Question about Hotpoint Dryers
Hotpoint dryer tl51 door catch ,dryer wont start
Door catch wont start the dryer,sometimes does but now not
5 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: tumble dryer hotpoint ctd00
Unscrew all screws that hold the 2 halves of the door together, then with a screwdriver or similar, prize apart the 2 halves of the door, be careful the door glass does not fall onto the floor.
Fit new parts, reassemble door, and hey presto!!!
Posted on Jan 06, 2009
todd0708
  • 247 Answers
SOURCE: hotpoint ctd40 t dryer. wont start just ticking.
do you hear anything running?,might have broken the belt or idler wheel,motor runs but no tumble,need to look inside,warning !! unplug ,high voltage.be carefull
Posted on Sep 22, 2009
hunter19_46m
  • 7482 Answers
SOURCE: I have a tumble dryer.
Sounds as if the door switch is the problem. This is normally a safety switch that stops the dryer when the door is opened.
Unplug the dryer.
Remove the door switch and check the switch condition with a continuity meter after removing the wires. Try turning the switch on and off....the meter should read power on and off when you do that.
You may have to remove the front of the dryer to get to the door switch.
Good luck,
I hope this helps
Posted on Oct 05, 2009
barkencoa
  • 3463 Answers
SOURCE: Hotpoint TL51 cable and plug
This indicates a badly fitted plug, loose wire in the plug, or a bad socket, check for discolouration of the socket and plug.
Replace if any sign of discolouration or browning of plug and socket.
Posted on Aug 20, 2010
Hotpoint condenser dryer door catch
http://www.repairclinic.com/vwo6/Shop-For-Parts/a8/Dryer-Parts
Oct 20, 2014 | Hotpoint Tumble Dryer Door Latch & Catch...
The door on my Hotpoint Aquarius Dryer CTD00 pops open during cycle is it the door catch that's worn?
If the door latches correctly at the time of wash then it is possible that there is a false trigger to release the door, if so you need to check on the lock.
check on this link for tips: Door lock
Jan 12, 2013 | Washing Machines
Hotpoint TL51 cable and plug get very hot
Aug 20, 2010 | Hotpoint Dryers
My machine has the door lock light on and wont start, the door is locked as i have to press the release to open it!
Remove the top cover, and release the door catch from inside the washer, you will probably need a screwdriver or similar to do do this.
You will need to replace the door catch and spring, and possibly the door lock, as it may break when you force the door open.
Thank you !!
Jun 26, 2010 | Hotpoint Aquarius WD63 Front Load...
Hi ,, my machine has no power ,, when i push the start button there is nothing at all ,, no lights nothing ,, i have tried the plug and fuse ,,the machine is the hotpoint wd645 ,,, many thanks
Try the plug in another socket that you know is o/k, if still no go ,then you need to remove top cover and rear panel, and check all connectins to control module/s.
Make sure the door is fully catch is fully engaged, as sometimes the spring can give out in the door handle.
Jan 16, 2010 | Hotpoint -Ariston Aquarius WD645 Front...
Hotpoint tdc 30 door catch will not push into door switch when I close door, have taken switch out and it fits into catch manually but not when it is installed so door will not close to activate drying
I would say that the problem is due to the door handle spring being weak or broken.
Purchase a door handle kit, and it should solve the problem, if it does not, then you need a new door switch.
Hope this helps with your problem.
Dec 09, 2009 | Hotpoint NVL333EY Electric Dryer
My door for a hotpoint ctd40 tumble drier wont stay closed. The spring latch seems ok but not holding dooe closed. Any ideas since it dont say anything in my manual about it and its 2 yrs old. cheers andy
Hi andy.
the fault is likely to be in the roller catch mechanism. Hotpoint have modified these. Part Number is C00257618.
It includes both door latch and catch.
If you have problems obtaining one please email me on: aardvark.repairs@btinternet.com or call me on 01733 307019
Regards
aardvark repairs
Nov 18, 2009 | Hotpoint Dryers
Unplug the dryer.
Good luck,
I hope this helps
Oct 05, 2009 | Hotpoint Dryers
Safety catch wont release after 2 minute swtch off.
hi there......sometimes this can be solved by reeating the spin cycle again....the door switch requires replacing
regards Sir Galahad
Aug 16, 2009 | Hotpoint First Edition FEW12 Front Load...
Dryers Logo
23 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Dan Webster
Dan Webster
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
