Question about Senco Tools & Hardware - Others
Angle nail frame pro 600 - Senco Tools & Hardware - Others
3 Suggested Answers
  • 152 Answers
SOURCE: just bought a senco pro 600 framer nailer what angle nail to use
My 600 uses 35 degree clipped head and is printed on the side of the magazine.
Posted on Mar 15, 2009
  • 885 Answers
SOURCE: what angle nails are used
The Senco Frame Pro 601 uses 34 degree clipped head nails.
Posted on Nov 23, 2010
D51822 is nailing at a 45 degree angle instead of 90 degree
Joe,
hey not sure what the d51822 brand name is I work on bostitch as a service tech. so well the obvious question with the details you've given 45 degree angle? so are they bent over to get that angle? not sure how they can come out straight and get bent. ok the nose ( where the nail comes out) is it completely flat on the board? if so I would be nearly impossible to create a 45 angle. not doubting you. I work on F28WW bostitch thinking they are similar so, check the bolts on the top (loose or damaged) or the nose its self see if it is bent. it would be only slight because otherwise the driver ( what pushes the nail in) would get jammed and not fire at all .try that first thinking the nose is bent and if its bent its junk. because cracks are next and that's when really bad things happen fast.
Nov 15, 2015 | Dewalt Heavy - Duty 31° Clipped Head...
Senco frame pro 601 turns nail upside down with nail head going in wood first
The nails can turn over if you have the wrong angle or gauge nails in the tool. Make sure you are using the proper nails for your gun because they are not all the same.
Feb 19, 2015 | Senco Tools & Hardware - Others
My 601 won't shoot any spikes it just leaves a 1/4 '' indent were nail should be?
If you're getting an indent in the wood from the driver, the gun is working properly. If the gun isn't driving fasteners/nails it's because the nail isn't under the driver when it's activated. Several things could cause this: Having the wrong angle nails in your gun. There is something in the feed path of the nails preventing them from feeding fully into the nose piece. The feed shoe is jambed or feed shoe spring is broken.
Feb 18, 2013 | Senco & Frame Pro 601 Framing Nailer
I was shooting 3 inch nains and I switched to 2 inch. after 20 or 30 nails it failed to drive a nail. The driver makes an indention in the wood but does not drive the nail. What are the problem...
Check that the driver is returning all the way to top of the cylinder. Driver will not return to top when lower bumper is cracked, driver is bent, or piston oring is too loose/tight or low air pressure to gun. Also check that the two inch nail is the same angle as the three in. Place the nails on the outside of the rails with the heads aligned with the rail. The first nail should align with the path of the driver. If the head of the first nail is angled back away from the path of the driver, will miss fire.
Mar 25, 2011 | Stanley Bostitch N88rh Framing Nailer...
What angle nails are used in a frame pro 601 senco
Nov 23, 2010 | Senco Tools & Hardware - Others
Check for pproper nails
what is the question, how to remove them and if so I would use a small pick to push them back out the magazine, and also when you get angle nails make sure you use the right guage.
Oct 07, 2009 | RTO PasLode 900420 Impulse Framing Nailer
DeWalt d51822 framing nailer, shoots 2 nails at once 1 in 5 times
I worked at at tool rental center while attending college and learned from the old tool masters about nails and nailers. Rental stores have many different brands of nailers to rent and customers would bring their own nails of all brands. You will notice on the case/box that your nails will /should work on many other brands however the degree or angle of the nails is not always exacly as stated on the box. You should check with protractor the exact angle of your nails and also check the exact angle of the nailer. Use straight edge on travel path of the piston and another on guide rails to check angle of the gun. You will discover that all is not as stated as in a perfect world. If the angle is off slightly, the head of the second nail will get into the path of the driver. This happens mostly with clip head because the nail heads are so close together. The full round head is spaced further apart with less jamming. If angle is off slightly, take a look at other brands of nails with protractor in hand, the angle will be different slightly or choose a slightly thicker nail. Look for the nails to fit with bottom of nail hitting the barrel first. This will move the head of the nail slightly away from the center line. Finally do not release pusher with force as this will jamb nails closer together. Good Luck!?
Jun 03, 2009 | Dewalt Heavy - Duty 31° Clipped Head...
Just bought a senco pro 600 framer nailer what angle nail to use
Mar 14, 2009 | Tools & Hardware - Others
Tools & Hardware - Others Logo
76 people viewed this question
Top Senco Tools & Hardware - Others Experts
John Trevino
yoopertech
John Bowen
Are you a Senco Tool and Hardware - Other Expert? Answer questions, earn points and help others
