi turn the voice mail off on my samsung jet?
Contact your carrier and have them disable the mailbox. They should also be able to disable or tell you how to disable the forwarding.
Apr 24, 2011 | Samsung Jet S8000 Cell Phone
I have a question about Samsung Duos. Can someone please help???
Yes i can help you.. Can you please put forward your question.
Feb 15, 2011 | Samsung Cell Phones
Blackberry Curve 8310
You have to go to Phone options->Call Forwarding and you have option of forwarding all calls or if busy, if no answer or unreachable. and you can select the phone number where you want to divert the call
Jul 17, 2008 | RIM BlackBerry Curve 8310 Smartphone
Cell Phones Logo
194 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
