I have owned my machine for 2 years and it has been great. But recently my espresso just does not taste like it used to: seems to have lost flavour and strength. I also seem to get more water than before in the drip tray after each cup, although I not sure what a reasonable amount is. I took the solenoid apart, as per the on line instructions, but found nothing wrong. I ony use it only on weekends, so light usage.
Comments:
Jun 01, 2009
- EsWorld, I am the only coffee drinker in the house, and only on weekends. I grind only what I need at the time, but I don't always go through a bag a month. I'll try the larger grind, and the machine cleaning. Thanks.
Try backwashing the group with purocaff. Are you using coffee ground at the store or do you grind just before use? How fresh is the coffee less than a month or more? If more than a month(whole beans) it is no longer useful. If more than a 3 days(ground), that is stale also. It will be very diffucult to get good espresso from that(not impossible, but difficult).
If using store ground, it cannot be ground older than a week(coffee loses flavor and taste minutes after being ground). Try getting less coffee more often and adjust the grind setting that you use. If you have always used setting 3 on the store grinder try 2.5. If grinding at home adjust the settings on the grinder to a slightly coarser grind and fill the portafilter slightly over the top of the basket, now tamp to the indent(fill line) in the basket. that should be sufficient to pull a great shot.
Hi, last week I purchased the Rancilio Silvia Espresso Machine. For most of this time I have been...
(More)
Hi, last week I purchased the Rancilio Silvia Espresso Machine. For most of this time I have been having near perfect coffee. Today for some reason, the shot has poured way too quickly resulting in weak coffee. The grind appears to be fine, I have tampered it the same as I have over the past week, the only thing that seems to be happening is the water coming out too quickly. Can you see a solution to this promblem? thankyou.
I have a Rancilio Silvia about 2 years old. About 10 days ago I did a descale and backflush process,...
(More)
I have a Rancilio Silvia about 2 years old. About 10 days ago I did a descale and backflush process, (very little came out) but now it is leaking from the right hand side when facing machine (but only when turned on) from the gap between the base and the body. I suspect it is the 3 way solenoid valve, but would like some advice before we attempt a repair. Is this a symptom of solenoid breakdown and is it a self repair job for a handyman husband?
