Question about Elna Sewing Machines
My elna 6600 wil only sew a few stiches, and then the needle is stuck.
After the first few stiches, the machine jams, and would not work any further. It gives me an error 05, and beeps
MakikiChris
  • 84 Answers
SOURCE: Straight sewing but only a few stitches before stopping
Hi Gaden....It's obvious by your post that you have advanced knowledge in sewing/machines including maintenance, so I feel very confident that your issue can be resolved by updating your software. Please click on the URL below, and download the approriate updates that correspond with your equipment.......Please update your post so I'm aware of your status....good luck my friend http://futura-support.com/downloads/patch.htm
Posted on Aug 04, 2007
SOURCE: Brother CS-6000 Sewing Machine - Jam
I had the same problem.. I think the bobbin used in this machine is no good I replaced mine.. It cost alot too.. but now I do not have any problems.. good luck
Posted on Aug 20, 2008
Mongo32
  • 111 Answers
SOURCE: When sewing the bobin thread tangles and jams
upper tension/threading wrong?
Posted on Jul 08, 2009
kirkx
  • 2019 Answers
SOURCE: I have a janome 8050
The key to proper stitches is that tension on the bobbin must equal the tension on the upper thread spool as well. The bobbin has a tension screw that may have come loose or the thread is not properly in the tensioner. For example, the bobbin could be in backwards. Or the tension of the top could be too light and allowing the tension on the bottom to pull the thread down too much.
Open the bobbin tray and watch while you slowly rotate the hand control to see it make a stitch.
You will probably be able to figure out what is wrong.
Posted on Apr 08, 2011
Tally Girl
  • 1122 Answers
SOURCE: needle stays stuck whilst motor runs. Elna sewing machine
Its a lovely swiss made machine, this is an electronic motor so the needle pressure should remain constant no matter what speed you sew at. The needle staying down and the squealing sounds more like drive issues inside or possibly gunk buildup.
If it was my machine, I would take it to a qualified Elna technician and ask for him to look at it. These machines are small and well made so well worth spending the money to give it a service and get it back to 1000% IMHO.
Posted on Apr 11, 2011
My elna 7000 sewing machine speed all of a sudden is very slow, does not work in reverse, or does not want to make any stiches? What can be wrong?
Looks like this is a mechanical machine. If so, bet it needs a good cleaning and oiling. The following may be helpful:
It was working now it seems to be frozen the needle part wont move
Definitely get some good quality sewing machine oil. Sounds like the machine has basically seized, including the stitch selectors.
Apr 26, 2016 | Elna Sewing Machines
In my old but good elna sewing machine thread got stuck in bobbin case and it is jammed
then you need to get the bobbin case out and clear all thread . if you can not get it then you need to take to a repair shop
Nov 02, 2015 | Elna 2005 Mechanical Sewing Machine
Elna 6200 stuck in bobbin mode but sticking
Is the bobbin winder spindle on top of machine pushed over to the right in winding position? Move it back to left to change back to sewing mode.
Nov 30, 2013 | Elna Sewing Machines
1960s Elna Supermatic - lower thread only catches sometimes
Make sure you have the correct needles for this machine and that it is fully inserted into the needle bar and correctly oriented.
Mar 20, 2013 | Sewing Machines
My sewing machine will not stich. i have tryed everything i can find on this problem but nothings working
Make sure nothing has either gotten stuck/caught/jammed somewhere inside it. Insure that the thread stays attached to the needle. Or the material you are trying to sew/stitch may be too thick.
Nov 17, 2012 | Singer Sewing Machines
Skipping stiches
SKIPPED STITCHES
1.the needle is not inserted correctly
2.the needle is damaged
3.the wrong size needle is being used
4.the foot is not attached correctly
Jul 10, 2012 | Elna 2005 Mechanical Sewing Machine
I have a necchi 4575 and when I sew a straight stitch it will sew just fine and then for a few stictches it wil act as if its out of thread but then it will pick uop and sew normal for a few more stiches...
Sounds as though either the hook is out of time to the needle, or you have a bent needle. There are videos on Youtube that deal with sewing machine timing. Try a new needle, and make sure it is installed and seated correctly
Jan 05, 2012 | Necchi 4575 Mechanical Sewing Machine
Cant make the auto threader work on an elna 2007
Do you mean the auto needle threader?
Mine won't work on very small needle sizes so I resort to the old manual needle threader for these. Ditto for twin needles.
Otherwise its a case of pulling the auto threader down so the hook swings into the needle eye, then pulling the thread over the face of the needle and catching it into the hook, then release the threader so it pulls back through the needle eye, taking the thread with it.
The only other thing that springs to mind is "is the needle at the top position in its stich cycle so that the threader lines up with the needle eye?
hope these ideas help a little.
Dec 03, 2010 | Elna 2007 Mechanical Sewing Machine
Needle stays stuck whilst motor runs. Elna sewing machine
Nov 15, 2009 | Elna 2007 Mechanical Sewing Machine
Sewing Machines Logo
12 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Derek Massey
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
