Question about HP Photosmart 3310 Printer
Clean underside scanner glass on HP Deskjet 3520
SOURCE: glass cleaning
first remove scanner cover look at how it is connected in hiddle is raised piece dont rember if you push towards front or back of printer its been awile scince iv had to do this one on left side of scanner is two screws screws on right are under control panel to remove this carefully take off cover over numbers by putting small screwdriver at bottem of lcd and lift up on cover over buttens after this is up find small slot on very front middle where this cover was if you press down carefully and slide control panel forword to release do slowly two ribben cables attach it remove carefully then remove all screws with T-10 driver glass and outer plastic should lift do not damage ribben cables after glass clean put cables back thru slot carefully replace screws reattach control panel cables look at how it slides back on
Posted on Mar 16, 2008
SOURCE: glass dirty on bottom side
Here's the HP link to clean most of the scanner printers
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=c00553775&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
Posted on Apr 06, 2008
  • 14 Answers
SOURCE: clean inside of printer glass
http://h10025.www1.hp.com/ewfrf/wc/document?docname=buu01831&cc=ca&lc=en&dlc=en&product=79499
NOTE: The underneath side of the scanner glass cannot be cleaned on any product. This is unlikely to be necessary and should only be done by an authorized service provider.
This note is found on that website. For an authorized service provider near you: http://hp.infonow.net/bin/findNow?CLIENT_ID=HP_LOC_CAN_SRV (in Canada)
http://hp.infonow.net/bin/findNow?ONE=1&CLIENT_ID=HP_LOC_USA_SRV&PAGE=Search.html&LANGUAGE=USA_ENGLISH
(in USA)
Posted on Jun 13, 2008
LaziMon
  • 5 Answers
SOURCE: cleaning scanner glass
This solution is for the HP 3310 all-in-one.
How to clean under the glass.
1. Find the small wire that runs from the lid to a jack on the back and disconnect it, un-clip the wire from the holders and let it hang free.
2. Lift the lid and pull it straight up about 3/4 of an inch, you will see two indents in the hinge, push these one at a time to release the lid. Remove it completely.
3. 3 screws are located under the hinge, remove them as well as the two in the front.
4. In the back, gently pull on the silver end pieces to release the top from the unit.
5. You can now turn it over to clean the glass.
6. to reinstall reverse the steps and remember to plug the jack back in.
That's it, easy when you know how. Pay HP service nothing!
Posted on Jan 01, 2009
  • 11 Answers
SOURCE: flashing on/off light on hp deskjet 3520 printer
Introduction The printer lights indicate the printer status. These lights can be on, off, or blinking (flashing), depending on the status of the printer. The sections below describe the most common combinations of blinking lights, how to fix the issue, and how the issue is caused. NOTE: The light patterns included in this document are described as blinking or flashing lights. For the purpose of this document, "flashing" means the same as "blinking." Blinking lights Printer lights can can blink for more than one reason, so the solution can vary. These solutions need not be performed in a specific order, but solutions for the most common issues are presented first. Blinking lights are often accompanied by an error message on the computer screen, which might help determine the solution. Issue: Power light is blinking
c00374282.gif Solution
Close the cover.
Cause
Printer cover is open. Solution
Insert appropriate media in the In tray.
Cause
The printer is out of paper. Solution
  • Change the printer's print mode setting.
  • Change the printer's paper type selection.
  • Use a different brand of label media.
Cause
The printer has difficulty picking up label media. Solution
Follow each of these steps until the problem is resolved:
  1. Remove the paper from both paper trays.
  2. Press the power button once. Wait a moment for the paper jam to clear.
  3. If printing labels, verify that a label did not become detached while passing through the printer. If the paper jam was not resolved, continue on to the next steps.
  4. Remove the rear access door.
  5. Remove the paper jam through the opening at the back of the printer.
  6. Replace the rear access door.
  7. Reload the paper into the paper In tray.
  8. Print the document.
Cause
There is a paper jam. Solution
  1. Remove and then reinsert the print cartridge(s) into the printer.
  2. Clean the print cartridges automatically using the Clean Cartridges option in the Printer Assistant.
  3. Manually clean the print cartridges and print cartridge cradles:
    • Open the printer cover and wait until the carriage moves to the center.
    • Press the Power button to turn off the printer.
    • Disconnect power cord from the back of the printer.
    • Remove the print cartridges and place them on a piece of paper with the nozzle plate facing up.
    • Lightly moisten a cotton swab with distilled water.
    • Clean the face and edges of the print cartridges with the swab. Do not touch the print cartridge ink nozzles or copper contacts.
    • Wipe the underside of the print cartridge cradle walls using a clean, moistened swab.
    • Reinsert the print cartridges.
    • Close the printer cover.
    • Connect the power cord to the back of the printer.
    • Press the Power button to turn on the printer.
  4. Calibrate the print cartridges.
  5. If the light is still flashing, replace the print cartridges.
Cause
There is a problem with a print cartridge. Solution
  1. Print a printer self-test by holding the power button down with a pencil and opening and closing the top cover four times.
  2. Check the nozzle self-test pattern in the self-test print out. If one or more of the solid rectangular areas are missing, an electrical contact problem may be present.
  3. Remove and then reinsert the print cartridge(s) into the printer.
  4. Print the document.
  5. If the problem persists, follow the steps listed above for cleaning the print cartridges and print cartridge cradle.
  6. Try printing again. If the problem continues, replace the print cartridges.
Cause
The print cartridge has partial loss of electrical interface with the carriage connections.
Posted on Mar 04, 2009
How to clean the underside of the glass in a HP scanjet 2400
Hi ,
You probably already found this :
http://h20565.www2.hp.com/portal/site/hpsc/template.PAGE/public/psi/performMaintDisplay/?sp4ts.oid=297429&spf_p.tpst=psiContentDisplay&spf_p.prp_psiContentDisplay=wsrp-navigationalState%3DdocId%253Demr_na-c01275864-2%257CdocLocale%253Den_US&javax.portlet.begCacheTok=com.vignette.cachetoken&javax.portlet.endCacheTok=com.vignette.cachetoken
According to it , you should normaly contact a HP technician to have the job done . Nevertheless , I succeeded to clean the underside of the glass inside a HP Scanjet 5470C wich seems similar to your model 2400 . If you take of the lid of the unit , you should find two screws in the opening of the hinges . Unscrew them and lift up the the whole top of the unit . You might encounter somme kind of resistance during the operation but I finally succeeded to get the it free that way .
Best regards .
Sep 04, 2014 | HP ScanJet 2400 Flatbed Scanner
Clean printhead and breather hoses hp 3520
try to reset the the black printhead , and clean the it
Mar 23, 2013 | HP DeskJet 3520 InkJet Printer
How to clean the glass underside of the hp scanjet g3010
working with computers since 1964 (yes, there were computers even then...), with consumer scanners since 1988, servicing hp equipment and scanners since 1998, for saving my life - i never, ever see any smudging on internal surface of the glass... could you kindly elaborate how you get smudging there?
there is no consumer serviceable parts inside, these are "disposable" scanners and never intended to be repaired or serviced inside.
Apr 24, 2012 | HP Scanjetâ„¢ G3010 Flatbed Scanner
How do you clean the underside of hp5590 glass?
Detach the ADF assembly. Remove the 4 case screws from the scanner bottom. The case has a notch at the back that has to be unclipped to separate the top and bottom. Clean the glass underside repeatedly, I use methylated spirits on soft toilet roll. Check in the glare of the scanner light, and reassemble.
May 19, 2011 | HP Scanjet 5590 Flatbed Scanner
Driver for HP Deskjet 3520
try to click at this link....use windows 2000
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&product=305968&lang=en&
May 26, 2009 | HP DeskJet 3520 InkJet Printer
hello..
just follow this link
ftp://ftp.hp.com/pub/softlib/software2/COL4001/dj-13176-3/3500_enu_win2k_xpinfu.exe
copy and paste to your internet explorer
Nov 11, 2008 | HP DeskJet 3520 InkJet Printer
HP Photosmart 3310 Printer Logo
Seeker5211
Seeker5211
